    Help PID tuning Dyzend Pro
    Firmware installation
    5.8k
    • FBGundefined
      FBG @dc42
      @dc42 said in Help PID tuning Dyzend Pro:
      If anyone really wants to get this thermistor working with Duet 2, then I suggest you connect it to one of the thermistor inputs on the expansion connector, with a 27K reference resistor connected between the input and VRef. Then use R27000 in the M305 or M308 command.
      Dear dc42, i am very interested in do this. Could you explain a little more, with a schematic?
      Best Regards
      FBGundefined 1 Reply Last reply Reply Quote 0
      • FBGundefined
        FBG @FBG
        @FBG said in Help PID tuning Dyzend Pro:
        Best Regards
        I am also using Duet Expansion Breakout Board
          • Connect the thermistor between pins 35 (Thermistor3) and 40 (VSSA) of the 50-pin expansion connector
          • Connect a 27K 1% tolerance resistor between pins 35 (Thermistor3 again) and pin 41 ADVREF) of the expansion connector
          That's it.
          chris974Mundefined 1 Reply Last reply Reply Quote 0
          • ejarmoundefined
            ejarmo
            would you be willing to locate the appropriate pins on a maestro for this process
              dc42 administrators @ejarmo
              @ejarmo said in Help PID tuning Dyzend Pro:
              The Maestro does not have an expansion connector with thermistor inputs, so this process does not apply. You would need to desolder one of the existing 2K2 thermistor series resistors and replace it by a 27K resistor.
              There is just a chance that you may be able to get the thermistor working with the existing series resistor if you use the new semi-automatic calibration procedure that firmware 3.2beta1 supports. The calibration procedure is described at https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings. Caution, if you are currently running version 2.x firmware on your Maestro then upgrading to 3.x firmware requires significant changes to the config.g file.
              • chris974Mundefined
                chris974M @dc42
                @dc42 @dc42 désoler pour ma très longue absence je reviens sur se sujet qui est aujourd'hui mon dernier problème que je n'avait pas fini de régler. Sur l'extension a 50 broches j'ai une duex5 de connectez comment je dois procéder ?
                Merci pour vos réponses
                  Phaedrux Moderator @chris974M
                  @chris974m said in Help PID tuning Dyzend Pro:
                  sorry for my very long absence I come back to this subject which is today my last problem that I had not finished solving. On the 50 pin extension I have a duex5 to connect how should I proceed? Thank you for your answers
                  See here on using the Duex
                  https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features
                    chris974M @Phaedrux
                    @phaedrux merci pour ta réponse rapide, se n'est pas pour l'utilisation de la duex5 mais pour les branchement de la résistance 27k et de la dyzend
                      dc42 administrators @chris974M
                      @chris974m, if you have a Duet Ethernet or Duet WiFi, and you do not have a DueX2 or DueX5 connected, then you can use one of the thermistor inputs on the expansion connector like this:
                      • Connect the thermistor between the chosen thermistor input and VSSA
                      • Connect the 27K resistor between the same thermistor input and VREF
                        chris974M @dc42
                        @dc42 désoler encore j'ai du mal peut être a comprendre mais je ne peut pas m'en servir en ayant la duex5 de concerter
                          chris974M
                          Je ne peut donc pas me servir de cette thermistance ? si quelqu'un pourrait m'aider please
                            Do you have a Duex 5? Yes or no?
                              chris974M @Phaedrux
                              @phaedrux Oui j’ai un duex5 de connecter
                                @chris974m Then you can use the thermistor input on the Duex itself if you've run out of ports on the main duet board.
                                  chris974M @Phaedrux
                                  @phaedrux said in Help PID tuning Dyzend Pro:
                                  @phaedrux donc le hotend ne fonctionnera qui si je le connecte au duex5
                                    @chris974m Well DC42s original suggestion was to try and get it to work with the expansion header, but you've got the Duex5 using the connector already, so you're left with the thermistor inputs on the board itself. Unless @dc42 has another suggesting for using it when the Duex is populated.
                                    chris974Mundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      chris974M @Phaedrux
                                      @phaedrux d’accord merci j’attend une nouvelle réponse
                                        dc42 administrators @Phaedrux
                                        I guess you could identify one of the conductors in the ribbon cable that carries one of the DueX5 thermistor inputs. Cut that conductor, and bridge the cut with a resistor of about 22K (plus the 4.7K on the DueX5 will give 26.7K). Connect the thermistor between the Duet end of the 22K resistor and the VSSA pin of any thermistor connector.
                                        However, we have a number of users running Dyze thermistors without changing the value of the 4K7 resistor, so you may be able to get that working well enough.
                                        chris974Mundefined 3 Replies Last reply Reply Quote 0
                                          chris974M @dc42
                                          @dc42 merci beaucoup pour votre réponse.
                                          Je sais pas si j’ai bien compris mais je faire les meme étape que vous m’avez citer avant mais en coupant mon câble duex5 est-ce exact ?
                                            chris974M @dc42
                                            This post is deleted!
