Toolboard LC1- v1.1 & Warrenty ?
This post is deleted! -
@arnold_r_clark Warranty terms here: https://www.duet3d.com/warranty
In the case of the LC1 v1.1, it is anticipated that people will make use of the feature to add a switch. If a board failure is demonstrably NOT related to the small amount of work on the board to enable the switch, I think we would generally look favourably on replacement. However, if, for example, it fails due to a short through the switch you added, it would not be covered.
@arnold_r_clark Yes you are correct the warranty policy was written before we shipped a product with an unpopulated footprint designed to allow a customer to add the component.
I have modified the warranty policy with a specific exception and will look to get the documentation updated as soon as possible.
In the future if we do this with any other product then I will look to expand the warranty policy to more generic wording.
@Arnold_R_Clark updated the documentation with some pictures:
https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board?revisionid=HEAD#Section_Adding_an_IO_3_Switch
