    Duet 3 6hc and expansion 3hc 12v io-7-9 and 6-8 no redout
    375
    • jsinicroundefined
      jsinicro @jsinicro
      jsinicroundefined 1 Reply Last reply Reply Quote 0
      • jsinicroundefined
        jsinicro @jsinicro
        • jsinicroundefined
          jsinicro @jsinicro
          • jsinicroundefined
            jsinicro @jsinicro
            • jsinicroundefined
              jsinicro @jsinicro
              @jsinicro still can't figure out why I am getting 12 volts out of the 4 pin header out 3 and 4 where the fan and pump are connected but on the 2 pin header out 6-8 not getting 12V? the picture above show the connections this is the expansion 3hc.
              • jsinicroundefined
                jsinicro
                @jsinicro this is consistent the same results on the main board
                • jsinicroundefined
                  jsinicro @jsinicro
                  @jsinicro Just wanted to point out the wiring diagram for the 3HC is labeled wrong taking there is no 2-pin out 7- out-9. it has to be according to the wiring picture out out-6,7,8
                  from the documentation:
                  Medium current/ 2 wire fan outputs
                  2-pin KK headers labelled OUT7 thru OUT9: these are intended for fans. Maximum recommended current 2.5A each. Flyback diodes are built-in to these outputs. (see note on 12V max current below)
                  • jsinicroundefined
                    jsinicro @jsinicro
                    @jsinicro new question?
                    the 2-pin KK headers, well there is only one on the 3HC this puts out v-fused which is 24 volts verified that, but what are the maximum amps?
                    • jsinicroundefined
                      jsinicro @jsinicro
                      @jsinicro that's all the documentation says:
                      2-pin KK headers labelled GND and V+: This is for powering an always-on fan or similar.
                      The documentation for the pumps say 823mA I have 2 but they are rated at 12V the set up that I have when I turn on power I have to unplug and plug one of them back in in order to have them working, which is not right as they are on 2 separate 3HC boards.
                      • jsinicroundefined
                        jsinicro @jsinicro
                        @jsinicro I will use the 24V and step it down to 12V
                        • jsinicroundefined
                          jsinicro @jsinicro
                          @jsinicro I suppose I could use the JST high amps step that down and connect both
