    Sensorless homing not working
    • jujojujo_2003undefined
      jujojujo_2003
      I have an ender 3 with these stepper motor drivers for X & Y axis https://www.printedsolid.com/products/ldo-nema-17-motor-high-temp-voron-ldo-42sth40-1004mahvrn
      (this is a 0.9 stepper) and I am not able to get sensorless homing to work. I have a duet 3 mini 5+ board (with 3.2.2 firmware)
      What I gather from https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
      there are the following variables that I can play with to get sensorless homing to work
      i) The current percentage value for stepper motor in M913 command
      ii) The feedrate for G1 command for homing
      iii) The sensitivity params (S ) in M915
      iv) Stealthchop <-> Spreadcycle cutoff given by V param in M569
      From the docs, the only restriction is that feedrate must be lower than Stealthchop <-> Spreadcycle cutoff (which we get from M569 P0.0 command multipled by 60 to convert mm/s to mm/min)
      I have tried a bunch of values for these 4 params
      i) M913 ranging from 10-100
      ii) Feedrate ranging from 2400 to 7500 (capped by stealthchop cutoff)
      iii) Sensitivity ranging from -63 to +63
      iv) V param for M569 ranging from 1 to 100
      For all these cases, the X carriage just seems to move and crash with "Homing failed" message. Given that for all values, high and low I get the same crash, I am not sure how to move or change the parameters.
      Also with V < 50, I either get "driver short to ground" error or "high motor temperature" error.
      Shouldn't setting sensitivity (S param in M915) to a very low value cause the stall detect to be triggered all the time?
      Any idea how I can get this to work?
      config.g
      homex.g
      homey.g
      retractprobe.g
      homex.g
      M98 P"retractprobe.g"
      M913 X70 Y70  		; drop motor currents to 40%
      M915 X S-20 R0 F0 H400; Sensitivity 4, don’t take action, don’t filter, 400steps/sec
      G91 				; set relative
      ;G1 H2 Z5 F1200      ; lift z by 5
      G1 H1 X-250 F4500	; move left 250mm, stopping at the endstop
      G90 				; back to absolute positioning
      M913 X100 Y100 		; motor currents back to 100%
      M915 S63 X Y R0	    ; Disable Logging and lower stall detection
      o_lampeundefined David Greenundefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @jujojujo_2003
        @jujojujo_2003 said in Sensorless homing not working:
        I'm no expert either, but to me a lower sensitivity leads to harder crashes?
        • David Greenundefined
          David Green @jujojujo_2003
          I use:
          M400
          M913 X70 Y70 ; drop motor current to 70%
          G91 ; relative positioning
          G1 H2 Z10 F6000 ; lift Z relative to current position
          G1 H1 X-320 F12000 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X15 F1800 ; go back a few mm
          G1 H1 X-320 F12000 ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-10 F6000 ; lower Z again
          G90 ; absolute positioning
          M400
          M913 X100 Y100 ; return current to 100%
          Which works on my CoreXY I don't have the M915 in the homex or y.g
          jujojujo_2003undefined 1 Reply Last reply Reply Quote 0
            jujojujo_2003 @David Green
            @david-green Tried this one too but it crashes again. 😞
              jujojujo_2003
              Looking at https://forum.duet3d.com/topic/21108/stall-detection-on-duet-3-mini/4 , I tried updating to V3.3 beta firmware and tried a bunch of S values for M915 from -128 to +127 but still the same crash.
                jujojujo_2003
                M400                      ; Wait for current moves to finish
                M913 X70  		          ; drop motor currents to 50%
                M915 X S-3 R0 F0 H400     ; Sensitivity -3, don’t take action, don’t filter, 400steps/sec
                M569 P0.0 V10             ; reduce V parameter so driver operates in stealthChop
                G4 P200                   ; wait 200ms
                G91 				      ; set relative
                G1 H1 X-255 F4000         ; move quickly to X axis endstop and stop there (first pass)
                So this is the config that worked for me(On v3.3 beta). It looks like we need to dial M569's V param first such that for that V param, M915 S-63 always triggers a stall and M915 S63 always triggered a crash. Then you binary search on the correct S value
                The problem now is that it homing doesn't work when the gantry is towards the end of x axis. But then If I home twice then it works. This seems very hacky. and also I keep getting "Error short-to-ground reported by driver(s) 1"
                  jujojujo_2003
                  SO I was able to fix this by reducing the current. My stepper current was set to 900ma . Probably this was too high(even though this is < the rated current of both stepper and driver)
                  Lowering it to 700ma fixed the issue.
