    423
    99.9k
    • Whitewolfundefined
      Whitewolf
      Just got my drop in unit today, just a quick inquiry before i screw something up. Should i losen the rear before tightening the front screws or should i just tighten the front?
      I dont want to damage the disc so i figured i would ask, but it isnt level.
        Whitewolf
        So i just opened it up to check out the disc, while reassembling i noticed that it does not fit inside the middle plate which is what is casuing the mount to be tilted. Is this by design or should i print a new center plate?
        • DjDemonDundefined
          DjDemonD
          The disc is designed to sit on a flange just inside the outer circular recess. It is not supposed to be inside the deeper recess. The idea is the lower part bends the disc in the centre. Do up the screws gradually and ensure they are all done up the same amount with a little preload on the disc.
          Then re-tune the module as per instructions, any change in preload level will affect the precision of it.
          www.precisionpiezo.co.uk
          • DjDemonDundefined
            DjDemonD
            If it's one that I made the disc fitted when I made and tested it. But sure you can print a new one if you want. Might be worth watching my YouTube video series on assembling it. It looks simple but won't work if done wrong.
            How to Guides: https://www.youtube.com/playlist?list=PL9g_2J-RjkRCy5Sr5gIVwMYGhI9DrJewq
            Sorry for being a while getting back to you I don't check here so often our official support thread is at reprap forum:
            http://forums.reprap.org/read.php?1,767998,page=13
            • fmaundefined
              fma
              Hi!
              As cheap piezo discs are mostly made to build buzzers, why not using them this way?
              The idea is to use 2 piezos: one on the head, and one somewhere on the heatbed. One of them is used to generate a vibration, and the other one to detect this vibration, which will be transmitted when the hotend is in contact with the bed.
              It should be possible to find a resonant frequency to optimize transmission (far from motor vibrations and other noise…).
              In fact, any kind of transducer can be used on the bed, to generate the frequency, to have more power than a simple piezo, so it can be easily detect by the head.
              A friend in our hackerspace wrote, a few months ago, an Arduino routine to detect a single frequency, which can help to analyse the signal: https://gist.github.com/edgar-bonet/0b03735d70366bc05fc6
              Just an idea. Let me know if it has already been discussed.
              Frédéric
              • DjDemonDundefined
                DjDemonD
                Thanks, it has been discussed more so on reprap in the general piezo thread http://forums.reprap.org/read.php?1,635075. I've never tried it, but whilst its an alternative approach is it potentially a solution looking for a problem, as the current method works so well adding a second piezo, and possibly adjusting/changing the PCB to search for the frequency outputted by it, would only be worthwhile if we were going to gain some sensitivity or better discrimination between a trigger and a false trigger (with current firmware settings this isn't particularly a big problem). I'm down to 4g of force to trigger on my microdelta with underbed piezos.
                • fmaundefined
                  fma
                  Well, I was trying to find a solution which doesn't need specific mount for the hotend nor the bed…
                  I will read the reprap thread. Thanks.
                  Frédéric
                  • DjDemonDundefined
                    DjDemonD
                    The gold standard (unless you want to calibrate/level manually) is electrical contact, but we don't have conductive printing surfaces, on the whole, so it isn't practical. You can get conductive PEI at eye-watering prices.
                      Whitewolf
                      @DjDemonD:
                      It was how it arrived look at the photo, bought one of your drop in units. I only dissasembled to see why it was so lop sided (have not even installed the thing because i dont want a hotend that sits at an angle. the disc does not fit in the outer recess, i will print another and follow the video. or i might just wait and install the bed sensors that you are shipping to me
                      just giving you a heads up for QA
                      • DjDemonDundefined
                        DjDemonD
                        That's just very odd, is it installed already? I'm tempted to send you another one and pay you the shipping to return it by regular airmail. I'd like to see what happened.
                        If it's installed and working then leave it if you're happy to.
                          Whitewolf
                          Its not installed, it arrived, i took it out of the package made my post here then left on a fishing trip. Came home to an overheated and fried computer from this heatwave we are having 😞 hopefully ill have my computer up and running by the time your bed piezo sensors arrive.
                          • fmaundefined
                            fma
                            Does anyone has a working design for a Diamond hotend? Ian, did you make progress on yours?
                            Frédéric
                            • DjDemonDundefined
                              DjDemonD
                              Your best bet here, and quite practical on a delta, for example, is to use underbed piezo sensors. There are designs for mounts, and with a stationary bed it works very well.
                              Here are some exmaple bed mounts
                              https://www.thingiverse.com/thing:2446460
                              You add to that the piezo kit:
                              https://www.precisionpiezo.co.uk/product-page/precision-piezo-z-probe-kit
                              After a bit of tuning you should be probing away with high sensitivity and with whatever hotend/nozzle you want.
                              • fmaundefined
                                fma
                                Ok, thanks.
                                Frédéric
                                • fmaundefined
                                  fma
                                  Mmm, I may have another idea… What about having the hotend (any hotend, in fact) mounted on a support which is anchored on one side, but free on the other side. On this free side, it is supported on a piezo disc. In order to have a good sensitivity, a spring put the right force on the piezo (just to maintain the head in its position). Then, once the bed calibration is done, an additional force can be applied (to increase the spring one) to firmly maintain the hotend (it can be a simple servo eccentric)...
                                  In fact, it can be the opposite: a very strong spring firmly maintains the hotend, and the servo releases a little bit the force so the piezo is less strained, and more sensitive. Could work with a FSR too.
                                  Frédéric
                                  • franzelkaundefined
                                    franzelka
                                    I ordered an assembled kit (screwmount version) and I‘m very curious how it will perform compared to the IR sensor (tilt problems etc.)
                                    I didn’t find a dedicated effector design for my Kossel Mini (Think3DPrint3D). What will be the best way to mount the piezo20, just screw underneath the original effector?
                                    • DjDemonDundefined
                                      DjDemonD
                                      Thanks for the order.
                                      Compared to the IR sensor (unless you have an evenly reflective (to IR) bed surface, which remains evenly reflective at all times, and no tilt), it will be like breathing fresh air. Tilt isn't a problem in the same way. There is no x or y offset so the nozzle determines the height at any given probing point, whether the entire effector and attached nozzle are tilted or not. In theory, if your tilt is quite minimal this should generate little/no issue with calibration/first layer thickness.
                                      However, if you have a very precise machine (or large one) then tilt is still going to feed into your calibration and reduce its accuracy to some extent, as instead of the trigger height being different relative to the nozzle at different probing points because of tilting that you see when using an offset sensor, its the nozzle height that changes if the effector tilts. So try to get rid of tilt if you can.
                                      As for mounting start off by using the supplied drilling guide (also a natty keyfob) to drill 2 3mm (3.5mm) holes equidistant from your central hole for your filament path, then screw the unit under your effector using m3 screws. This works but absorbs around 18mm of your z printing height.
                                      Once you've determined you are satisfied with the performance of it, consider designing an effector with the upper part of the unit integrated into it (even better if this is raised above the effector, so that just your heater block hangs beneath, this really reduces the effect of any tilt you might still have, but makes cooling the heatsink a little more challenging), to regain the z height you lost.
                                      • zendesignerundefined
                                        zendesigner
                                        HI Simon,
                                        I just ordered your Orion module yesterday , with the intention to use it with a duet Wifi on a Kossel Metal delta printer.
                                        Nice to find your thread here. looking forward to reading it and combining it with the DUet.
                                        Bart
                                        • DjDemonDundefined
                                          DjDemonD
                                          Thanks Bart. I think it will provide a great addition to your printer and its duet board. Accurate probes on a delta reduce the workload considerably.
                                            deckingman
                                            @fma:
                                            No. I went for a different arrangement. My Diamond hot end assemblies (3 of them) have steel dowel pins which mate with oil filled bronze bushes in the X carriage. This allows an amount of Z movement whilst constraining any XY movement. Actually I reamed out one of the bushes and use a couple of springs on the other bushes which allows the hot end assembly to tilt when pushed from below. Then I went for a simple precision switch which has a repeatability of 0.005mm. So basically the hot end is the probe like the Piezo but I'm using a simple switch instead. When the nozzle comes into contact with the bed, the side of the assembly nearest the switch tilts upwards. I've got it set so that it only takes 0.3mm of movement to trigger the switch. It works like a charm and has been running for about a year. The mechanics are a bit involved but there is no calibrating - it's just a simple (but quite expensive) switch.
                                            I wrote a bit about it on my blog, about half way down this page https://somei3deas.wordpress.com/my-corexy-printer-build/
                                            There is a bit more on this YouTube video https://www.youtube.com/watch?v=0lW0EgNX0iQ&t=50s from about 2:24 and again at 3:42.
