    Z Axis Homing ..
    4.3k
    • Sinkundefined
      Sink
      Perfect ..
      Thanks again ..
      • krzakuundefined
        krzaku
        If I may join in on this, I'm having troubles with Z homing too. I have an NPN NO inductive sensor connected to the E0 endstop header, I did what it says in the link @dc42 sent, but when I send G30 (no parameters, but I also tried the current X/Y, with no difference) the head moves to 0/0 AND BEYOND, mashing the Y axis and grinding the belt. This is after I homed the X/Y axis of course. Version 1.19RC5.
        • number40fanundefined
          number40fan
          ; Z homing file for Prusa i3 or similar printer using a Z probe for Z homing
          You have a switch, right?
          • krzakuundefined
            krzaku
            Yes, but the Z probe is configured in mode 4, switch mode, as per instructions in the wiki.
              number40fan
              Ok, just wanted to make sure that wasn't the issue. Does the switch change when you run M119? Is there a difference in the Homing files between switch and probe? I haven't looked at the wiki for your particular printer.
                number40fan
                G91
                G1 Z5 F200
                ;G1 X100 Y100 F9000
                ;G30
                ; Un-comment the following line if you want the head to actually move to Z=0 after homing
                G1 Z-200 S1 F100 ; move Z down until the switch triggers
                G90 ; back to absolute mode
                G92 Z0.3 ; tell the firmware that we are at Z=0.3mm
                What happens if you try this?
                  number40fan
                  Sorry, krzaku, thought I was talking with the OP.
                  • krzakuundefined
                    krzaku
                    G1 S1 for Z axis doesn't work, because the Z probe is not connected to the Z endstop port, but to the E0 endstop.
                      Actually it will work if you include the Z1 parameter in the M558 command and Z0 in the M574 command, because then the Z probe will be used as the Z endstop too. However, that's not what you should be doing; if you want to home Z using a Z probe you should use G30 not G1 S1.
                      • krzakuundefined
                        krzaku
                        That's exactly what I've been doing, and it's grinding the belt like I said. According to the wiki, G30 with no parameters shouldn't move the head at all. I also tried G29, and it goes to the same position at the start as G30, grinding the belt as well.
                          G30 with no parameters will move the head down until the Z probe triggers.
                          Have you tested the Z probe? i.e. gradually lower the head towards the bed ands watch the Z probe reading in DWC. For a switch-type Z probe, the reading will change from 0 to 1000 when the probe triggers.
                          • krzakuundefined
                            krzaku
                            But it shouldn't move the head in the X/Y axis, should it? And yes, the probe is working for sure. I also tried it in switch mode, connecting it to the Z endstop header, and homing (with G1 S1) worked fine then. Even if the probe wasn't working, it wouldn't explain why the carriage mashes the Y axis and tries to go beyond while grinding the belt.
                              G30 with no parameters should not move the head in the XY plane. Are you finding that it does? If so, please let us know which firmware version you are running, what commands you are sending prior to G30, and post your config.g file.
                                deckingman
                                The G30 moving in X and Y sounds awfully like deploy probe is being run. That's exactly what I ran into when upgrading to one of the 1.19 releases (can't remember which one) and I should have read the release notes which state that the deploy and retract probe files should be deleted from .sys. Once I deleted those files (in accordance with the release notes), G30 worked as expected.
                                • krzakuundefined
                                  krzaku
                                  @deckingman that's it! Removing those files fixed my issue. I skimmed over the release notes, when I should've read them more closely…
