    Proud to have an Duet3 6HC ! But is not working
    Firmware installation
    774
    • uneumann36undefined
      uneumann36
      First,
      Thank you very mich for your advise to buy an Duet3 6HC Board.
      Ist is wonderful , really great developed 👍
      @Phaedrux
      You are really a cool guy! Everytime you help me succesful.
      I am Not an expert in Programming, so Jesus , ist Takes 2 Full days to keep my new Duet3 Printer working.
      Based on an Ender 5 , with an 3 in 1 out hotend.
      Not everything is working , and i have to tune and fine adjustment.
      Thank you again to all of you.
      There is only one thing what i Wang to asked you,
      Can i post my config datas, that someone of you have a look on it if i can use my Printer with this settings?
        Phaedrux Moderator @uneumann36
        @uneumann36 said in Proud to have an Duet3 6HC ! But is not working:
        Yes you can share your files and we can take a look.
          uneumann36
          Thank you , here is my config. :
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 20 2021 07:20:18 GMT+0200 (Mitteleuropäische Sommerzeit)
          G21 ; Units in mm (mm)
          M550 P"Ender 5 Duet 3" ; set printer name
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0.1 S0 ; physical drive 0.1 goes backwards
          M569 P0.3 S0 ; physical drive 0.3 goes backwards
          M569 P0.4 S0 ; physical drive 0.4 goes backwards
          M569 P0.5 S0 ; physical drive 0.4 goes backwards
          M584 X0.0 Y0.1 Z0.2 E0.3:0.4:0.5 ; set drive mapping
          M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00 E422.76:422.76:422.76 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X5000.00 Y5000.00 Z250.00 E4000.00:4000.00:4000.00 ; set maximum speeds (mm/min)
          M201 X1500.00 Y1500.00 Z250.00 E3000.00:3000.00:3000.00 ; set accelerations (mm/s^2)
          M906 X1200 Y1200 Z1200 E1000:1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X220 Y220 Z300 S0 ; set axis maxima
          M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin io0.in
          M574 Y1 S1 P"io1.in" ; configure active-low endstop for low end on Y via pin io2.in
          M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
          M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
          M307 H1 ; enable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
          M307 H1 R3.650 C118.5 D4.66 S1.00 V23.8 ; disable bang-bang mode for heater and set PWM limit
          M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
          M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
          M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
          M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
          M950 F2 C"out6" Q500 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 H2:3 L0.15 X1 B0.3 T35:45 ; set fan 2 value
          M563 P1 D1 H1 F0 ; define tool 1
          M563 P2 D2 H1 F0 ; define tool 1
          G10 P2 X0 Y0 Z0 ; set tool 1 axis offsets
          G10 P2 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
            uneumann36
            And here my tfree , tpost and tpre datas :
            ; tfree0.g
            ; called when tool 0 is freed
            M83 ; relative extruder mode
            G1 E-40 F8000 ; retract 40mm
            ; tpost0.g
            ; called after tool 0 has been selected
            M116 P0 ; wait for tool 0 only to reach operating temperature
            G1 E40 F8000 ; undo retraction
            ; tpre0.g
            ; called before tool 0 is selected
              uneumann36
              I hope my self adjusted settings are ok.
                droftarts administrators @uneumann36
                @uneumann36 A couple of comments:
                You don't need to enable the pullup resistor on the Duet 3. Remove ^ from the above line.
                You are using the default thermistor settings. What hotend are you using for the 3-into-1? Check what thermistor it comes with, and change the M308 line accordingly for better temperature accuracy.
                For the bed thermistor, I think the Ender 5 uses the Marlin default thermistor 1 setting (100k Epcos). Change the B value in the M308 line for the heated bed to B4092.
                I can't comment on your tool change macros; 3-into-1 hot ends often require a lot of tuning to get the filament change smooth.
                uneumann36undefined 1 Reply Last reply Reply Quote 1
                  uneumann36 @droftarts
                  @droftarts
                  Thank you very much for your advise.
                  What do you mean with :
                  You are using the default thermistor settings. What hotend are you using for the 3-into-1? Check what thermistor it comes with, and change the M308 line accordingly for better temperature accuracy. ?
                  It is the same like origin in Ender5
                  Or do i understand something wrong?
                    @uneumann36 The default setting for thermistors in the RepRapFirmware configuration tool is B4138. I don't think anyone uses this thermistor any more.
                    I think some Ender 5 come with E3D hot end. If yours is standard, then like the bed, change the B value in the M308 line for the hot end to B4092.
                    uneumann36undefined 1 Reply Last reply Reply Quote 0
                      uneumann36
                      Perfect, i will try this in the evening.
                      Thank you
                        @droftarts
                        Hi
                        So i try your advise.
                        About the thermistors , all settings are good.
                        But when i delete the Line :
                        Then the BLT is not working and DWC show the failure :
                        G28 Z
                        Error: in file macro line 8: G30: Z probe 0 not found
                        Error: Homing failed
                          @uneumann36 I didn’t say to delete the line, just delete the ^ character! So line should be:
                          M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                            @droftarts
                            Oh sorry,
                            Then I got it wrong
                            Thank you
                            Works well
