    inconsistent Z movement
    726
      Are you using those new motors on the Z axis as well?
      Is this a new problem after those recent changes?
      You can try bumping the motor current on the Z axis a bit. Try 1300ma.
      How heavy is the gantry?
      Have you squared up the gantry so that it's even on both sides? If you have a spare driver you could put each Z motor on it's own driver. (just add the second driver number to the M584 Z mapping, nothing else needs to change)
      kmartundefined 2 Replies Last reply Reply Quote 0
      • kmartundefined
        kmart @Phaedrux
        @Phaedrux said in inconsistent Z movement:
        Thanks for your reply.
        Yes i used those motors on the Z and this is only a problem after my changes. Prior to this everything was working reliably, i didn't have failed prints.
        I will play with the motor current and see if that makes any difference.
        I never weighed the gantry, previously it was a printed carriage with E3D hot end (bowden) on 2 smooth rods.
        After the change it's a piece of 2020 extrusion w/ linear rail, still printed carriage but direct drive. So it's definitely heavier... Just not sure how heavy.
        Everything is square, i guess the last attempt will be to run each motor on its own stepper. But i did run the same configuration prior to the changes so I don't know if that's really the problem or not... But I'm not an expert.
        Thanks again
        • kmartundefined
          kmart
          No progress really. I bumped up the current as much as i could while keeping the motors from getting hot (1375mA) but i still get the inconsistent Z movement.
          Next step will be to try independent steppers for each Z motor. Time is limited to work on this but hopefully i can try and get that setup in the next 1-2 days
          • kmartundefined
            kmart @Phaedrux
            M584
            So i setup this up
            M584 X0 Y1 Z2:4 E3
            But now i get this
            G28
            Warning: motor phase A may be disconnected reported by driver(s) 2 4
            Warning: motor phase B may be disconnected reported by driver(s) 2 4
            Is this because now one motor from Z is disconnected? How do i fix that?
              What is connected to drivers 2 and 4?
              Do you have the jumpers installed in the second Z port?
              kmartundefined 1 Reply Last reply Reply Quote 0
              • kmartundefined
                kmart @Phaedrux
                Originally Each Z motor was connected to Z1/Z2 (driver 2), i moved one to E1 (Driver 4) for each to be on their own driver as you suggested
                I didn't realize in the wiring diagram that there was option A and option B. After seeing that i installed the jumpers and now both motors are moving.
                So now new issue. Home x and Home Y lift Z by a few mm. I can see one Z motor is spinning faster than the other because one coupler expands... I doubt this is config related, what could potentially cause this, bad wiring?
                Edit, I just realized they're spinning in opposite directions
                Edit 2: Fixed that with M569 for driver 4. Will continue to test
                  M569 P0 S1 ; X goes forwards
                  M569 P1 S1 ; Y goes forwards
                  M569 P2 S0 ; Z goes backwards
                  M569 P3 S0 ; E0 goes backwards
                  Add driver 4 to the list and set the direction
                  • kmartundefined
                    kmart @Phaedrux
                    @Phaedrux
                    Yeah i had caught that just after posting. Fixed it and all is good.
                    Preliminary testing using a feeler gauge is that the height movement is consistent, or at least more than it was before.
                    But I've been wondering. Prior to all my changes i ran 12V, with the original Anet A8 stepper motors, with the dual Z connected to Z1 and Z2 and never had this problem.
                    Is there something wrong with the new motors i bought? Should i be looking at just replacing the Z motors with something more suitable?
                    Thanks,
                      The specifications of those motors look OK to me. Check that they move freely.
                      • kmartundefined
                        kmart @dc42
                        As far as I can tell they do, and I've quadruple checked the linear rail alignment that the gantry moves freely up and down without binding.
                        The only other thing i can think of is that i also added anti-backlash lead screw nuts... They were generic off of amazon, maybe they're causing some kind of additional resistance.
                        I may end up disassembling/reassembling the whole thing and verifying all wiring as well because this is the first time I've been really stumped.
                        But after a few tests this morning the consistency seems more reliable with independent Z drives so I'm going to move onto the next problem.
                        Thanks,
                          Phaedrux Moderator @kmart
                          @kmart said in inconsistent Z movement:
                          That's typically what they do. Sometimes to the point of binding if the motor isn't powerful enough. Backlash is typically not a problem on Z. So I'd try removing them.
