    Proud to have an Duet3 6HC ! But is not working
    Firmware installation
    774
    • uneumann36undefined
      uneumann36
      Thank you , here is my config. :
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 20 2021 07:20:18 GMT+0200 (Mitteleuropäische Sommerzeit)
      G21 ; Units in mm (mm)
      M550 P"Ender 5 Duet 3" ; set printer name
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.3 S0 ; physical drive 0.3 goes backwards
      M569 P0.4 S0 ; physical drive 0.4 goes backwards
      M569 P0.5 S0 ; physical drive 0.4 goes backwards
      M584 X0.0 Y0.1 Z0.2 E0.3:0.4:0.5 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E422.76:422.76:422.76 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X5000.00 Y5000.00 Z250.00 E4000.00:4000.00:4000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z250.00 E3000.00:3000.00:3000.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1000:1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X220 Y220 Z300 S0 ; set axis maxima
      M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in" ; configure active-low endstop for low end on Y via pin io2.in
      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H1 ; enable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M307 H1 R3.650 C118.5 D4.66 S1.00 V23.8 ; disable bang-bang mode for heater and set PWM limit
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
      M950 F2 C"out6" Q500 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 H2:3 L0.15 X1 B0.3 T35:45 ; set fan 2 value
      M563 P1 D1 H1 F0 ; define tool 1
      M563 P2 D2 H1 F0 ; define tool 1
      G10 P2 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P2 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
        uneumann36
        And here my tfree , tpost and tpre datas :
        ; tfree0.g
        ; called when tool 0 is freed
        M83 ; relative extruder mode
        G1 E-40 F8000 ; retract 40mm
        ; tpost0.g
        ; called after tool 0 has been selected
        M116 P0 ; wait for tool 0 only to reach operating temperature
        G1 E40 F8000 ; undo retraction
        ; tpre0.g
        ; called before tool 0 is selected
          uneumann36
          I hope my self adjusted settings are ok.
            droftarts administrators @uneumann36
            @uneumann36 A couple of comments:
            You don't need to enable the pullup resistor on the Duet 3. Remove ^ from the above line.
            You are using the default thermistor settings. What hotend are you using for the 3-into-1? Check what thermistor it comes with, and change the M308 line accordingly for better temperature accuracy.
            For the bed thermistor, I think the Ender 5 uses the Marlin default thermistor 1 setting (100k Epcos). Change the B value in the M308 line for the heated bed to B4092.
            I can't comment on your tool change macros; 3-into-1 hot ends often require a lot of tuning to get the filament change smooth.
            uneumann36undefined 1 Reply Last reply Reply Quote 1
              uneumann36 @droftarts
              @droftarts
              Thank you very much for your advise.
              What do you mean with :
              You are using the default thermistor settings. What hotend are you using for the 3-into-1? Check what thermistor it comes with, and change the M308 line accordingly for better temperature accuracy. ?
              It is the same like origin in Ender5
              Or do i understand something wrong?
                @uneumann36 The default setting for thermistors in the RepRapFirmware configuration tool is B4138. I don't think anyone uses this thermistor any more.
                I think some Ender 5 come with E3D hot end. If yours is standard, then like the bed, change the B value in the M308 line for the hot end to B4092.
                uneumann36undefined 1 Reply Last reply Reply Quote 0
                  uneumann36
                  Perfect, i will try this in the evening.
                  Thank you
                    @droftarts
                    Hi
                    So i try your advise.
                    About the thermistors , all settings are good.
                    But when i delete the Line :
                    Then the BLT is not working and DWC show the failure :
                    G28 Z
                    Error: in file macro line 8: G30: Z probe 0 not found
                    Error: Homing failed
                      @uneumann36 I didn’t say to delete the line, just delete the ^ character! So line should be:
                      M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                        @droftarts
                        Oh sorry,
                        Then I got it wrong
                        Thank you
                        Works well
