    No 3.3vdc at endstops
    • Claypotundefined
      Claypot
      I have a Duet Ethernet. My delta will not home because my end stops are always triggered. There are no LEDs for the endstops and no 3.3v on any of the pins. The 3.3v led is lit on the front of the board. Does anyone have any pro tips to fix my issue?
      • JustDaveundefined
        JustDave
        Are you using microswitches? If so are you using the normally open or normally closed contact on the switch?
        • Claypotundefined
          Claypot
          I am, just figured out by looking at schematic of board, need pin 1 and 3. I was on 2 and 3. 2 and 3 does not work…Confirmed. 1 and 3 DOES work.
          • JustDaveundefined
            JustDave
            Excellent!
              This is covered at https://duet3d.com/wiki/Wiring_and_hardware_differences_from_RAMPS_etc. and https://duet3d.com/wiki/Connecting_endstop_switches.
              • WZ9Vundefined
                WZ9V
                Yes, Duet uses the layout common with RC stuff which is setup to not kill things if you plug it in backwards (just won't work). The legacy 8-bit boards pin-out can result in VCC being sent to a signal pin or ground if plugged in incorrectly (bad). I prefer David's way (long time RC guy), he also uses locking connectors which is another smart move.
