No FTP Connection
Using Firmware Version: 1.18.1 (2017-04-09)
Enabled M586 P1 S1Ok then i need to switch to beta Firmware.
Read the important upgrade notes first.
Downloaded these https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Edge
Copy over existing iap4e.bin from 1.18 stableRuns Update with error could not rename beta firmware names to normal Firmware names.
Now it wont connect to my AP anymore.
Wifi reported error: no known networks found WiFi module is idlewont also Shown as AP to reconfigure Wifi.
M552 S0 also shows no reaction.Where are the important upgrade notes to find?
Are you using 1.19beta series firmware? Older Duet WiFi firmware doesn't support FTP.
Have you enabled FTP using the M586 command?
Hi I'm currently under the last Beta and I've also a problem regarding the FTP, whenever I try to push, replace,
deletea file/folder I'll get an ECONNRESET (connection reset by a peer) each time. Files and folders a listed correctly but totally unable to perform any modification, I tried in active mode and in passive mode, but same result. (note : I'm using filezilla)EDIT : delete command works
Upgrade notes are included at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md. For upgrading the Duet WiFi from 1.18 to 1.19 series firmware they link to https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta.
Did all listed in the Wiki link after sending M997 S0:1 he says Error in application programming binary "iap4e.bin" not found
copy old iap4e.bin updated started, trying if it works now again
Thx for help works again,only WiFi Connection takes long time.
FTP wont let me connect anyway.
Username: anonymous
Passwor: same that is used via Webinterface -
Jens-iMac:~ 135erHeli$ ftp ftp://135ercorexy.local
Trying 192.168.178.51…
Connected to 135ercorexy.local.
421 Service not available, remote server has closed connection.
ftp: Can't connect or login to host `135ercorexy.local'
Jens-iMac:~ 135erHeli$23:44:10
M586 P1 S1
FTP is enabled on port 21 -
Also when Homing X now Y is homing.Whats going wrong? Didnt read the config Files anymore?
The M667 Y-1 command was inserted before as my Printer was Printing Mirrowed.
Now i hav to Switch X and Y Motor Connection on the Board? -
So ill switch X and Y Motor Connection, but Printer Homes when ill say X Homing Y instead of X.
Any Idea? -
Swap the X and Y motors back to how they were and use the M569 command to reverse the direction of the Y motor. If in doubt check that the head moves correctly when you command the the motors individually as described at https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_CoreXY_printer#Movement_section.
