Unsolved Bug: RRF 3.3beta2 - G92 B0 changes E axis position
@dc42 Thanks, I will try to have a go on it over the weekend, Monday at latest.
Error: M997: In-application programming binary "0:/firmware/Duet2_SDiap32_WiFiEth.bin" not found
I don't normally have a firmware folder?
I re-ran the tests today and this is the shortest way of replicating the issue:
29/03/2021, 19:30:32 Emergency stop, attemping to reconnect... 29/03/2021, 19:30:39 M114 X:0.000 Y:0.000 Z:0.000 B:0.000 E:0.000 E0:0.0 Count 0 0 0 0 Machine 0.000 0.000 0.000 0.000 Bed comp 0.000 29/03/2021, 19:30:47 G1 E1 F500 29/03/2021, 19:30:47 G1 E1 F500 29/03/2021, 19:30:48 G1 E1 F500 29/03/2021, 19:30:53 M114 X:0.000 Y:0.000 Z:0.000 B:0.000 E:0.000 E0:3.0 Count 0 0 0 0 Machine 0.000 0.000 0.000 0.000 Bed comp 0.000 29/03/2021, 19:31:00 G92 B0 29/03/2021, 19:31:04 M114 X:0.000 Y:0.000 Z:0.000 B:0.000 E:0.000 E0:1.0 Count 0 0 0 0 Machine 0.000 0.000 0.000 0.000 Bed comp 0.000
Can we have another 't' in attempting please?
3.3 adds the use of a /firmware folder to help clean up the sys folder.
Are you also using DWC 3.3 beta2?
You may need to create the folder manually and move your firmware files over.
@phaedrux said in Bug: RRF 3.3beta2 - G92 B0 changes E axis position:
It's sufficient just to upload the IAP file through DWC again.
I'll have a go first thing tomorrow. Things overran today.
This post is deleted! -
@dc42 Problem remains...
30/03/2021, 08:28:39 M114 X:0.000 Y:0.000 Z:0.000 B:0.000 E:0.000 E0:0.0 Count 0 0 0 0 Machine 0.000 0.000 0.000 0.000 Bed comp 0.000 30/03/2021, 08:28:52 G1 E1 F500 30/03/2021, 08:28:53 G1 E1 F500 30/03/2021, 08:28:53 G1 E1 F500 30/03/2021, 08:28:58 M114 X:0.000 Y:0.000 Z:0.000 B:0.000 E:0.000 E0:3.0 Count 0 0 0 0 Machine 0.000 0.000 0.000 0.000 Bed comp 0.000 30/03/2021, 08:29:06 G92 B0 30/03/2021, 08:29:09 M114 X:0.000 Y:0.000 Z:0.000 B:0.000 E:0.000 E0:1.0 Count 0 0 0 0 Machine 0.000 0.000 0.000 0.000 Bed comp 0.000
Contents of system folder: https://www.dropbox.com/s/7c18bi3c23hz3bc/210330_download.zip?dl=0
Board: Duet 2 Ethernet (2Ethernet)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3beta2+1 (2021-03-26)
Duet Web Control 3.3.0-b2 -
@doctrucker, thanks, I've reproduced that. Looking into it now.
Fixed in next 3.3beta.
@dc42 great!
