Win 7 laptop connection issues
2.1k
    T3P3Tony administrators
    As you have said this is very odd, I assume the laptops that don't connect are on the same network? Do you get any hints when you inspect the traffic seen by chrome when trying to connect?
      number40fan
      All computers/tablets/phone on the same network. Sorry, but I have already uninstalled Chrome and Firefox since they didn't work. Give me something to test in IE and I'll be all over it.
        Ahh sorry well IE does not work properly the last time I tested it as it does not implement the HTML 5 standard fully. You will need to use firefox or chrome. As far as the issue is concerned I am trying to see if the browser is connecting to the duet and then failing to load something or if its not connecting at all. Chrome (and maybe firefox &IE) allow you to get more information about what the browser is doing by inspecting the web page.
          number40fan
          I see. I'll redownload Chrome. Let me know what I need to do.
            number40fan
            Loaded Ubuntu on an SD card, booted up to it and I can access DWC without an issue using Firefox.
              FrankNPrinter
              you might try adding the url to trusted sites in browser options. depending on your AV/malware/ browser settings, security could be blocking you in win7 and of course make sure you have applied the latest patches from Microsoft at a minimum you should have updates from May. April was when the wannacry virus broke and they released a bunch of security updates based on it…
                number40fan
                Fully up to date. Tried adding it to safe sites. Even tried a new router since it was so old that you couldn't set the date past 2015. But, sadly, nothing has been able to fix the issue. Tried a third Win 7 laptop that I own….nothing.
                  FrankNPrinter
                  you can ping by ip address, how about a tracert to see what is in between your pc and printer? any firewalls ect? i use chrome BTW.
                  open command prompt
                  type tracert "printer adx"
                  from your description, only thing in between is your switch\router right?
                  win 7 32 bit or 64?
                  depending on router model, log in and it should tell you IP and net name of printer. try netname as well and see if it yields different results. I know if i leave my printer off for a couple days or so, the IP address often changes so net name is a great workaround for DHCP
                    number40fan
                    I have the printer locked into an IP. I can ping it using the IP address. Same MSE on all computers and I have tried disabling via msconfig to try without and it didn't help.
                    ping duetwifi = ping request could not find–- Even on the PC that can connect, so maybe I am doing something wrong here.
                    Tracert (IP Address) shows 1: * 2837ms 10ms
                    All laptops and one PC (that can connect) are going through one wifi router.
                    64 bit.
                    Netname? Couldn't find any relevant info on how to use.
                      number40fan
                      I am finally able to connect to the DuetWifi with my laptop after editing the registry and removing all instances of Java. I then downloaded the latest Java and installed it.
                      I still get this error when trying to view the System Editor.
                      [[language]]
                       JavaScript Error
                       A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
                      Message: Object doesn't support property or method 'endsWith'
                      URL: http://192.168.1.7/js/dwc.js
                      Line: 3333:2
                      Error object: {"description":"Object doesn't support property or method 'endsWith'","number":-2146827850,"stack":"TypeError: Object doesn't support property or method 'endsWith'\n at addSysFile (http://192.168.1.7/js/dwc.js:3333:2)\n at success (http://192.168.1.7/js/dwc.js:3395:8)\n at i (http://192.168.1.7/js/dwc.js:2:27598)\n at j.fireWith (http://192.168.1.7/js/dwc.js:2:28311)\n at A (http://192.168.1.7/js/dwc.js:4:13856)\n at Anonymous function (http://192.168.1.7/js/dwc.js:4:16146)"}
                        That could mean that you are using incompatible versions of Duet Web Control and RepRapFirmware. Which versions are you using?
                        Please confirm that the browser is Chrome or Firefox.
                          number40fan
                          Firmware Name: RepRapFirmware for Duet WiFi
                          Firmware Electronics: Duet WiFi 1.0
                          Firmware Version: 1.18.1 (2017-04-09)
                          WiFi Server Version: 1.03 (ch fork)
                          Web Interface Version: 1.15a
                          Web Interface by Christian Hammacher
                          Licensed under the terms of the GPL v3
                          Using Chrome.
                            number40fan
                            Sorry for wasting your time. I was back in IE when I had that java error. With Chrome, it is fine. At least I can connect now with the laptop.
