    Bltouch tuning - adjusting distance from trigger point to nozzle
    4.5k
    • ballanuxundefined
      ballanux
      I'm finishing tuning my DIY 3d printer (its a corexy based on BLV's design) with 3 independent z axis. I want to be able to do automatic bed leveling with the BLtouch.
      When I designed the BLtouch mounting I read the BLtouch manual and found the tip of the probe should be between 2.3 and 4.3mm over the nozzle so I designed it for 3mm as a nice round value.
      I have been doing the calibration procedure and ended up with a height difference of 2.8mm, so I put that on my G31 command of config.g
      When I test the full bed levelling procedure, always en up with the following message:
      Error: Some computed corrections exceed configured limit of 0.50mm: -5.000 -5.000 -5.000
      Reading the troubleshooting guide I found the following:
      The bottom of the BLTouch plastic shell must be 8mm+-0.5mm away from the nozzle tip to trigger properly.
      Which actually accounts exactly for the -5mm that the previous error gives... but I'm a bit reluctant to change the mounting height before checking with someone else... the bltouch manual seems quite clear and if I raise it by 5mm I don't know if it will actually trigger.
      I also don't want to raise the maximum correction sice it seems a bit excessive to have it at more than 5mm.
      Also, since the whole procedure is working fine, maybe it is just something that I'm missing in my configuration files...
      my z-probe section of config.g
      M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" H5 R0.2 F100 T6000        ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y20 Z2.800                       ; set Z probe trigger value, offset and trigger height
      my bed.g
      G28 ; home
      G30 P0 X15  Y20  Z-99999  ; probe near a leadscrew
      G30 P1 X150 Y290 Z-99999 ; probe near a leadscrew
      G30 P2 X285 Y20  Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
      Do I need to raise the probe by 5mm? or can I compensate for it in the configuration since the whole process seems to work except for the actual compensation?
      • fcwiltundefined
        fcwilt @ballanux
        @ballanux
        So does the probe, as mounted, meet the 8mm +/- 0.5mm requirement?
        Is it trigger correctly?
        Moving to Z=0 does the tip of the nozzle just touch (or almost touch) the bed?
        If you change the limit from 0.5mm (that's very small - mine is 3.0mm) does it work?
        ballanuxundefined 1 Reply Last reply Reply Quote 0
        • ballanuxundefined
          ballanux @fcwilt
          @fcwilt
          Thanks for the reply!
          No. If I understood that sentence, this is from the tip of the probe when its retracted to the nozzle tip, right? in that case I have about 3mm, which is what the BLTouch manual asks for:
          So I don't know where the 8mm comes from or if that depends on the BLTouch version. This is why I wanted to ask about it
          Yes, it triggers. During my initial testing I saw error messages of not triggering, but after I adgusted the bed height closer to the probe, it does trigger correctly
          Yes, I first of all adjusted manually the bed with a piece of paper, so I have about 50um of clearance between nozzle and bed
          I just tried and with 6mm as the limit it does, if that's OK I can leave it like that, but it seems strange that it gives me -5mm in all three points but when I do single point probing I can get 0.0mm as Z height wightous issue
          Leadscrew adjustments made: -5.000 -5.000 -5.000, points used 3, (mean, deviation) before (-5.000, 0.000) after (0.000, 0.000)
          So... with 6mm it seems to work, it is that to me it seemed too much and I don't know exactly where the 5mm difference comes from
          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @ballanux
            @ballanux
            Glad to hear it is working.
            Do you home the Z axis with the probe or Z endstops?
            Do you home before running the bed leveling?
            • ballanuxundefined
              ballanux
              @fcwilt
              I actually have both, I have endstops at the max Z and the probe at min Z.
              Yes, I do a homing before the bed leveling, I suppose the firmware doesn't allow otherwise.
              I'm still testing things and if possible trying to do a first print today, I think I will only use the Z probe if it works well.
                Phaedrux Moderator @ballanux
                @ballanux said in Bltouch tuning - adjusting distance from trigger point to nozzle:
                Yes it seems to vary for the version. Best to follow the manual for your version.
                https://www.antclabs.com/manual
                • ballanuxundefined
                  ballanux @Phaedrux
                  @phaedrux Thanks for the confirmation, it confused me quite a bit.
                  By the way, I'm doing my first test print now and while I still have some things to adjust I'm quite glad how everything is working
                  JayJayundefined 1 Reply Last reply Reply Quote 0
                  • JayJayundefined
                    JayJay @ballanux
                    @ballanux
                    the upto date documentation has all been changed (even on some of the older pdf's) I have documentation downloaded from antclabs here that shows that distance as being
                    8mm +/- 0.2mm
