    Problem after Update
    stepper motor noise don’t move update firmware 3 update
    • MauriceMundefined
      MauriceM
      Hey,
      Im jsut building another Voron V2 and i wanted to use the same Firmware Setup as in my other Printers.
      But i use RRF3.2.2 on my new Build and it seems that something changed because my steppers wont work.
      I connectes them the same way as on my old printer.
      All it does is making some noise.
      To check the cables i connected one Stepper to my other printer and there it works.....
      Can it be that something changed from RRF3 to 3.2.2.
      And if so am i able to change the firmware to 3.0?
      If it try this, i get an error message that some folders are missing...
      What weard, because i updated 3.2.2 on this board via de Web Interface
      Thanks alot.
      MauriceMundefined 1 Reply Last reply Reply Quote 0
      • MauriceMundefined
        MauriceM @MauriceM
        This post is deleted!
          Please post the results of sending M122 and M98 P"config.g".
          You're sure the motor phases are paired correctly?
          https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
