    DWC crashing; repeatedly
    Firmware installation
    8
    37
    4.2k
      It's important that the wifi antenna is not shielded from radio waves. This is especially important if the printer is enclosed. On my delta, I have it poking through a slot in a plastic side panel. That same panel also provides access to the USB connector and SD card, and the LEDEs along that edge of the board can been seen through it.
      • MrBlomundefined
        MrBlom
        also having a lot of problem with wifi and the betas
        timo outs or can't connect
        start to get very frustrating
        Please prioritize this
        • Forgvn77undefined
          Forgvn77
          I am pleased to report that with the latest betas (Firmware 1.19beta10+2, WiFi Server 1.19beta9, and DWC 1.17+2) my Wifi and Ajax connection problems have largely gone away and I can connect and stay connected pretty reliably. This was a major problem for me the past month or so in previous releases and I was almost ready to bail it had gotten so unusable. Thanks for getting it fixed!
          Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
          Make A Difference!
          • BMMalundefined
            BMMal
            I'm also getting the following error on occasion now. Is this just due to less than great wifi too?
            A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
            Message: Uncaught TypeError: Cannot read property 'axesHomed' of undefined
            URL: http://10.0.0.115/js/dwc.js
            Line: 763:69
            Error object: {}
            I think I spoke too soon about my issue with disconnecting after files have been uploaded. Regardless of that, the beta firmware still seems more sensitive to changes in wifi strength than previous versions.
            Duet Ethernet - Most likely the most recent Edge firmware
            Duet X5
            7" Panel Due V2
            Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
            • Whitewolfundefined
              Whitewolf
              Hi everyone,
              I have something for you to try to see if it helps (it worked for me though DC42 does not know what change couldnhave lead to this)
              After upgrading to the beta versions i had the same issue, i could not stay connected. What I did and now rarely get disconnected is delete the DHCP lease from the router and reboot the router then readd the assigned ip via mac address and reboot again
              after doing this things have been much smoother.
              • BMMalundefined
                BMMal
                @Whitewolf:
                Hi everyone,
                I'll have to give that a try when our IT guy is in. Fortunately, I am building this machine for work. Unfortunately, I don't have much freedom to go and make changes to the network.
                I have updated to the 10+2 firmware and though it seems my wifi signal is maybe a little better, the issues still prevail.
                I'm also going to make a bracket and cut some holes to allow my wifi antenna to protrude through the wall of my control box.
                Duet X5
                7" Panel Due V2
                • BMMalundefined
                  BMMal
                  Was finally able to get an AP set up next to the machine. The WiFi signal is now -45dbm which has improved the stability of my connection when I am simply looking at the control screen and issuing manual commands.
                  When I try to go to the gcode files tab, the files will be greyed out and the connection is quickly dropped. If I attempt to upload a file through this interface, it usually fails to upload and drops the connection. However, using the "Upload and Print" button works alright. Even if the connection gets dropped, the machine starts the print and I can reconnect to see the status screen. This typically gets very unstable eventually as well and often ends up with me not being able to connect at all.
                  Additionally, it seems that some part of the Duet is having a difficult time computing the layer height, as it generally is never actually calculated and if it is, it calculates two, the second one is usually because I use a Z offset in the slicer, or maybe only one. I'm using the newest beta of Kisslicer. Is the Duet having difficulty in parsing information from files and causing these issues? If there is something I can test to help determine a cause please let me know.
                  Duet X5
                  7" Panel Due V2
                    BMMal, if you are running older beta firmware then please upgrade to the latest betas (DuetWiFiFirmware 1.19beta11, DuetWiFiServer 1.19beta10 and DWC 1.17+2). If after that you still have problems, here are some suggestions:
                    • another user reported that changing WiFi channel on the router made a big difference
                    • if you can capture a Wireshark trace of what happens when you try to get the Gcode files list, that may help us diagnose the problem.
                    HTH David
                    • BMMalundefined
                      BMMal
                      Thanks for the suggestion David. I will have to try changing the channel tomorrow. For now here is a couple wireshark captures.
                      https://www.dropbox.com/sh/lubl3jzp2jffil8/AAAafAxwGmdWUMUaJKus4bd2a?dl=0
                      Duet X5
                      7" Panel Due V2
                        BMMal, thanks for the captures. Are you running the latest betas as listed in my previous email?
                        It looks like it is having problems retrieving file info for file HandlePommel.gcode. Please can you put that file on Dropbox for me to try. Also, try deleting that file from the SD card, to see if it has the same problem on the next file.
                        • BMMalundefined
                          BMMal
                          David,
                          I believe I am running all of the newest available:
                          Firmware Name: RepRapFirmware for Duet WiFi
                          Firmware Electronics: Duet WiFi 1.0 + DueX5
                          Firmware Version: 1.19beta11 (2017-07-25)
                          WiFi Server Version: 1.19beta10
                          Web Interface Version: 1.17+2
                          I have added the file and another one to the Dropbox folder. I have noticed it producing similar error messages in the Repetier log (for several different files) when I resorted to using Repetier to start prints from SD because DWC was crashing so much and I did not have a Panel Due at the time. I am not using the SD card on the Panel Due. This issue has persisted after deleting, reuploading (if it works), or otherwise directly adding them to the card. Often times the behavior changes after resetting the board where the file name will be read but often the other statistics/info are still missing. Generally, after a reset the Panel Due can then see the file and start it but I often still cannot get the file to start from DWC. Thank you for the help!
                          Duet X5
                          7" Panel Due V2
                            Thanks. I've uploaded the file to one of my printers and DWC gets the file info over WiFi without difficulty. It failed to find the layer height because it was given too far down the file, so I've just fixed that in the forthcoming 1.19RC1 firmware.
                            • BMMalundefined
                              BMMal
                              By using a phone app to see which WiFi channel has the strongest signal, I was able to purposefully change it to broadcast on the strongest one. This boosted the Duet's signal from -45dbm to -25dbm. But this has not yet resolved my issue. For now I will probably wait until 1.19RC1 is released and see if that helps.
                              Duet X5
                              7" Panel Due V2
                              • BMMalundefined
                                BMMal
                                It seems that since I updated to 1.19 RC1 these poor behaviors have greatly improved and possibly disappeared.
                                Duet X5
                                7" Panel Due V2
