    Firmware 1.19RC5 released - last chance to report issues
    Firmware installation
    17
    73
    8.2k
    • Kulitorumundefined
      Kulitorum
      RC5 seems to be ok for me.
      Where do I find the debug information? - I see no difference in the console when enabling debugging for all modules.
      Regarding the requested tool change gcode, here you go:
      G1 X116.118 Y109.931 E5.6070
      G1 X119.931 Y106.118 E5.8007
      G1 X116.537 Y106.118 E5.9226
      G1 X116.118 Y106.537 E5.9439
      G92 E0
      G1 E0.0000 F600
      G1 Z1.280 F9000
      ; process Tool 0
      ; layer 8, Z = 0.780
      G1 z0.780
      T0
      ; tool H0.200 W0.480
      ; inner perimeter
      G1 X115.720 Y125.720 F4500
      G1 Z0.780 F9000
      G1 E0.0000 F600
      G92 E0
      G1 X134.280 Y125.720 E0.6667 F2250
      G1 X134.280 Y144.280 E1.3334
      G1 X115.720 Y144.280 E2.0001
        Debug info is sent to the USB port only.
          Kulitorum, thanks for your feedback. I'll assume that the slow homing issue you reported with a previous RC is fixed now.
          Nobody else has reported any issues with RC5, so I'll assume that no news is good news. Expect a 1.19 release in the next day or two.
          • sigxcpuundefined
            sigxcpu
            OK, I am ready to try again 1.19, but I fail to find "the important upgrade notes". There are references in "what's new" page, but there is no actual link.
              Kulitorum
              Is there any way to set the speed of a G1 P1 command?
                T3P3Tony administrators
                @sigxcpu:
                its here:
                https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta
                  Kulitorum
                  Also, any positive movement with my U axis, with S1 defined ignores any F data and just runs at full speed. RC5
                    @sigxcpu:
                    Upgrade notes are always in the WHATS_NEW file in the root of my RepRapFirmware github repository, as linked to in the first post in this thread. If you look past the list of new features (which is rather long for this release) and the list of bug fixes, you will find the upgrade notes.
                      @Kulitorum:
                      The P parameter is just a modified for the G1 command, so the speed of movement is set by the F parameter as usual.
                        @Kulitorum:
                        Can you confirm that you have a space character in the command string immediately before the letter F ?
                        • DjDemonDundefined
                          DjDemonD
                          I don't know if it helps but the issue I reported under RC1 (in that thread) on my corexy with the duet board crashing and trying to send information to the USB was still happening earlier today. I upgraded to RC5 and it is working normally. Many thanks for all the hard work.
                          www.precisionpiezo.co.uk
                            Thanks for the feedback! Good to know that it is fixed.
                              Kulitorum
                              Yes, there is a space.
                              U at 211:
                              G1 U300 F100 S1
                              https://www.youtube.com/watch?v=Zy6cDdJbkhY
                              • sigxcpuundefined
                                sigxcpu
                                @dc42:
                                @sigxcpu:
                                That is what happens when you read the first two paragraphs of that huge page 🙂
                                Did the upgrade, everything looks fine. No real print yet (CoreXY 300x300x300)
                                  @Kulitorum:
                                  U at 211:
                                  G1 U300 F100 S1
                                  I still can't reproduce this. Please can you give me the exact sequence you are using from power on to make this happen.
                                  There are a few things not quite right with your config and homing files, although I don't think they are relevant to this issue, but please try them anyway:
                                  • In your M574 command in config.g you should have U2 not U1 because the U endstop is at the high end
                                  • In your M208 S0 command the U parameter should be the point at which the endstop switch triggers
                                  • The G1 S1 commands in your homing files should be executed in relative mode. For example, homex.g:
                                  ; homex.g
                                  ; called to home the X axis
                                  ; generated by RepRapFirmware Configuration Tool on Wed May 17 2017 18:05:05 GMT+0200 (Romance Daylight Time)
                                  ; Lift Z relative to current position
                                  G91
                                  G1 Z1 F6000
                                  ; Move quickly to X axis endstop and stop there (first pass)
                                  G1 X-255 F3000 S1
                                  ; Go back a few mm
                                  G1 X5 F3000
                                  ; Move slowly to X axis endstop once more (second pass)
                                  G1 X-10 F360 S1
                                  ; Lower Z again
                                  G1 Z-1 F6000
                                  G90
                                  Homeu.g:
                                  ; homeu.g
                                  ; called to home the U axis
                                  G91
                                  G1 Z1 F6000
                                  G1 U370 F6000 S1
                                  ; Go back a few mm
                                  G1 U-5 F6000
                                  G1 U10 F360 S1
                                  ; Lower Z again
                                  G1 Z-1 F6000
                                  G90
                                  [Edited the above to make somie corrections to homeu.g]
                                  You don't need the G92 commands as long as you have set the U axis maximum in your M208 command to the point at which the switch triggers.
                                  Also the zip file you provided had an old version of iap4e.bin in it.
                                    Kulitorum
                                    I applied your changes, and it made no difference.
                                    So I made a test.gcode file with one line:
                                    G1 U400 F2000 S1 ; test
                                    And when I "Emergency stop" and print that file, it runs at full speed.
                                    But when I "Emergency stop" and paste the same line "G1 U400 F2000 S1 ; test" into "Send Gcode" field in the top left of the web interface, it runs at the requested speed.
                                    Until I press "-100" for the U axis (executes correctly) and then press "Send" again - then it runs at too high speed.
                                    I hope this makes sense.
                                    • chrishammundefined
                                      chrishamm administrators
                                      To those testing this firmware release: I have just pushed DWC 1.19-RC1 to my GitHub repository, see https://github.com/chrishamm/DuetWebControl/tree/dev
                                      If you decide to try it out and find any bugs, please report them here or open a new issue on my GitHub page.
                                      Duet software engineer
                                        Kulitorum
                                        Chrishamm, I installed it, and so far it works fine. Where can I find a "What's new" file?
                                          @Kulitorum:
                                          I don't include a "Whats new" file with my DWC releases yet, but you can find all the changes in the commit message on GitHub: https://github.com/chrishamm/DuetWebControl/commit/fa10a75ab8b9003d3faced9c9d2db448ad150a62
                                          0 chrishamm committed to chrishamm/DuetWebControl
                                          Version 1.19-RC1
                                          Added message box controls for XY axes
                                          Implemented new "Mix" option on the extrude/retract panel
                                          Bug fix: After reconnecting the active message box was not displayed
                                          Bug fix: Sometimes the current tool was not underlined
                                          Bug fix: ABC axes weren't displayed properly
                                          • whosrdaddyundefined
                                            whosrdaddy
                                            @Chrishamm, did you see my pull request?
                                            I added dutch translation for DWC.
                                            Will crosscheck with 1.19 to see if additional strings have been added.
