    DuetLapse3
    Third-party software
    20
    296
    30.1k
    • JohnOCFIIundefined
      JohnOCFII
      Greetings -- My last couple of prints, I noticed that I wasn't getting my "extratime". The log told me that my version of ffmpeg didn't support it, even though it was the version I built locally on my Pi last December.
      pi@octocore:/opt/DuetLapse/octocore/railcore-localdomain $ more 15379_21-05-17T16ΛΈ40ΛΈ44.log
      2021-05-17 16:40:45,112 -
      2021-05-17 16:40:45,114 - ################### Options selected for this run #####################
      2021-05-17 16:40:45,114 - #Environment Settings:
      2021-05-17 16:40:45,115 - # printer         = railcore.localdomain
      2021-05-17 16:40:45,116 - # basedir         = /opt/DuetLapse
      2021-05-17 16:40:45,116 - # poll            = 5
      2021-05-17 16:40:45,117 - # logtype         = both
      2021-05-17 16:40:45,118 - # verbose         = False
      2021-05-17 16:40:45,118 - # os              = Linux
      2021-05-17 16:40:45,119 - # host            = 0.0.0.0
      2021-05-17 16:40:45,119 - # port            = 0
      2021-05-17 16:40:45,120 - # pid             = 15379
      2021-05-17 16:40:45,120 - # keeplogs        = False
      2021-05-17 16:40:45,121 - # novideo         = False
      2021-05-17 16:40:45,122 - # deletepics      = False
      2021-05-17 16:40:45,122 - # maxffmpeg       = 2
      2021-05-17 16:40:45,123 - # keepfiles       = False
      2021-05-17 16:40:45,123 - #Execution Setings:
      2021-05-17 16:40:45,124 - # dontwait        = False
      2021-05-17 16:40:45,125 - # seconds         = 0
      2021-05-17 16:40:45,126 - # detect          = layer
      2021-05-17 16:40:45,127 - # pause           = no
      2021-05-17 16:40:45,128 - # standby         = False
      2021-05-17 16:40:45,128 - #Camera1 Settings:
      2021-05-17 16:40:45,129 - # camera1         = web
      2021-05-17 16:40:45,130 - # weburl1         = http://octocore.localdomain:8081/snapshot
      2021-05-17 16:40:45,131 - # Video Settings:
      2021-05-17 16:40:45,132 - # extratime   =     4.0
      2021-05-17 16:40:45,133 - ###################################################################
      2021-05-17 16:40:45,432 -
      2021-05-17 16:40:45,433 - ************************************************************************************
      2021-05-17 16:40:45,434 - Warning: This version of ffmpeg does not support -extratime
      2021-05-17 16:40:45,434 - -extratime has been set to 0
      2021-05-17 16:40:45,435 - ************************************************************************************
      2021-05-17 16:40:45,758 -
      2021-05-17 16:40:45,759 - ###############################################################
      2021-05-17 16:40:45,760 - Connected to printer at railcore.localdomain using Duet version 3.3RC2 and API access using rr_model
      2021-05-17 16:40:45,761 - ###############################################################
      2021-05-17 16:40:45,762 -
      2021-05-17 16:40:45,763 - ##########################################################
      2021-05-17 16:40:45,764 - Will start capturing images on first layer change
      2021-05-17 16:40:45,764 - ##########################################################
      2021-05-17 16:40:45,765 -
      2021-05-17 16:40:45,766 -
      2021-05-17 16:40:45,767 - ##########################################################
      2021-05-17 16:40:45,767 - Video will be created when printing ends.
      2021-05-17 16:40:45,768 - On Linux   -  press Ctrl+C one time to stop capture and create video.
      2021-05-17 16:40:45,769 - On Windows -  Ctrl+C will NOT create a video. You must use the http listener
      2021-05-17 16:40:45,769 - ##########################################################
      2021-05-17 16:40:45,770 -
      even though the filter showing tpad was there:
      pi@octocore:/opt/DuetLapse $ ffmpeg -filters | grep tpad
      ffmpeg version git-2020-12-24-29cef1b Copyright (c) 2000-2020 the FFmpeg developers
        built with gcc 8 (Raspbian 8.3.0-6+rpi1)
        configuration: --extra-cflags=-I/usr/local/include --extra-ldflags=-L/usr/local/lib --extra-libs='-lpthread -lm -latomic' --arch=armel --enable-gmp --enable-gpl --enable-libass --enable-libdrm --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libssh --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-mmal --enable-nonfree --enable-omx --enable-omx-rpi --enable-version3 --target-os=linux --enable-pthreads --enable-openssl --enable-hardcoded-tables
        libavutil      56. 62.100 / 56. 62.100
        libavcodec     58.115.102 / 58.115.102
        libavformat    58. 65.100 / 58. 65.100
        libavdevice    58. 11.103 / 58. 11.103
        libavfilter     7. 94.100 /  7. 94.100
        libswscale      5.  8.100 /  5.  8.100
        libswresample   3.  8.100 /  3.  8.100
        libpostproc    55.  8.100 / 55.  8.100
       ... tpad              V->V       Temporarily pad video frames.
      I rebuilt ffmpeg again following the instructions in the GitHub pages, but other than seeing that I do have the new version, the log still shows that "Warning: This version of ffmpeg does not support -extratime"
      The extra time feature was working fine a couple of months ago.
      Any ideas, or places to check?
      Thanks,
      John
      stuartofmtundefined 1 Reply Last reply Reply Quote 0
      • stuartofmtundefined
        stuartofmt @JohnOCFII
        @johnocfii said in DuetLapse3:
        Let me take a look later today / tomorrow. Its entirely possible that I introduced some logic error in a later version. I did do some 'tidy up' so it could easily 'no good deed goes un-punuished'
        What version of DuetLapse3 are you on ? Sorry that you had to rebuild ffmpeg.
        JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
          stuartofmt @war4peace
          @war4peace said in DuetLapse3:
          But with me being a newbie at all Linux-things, I'm not sure about some basic things...
          Sorry - for some reason I did not get notification of your post (or I fat fingered it) and only now just saw your question.
          I'm tied up all day - but will give you a considered answer later today (if I can ) but more likely tomorrow. The good news is that its all possible and pretty straightforward BUT there are options πŸ™‚
          war4peaceundefined 1 Reply Last reply Reply Quote 0
            JohnOCFII @stuartofmt
            @stuartofmt said in DuetLapse3:
            I'm running 3.4.2. I was on 3.4.1 before that.
            John
              Do you mind trying 3.4.3. Looks like it was a silly mistake - but I do not have time to rigorously test at the moment.
              JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
                @stuartofmt sure - I'll try that soon.
                  @stuartofmt Worked great! https://youtu.be/vvtMgD2nNE0
                  • war4peaceundefined
                    war4peace @stuartofmt
                    @stuartofmt
                    No rush, I am still tuning and polishing a lot of things with my printer. Take your time πŸ™‚
                      @war4peace
                      Hi - I think the simplest approach (for now) is to run DuetLapse3.py using the linux systemctl capability.
                      I updated the instructions here:
                      https://github.com/stuartofmt/DuetLapse3/blob/main/systemctl setup.md
                      and added a sample unit file (.service extension) here:
                      https://github.com/stuartofmt/DuetLapse3/blob/main/DuetLapse3.service
                      Note that you want to make sure the options you have set are perfected by running DuetLapse3 from the command console, before you replicate these in the unit file.
                      Essentially - using this approach, DuetLapse3 will terminate normally at the end of each print job and then restart.
                      In particular - you likely (definitely) want to have -detect layer set. Otherwise - on restart of DuetLapse3, even if there is no print job running, it may start capturing images the entire time 😞
                        @stuartofmt
                        Thank you for your answer.
                        Here's my command line (tested to be working, located in a bash file, see below):
                        /usr/bin/python3 $PROCESS -duet localhost -basedir /home/pi/duetlapse/output -camera1 stream -weburl1 http://localhost:8181/stream -detect layer -seconds 10  -extratime 10 -instances oneip -deletepics -port 8282 &
                        I am trying to follow the instructions listed, but I have a couple questions.
                        In the document it says "This needs to be the directory for BOTH startDuetLapse3.py and DuetLapse3.py" - there is no "startDuetLapse3.py" file to be found.
                        Here's the full list of files in the DuetLapse folder:
                        pi@duet3:~/duetlapse $ find "$(pwd)"
                        /home/pi/duetlapse
                        /home/pi/duetlapse/duetlapse.sh
                        /home/pi/duetlapse/DuetLapse3.py
                        /home/pi/duetlapse/output/duet3
                        /home/pi/duetlapse/output/duet3/localhost
                        /home/pi/duetlapse/startDuetLapse3.service
                        As for starting DUetLapse, I am using a bash file with the following contents:
                        #! /bin/bash
                        #Example bash script for running DuetLapse3.py
                        PROCESS=/home/pi/duetlapse/DuetLapse3.py
                        case "$1" in
                           start)
                        #Edit and uncomment for your own needs
                        #One camera example
                        #  Two camera example
                        #/usr/bin/python3 $PROCESS -duet 192.168.86.235 -basedir /home/pi/Lapse -instances oneip -dontwait -seconds 3 -camera1 stream -weburl1 http://192.168.86.230:8081/stream.mjpg  -camera2 other -weburl2 http://192.168.86.230:8081/st$
                           stop)
                              if ["$2" == '']
                              then
                                  PROCESS_PID=`/bin/ps -ef | grep "$PROCESS" | grep -v "grep" | awk '{print $2}'`
                                  kill -2 $PROCESS_PID
                              else
                                  PROCESS_PID=`/bin/ps -ef | grep "$PROCESS" | grep "$2" | grep -v "grep" | awk '{print $2}'`
                             fi
                        esac
                        Can I use that bash script instead of startDuetLapse3.py?
                        I am a newbie in linux-world, sorry for the arguably stupid questions...
                        JohnOCFIIundefined stuartofmtundefined 2 Replies Last reply Reply Quote 0
                          JohnOCFII @war4peace
                          @war4peace The file startDuetLapse3.py can be found along with the rest of the DuetLapse files here: https://github.com/stuartofmt/DuetLapse3
                          It is fairly straightforward to replicate if needed.
                          John
                            I'll fix that - It should have read This needs to be the directory in which you have DuetLapse3.py installed. If you are using startDuetLapse3.py it will be in the same directory as DuetLapse3.
                            For your use-case, I would not use a bash script at all. The bash script was there to support a much earlier version, when the documentation was less complete. Since then the inbuilt capability together with startDuetLapse3 makes the bash script redundant (in most cases) . I will remove it as it no longer serves a purpose.
                            startDuetLapse3 is an administrative tool. Its use is optional but has many useful features - way beyond a bash script. It's accessible from a browser - so you can administer from more-or-less any local machine. I also use VPN to access it remotely πŸ™‚
                            If you want a single instance of DuetLapse3 running all the time - then you are better off using systemctl for that instance. The key lines in you unit file (given the info you provided) would look like this.
                            <snip>
                            WorkingDirectory=/home/pi/duetlapse
                            <snip>
                            ExecStart=python3 /home/pi/duetlapse/DuetLapse3.py -duet localhost -basedir /home/pi/duetlapse/output -camera1 stream -weburl1 http://localhost:8181/stream -detect layer -seconds 10 -extratime 10 -instances oneip -deletepics -port 8282
                            <snip>
                            Of course you can run additional ad-hoc instances if you like (e.g. through startDuetLapse3).
                            With that in mind - you may find -instances oneip too restrictive or redundant. The very first instance of DuetLapse essentially ignores this directive because there can be no conflict. Subsequent instances check already running instances for possible conflict based on their directive only. In other words these options are not global in their scope. With -instances oneip - you cannot have 2 or more instances connected to the same Duet. With -instances many, you can have many instances connected to the same (or different) Duets.
                              war4peace @JohnOCFII
                              @johnocfii
                              Thank you. I have followed the instructions, but receiving an error, see below:
                              pi@duet3:~/duetlapse $ sudo systemctl status startDuetLapse3.service
                              ● startDuetLapse3.service - startDuetLapse3 Service
                                 Loaded: loaded (/lib/systemd/system/startDuetLapse3.service; disabled; vendor preset: enabled)
                                 Active: failed (Result: exit-code) since Fri 2021-05-21 00:16:32 EEST; 6s ago
                                Process: 15508 ExecStart=/usr/bin/python3 startDuetLapse3.py -duet localhost -basedir /home/pi/duetlapse/output -camera1 stream -weburl1 http://localhost:8181/stream -detect layer -seconds 10 -extratime 10 -instances oneip -deletepics -port 8282 & (code=exited, status=2)
                               Main PID: 15508 (code=exited, status=2)
                              May 21 00:16:32 duet3 systemd[1]: startDuetLapse3.service: Service RestartSec=100ms expired, scheduling restart.
                              May 21 00:16:32 duet3 systemd[1]: startDuetLapse3.service: Scheduled restart job, restart counter is at 5.
                              May 21 00:16:32 duet3 systemd[1]: Stopped startDuetLapse3 Service.
                              May 21 00:16:32 duet3 systemd[1]: startDuetLapse3.service: Start request repeated too quickly.
                              May 21 00:16:32 duet3 systemd[1]: startDuetLapse3.service: Failed with result 'exit-code'.
                              May 21 00:16:32 duet3 systemd[1]: Failed to start startDuetLapse3 Service.
                                Just to be clear: Are you intending to start startDuetLapse3.py or DuetLapse3.py?
                                They are two separate programs startDuetLapse3 provides an administrative, browser-based UI for starting and managing DuetLapse3.py.
                                In any case:
                                1. You did not provide the full path name in the ExecStart command.
                                2. It looks like you want to start DuetLapse3.py. If that's the case - you are calling the wrong program.
                                3. If you intended to start startDuetLapse3.py then the command options have a different syntax due to some vagaries of how such things are passed by the operating system. See the documentation on startDuetLapse3 here (in particular the -args syntax):
                                  https://github.com/stuartofmt/DuetLapse3/blob/main/startDuetLapse3.md
                                  @stuartofmt
                                  Thank you again for your patience.
                                  Updated command line:
                                  ExecStart=/usr/bin/python3 /home/pi/duetlapse/startDuetLapse3.py -duet localhost -basedir /home/pi/duetlapse/output -camera1 stream -weburl1 http://localhost:8181/stream -detect layer -seconds 10  -extratime 10 -instances oneip -deletepics -port 8282
                                  Current status: service starts, then ends after a short while. Running "sudo systemctl status startDuetLapse3.service" immediately after starting the service shows it as running, but after a few seconds it exits. Must be something in the command line.
                                  I am now going through the manual for StartDuetLapse and will adjust accordingly.
                                  Will post updates once done.
                                  EDIT: It is working now.
                                  Thank you very much for your help, much appreciated!
                                    You need to have firmly in your mind which program you are dealing with Many of the options (because of the way you specified them) are incorrect for startDuetLapse3. (which is the program you are trying to start). You are using some options that only apply to DuetLapse3. This is wrong.
                                    If you stop startDuetLapse3
                                    sudo systemctl stop startDuetLapse3.service
                                    and then run the command you are trying to use
                                    you will see what I mean - you will get errors about the options that you are trying to use.
                                      @stuartofmt
                                      Understood.
                                      Confusion cleared.
                                      Later Edit I apologize, I was busy at the moment and now realized my answer was too brief.
                                      As I had said, β€žI am now going through the manual for StartDuetLapse and will adjust accordingly.” Which I did, used the "args=" parameter as specified in the manual and everything is in order now.
                                        Excellent !! I do have a newer version of start DuetLapse3 coming out in a couple of days. Minor tweaks and corrections. Nothing that will cause a change in arguments or setup. A simple file replacement.
                                          stuartofmt
                                          Its been a while -- I've made updates to both DuetLapse3 and startDuetLapse3.
                                          Included in the documentation are instructions on using DuetLapse3 with the Pi camera on Buster.
                                          Version 3.5.0
                                          Remember to keep DuetLapse3 and startDuetLapse3 at the same release levels
                                          Changes to DuelLApse3
                                          • [1] Changed some system calls to allow for better error handling.
                                          • [2] Fixed an issue with sending gcodes to SBC
                                          • [3] Improved the handling of -pause yes and - movehead
                                          • [4] Added an optional argument -rest that delays image capture after a pause. This is because the camera feed can be delayed with respect to the actual head position.
                                          • [5] Updated documentation with additional notes
                                          • [6] Deprecated the use of -camera pi due to changes in Raspberry Pi (see notes in the section on -camera).
                                          • [7] Added a new argument -nolog and deprecated -logtype. Logging will always use the console unless the program is running in the background.
                                          • [8] If -verbose is used, much more detail is created. Should usually only be used for debugging.
                                          • [9] Added new argument -fps. Sets the default frames-per-seconds
                                          • [10] Added the ability to change the default frames-per-second (fps) from the main menu.
                                          • [11] Added a new argument -hidebuttons. Hides menu buttons that are currently invalid. Otherwise, invalid buttons are greyed out.
                                          • [12] General UI improvements.
                                          • [13] After Snapshot, returns to the previous logical state either 'start' or 'pause'
                                          Changes to startDuetLapse3
                                          • [2] Updated documentation with additional notes
                                          • [3] Added a default logfile (startDuetLapse3.log)
                                          • [4] Added a new argument -nolog. Logging will always use the console unless the program is running in the background.
                                          • [5] Added a new argument -verbose. Creates detailed debugging information.
                                          • [6] Failure to start DuetLapse3 (from the UI) is reported with reasons. Successful starts are reported after 30 seconds.
                                          • [7] Shutdown, from the UI, requires confirmation.
                                          • [8] The use of http option nohup=yes is deprecated.
                                          • [10] Added the ability to change the default frames-per-second (fps) when creating a video from the files menu.
                                          • [11] General UI improvements.
                                            stuartofmt
                                            I am please to announce the release of version 4.0.0
                                            It has a number of changes, the most significant being the ability to control DuetLapse3 with gcode.
                                            Controlling DuetLapse3 with gcode
                                            The program, among other things, monitors messages generated with the gcode M117 command.
                                            Two message forms will cause the program to react.
                                            • [1] M117 DuetLapse3.(x) where (x) is one of the allowed settings.
                                            • [2] M117 (execkey) (command) where (execkey) is a prefix specified by the -execkey option and (command) is an arbitrary command that will be sent to the OS.
                                            M117 gcode messages can be embedded in the print file, placed in a macro, or sent from the DWC console.
                                            Note that as a practical matter, This functionality assumes a single instance of DuetLapse3 connected to a single printer.
                                            DuetLapse3 uses a polling method and checks the printer every 5 seconds for M117 messages.<br>
                                            To prevent a message being missed, IT IS MANDATORY that a delay (G4) be added after every M117 message intended for this program.
                                            The strong recommendation is that the delay is 10 seconds i.e. G4 S10
                                            M117 DuetLapse3.(x)
                                            In the first form, the following settings are available:
                                            start, standby, pause, continue, restart, snapshot, completed, graceful, forced
                                            These correspond to the same actions in the UI.<br>
                                            Note that terminate is not supported instead use graceful or forced depending on your need.
                                            There is also a special variant which can be used to change options on-the-fly.
                                            This is equivalent to setting an option in the command line at startup.
                                            M117 DuetLapse3.change.(variable)=(value)
                                            G4 S10
                                            The following variables are supported:<br>
                                            verbose, seconds, poll, detect, dontwait, pause, restart, novideo, keepfiles, minvideo, extratime, fps, rest , execkey
                                            Examples
                                            M117 DuetLapse3.standby # Will place the program into standby
                                            G4 S10
                                            M117 DuetLapse3.start # Will start capturing image
                                            G4 S10
                                            M117 DuetLapse3.change.verbose=False #  will turn of verbose output
                                            G4 S10
                                            M117 DuetLapse3.change.seconds=20 # Will capture an image every 20 seconds
                                            G4 S10
                                            This form allows an arbitrary command to be executed by the operating system.
                                            The character sequence specified by -execkey is used to identify the command.
                                            For example if -execkey was :do: the following message will attempt to run test.sh
                                            M117 DuetLapse3 :do: ./test.sh "hello world"
                                            G4 S10
                                            Note: There are no additional single or double quotes used in the M117 gcode.
                                            The command portion is presented as it would be from the command line of the relevant OS.
                                            Test Example
                                            This example demonstrates controlling DuetLapse3 using M117 messages.
                                            It does not print anything but simulates a small print job.
                                            DuetLapse3. messages are both inline (in the gcode) and called inside a macro.
                                            Copy the following file to your printer job folder:
                                            M117Test.gcode
                                            and this file to the macro folder:
                                            test_job_settings.g
                                            Optionally (Linux only) create a file test.sh in the DuetLapse3 directory.
                                            #!/bin/bash
                                            echo "-----------"
                                            echo "$1 $2"
                                            echo "----------"
                                            Don't forget to make the file executable:
                                            chmod + x ./test.sh
                                            Start DuetLapse3 with the following suggested options, in addition to those needed for -duet and -camera:
                                            -restart -verbose -standby -keepfiles
                                            Note
                                            • [1] The use of M117 DuetLapse3.standby early in the print job (in the macro) to prepare for capture.
                                            • [2] The use of M117 DuetLapse3.start to control when capture will start.
                                            • [3] The use of M117 DuetLapse3.complated to indicate when capture will stop.
                                            Placement of these options allows fine control over the timelapse. This is especially useful if -restart is used and DuetLapse3 is running continuously.
                                            Macros can be especially useful if running DuetLapse3 continuously.
                                            You could (for example) having a standard set of options that are called at the end of each print job and specific macros (layer only, layer and time, time only, different -second settings etc.) for certain type of timelapse.
                                            Embedding these macro calls from your slicer makes easy use of this functionality.
