    Help needed setting up BL touch
    676
    • Michael Hathawayundefined
      Michael Hathaway
      I need help setting up a BL touch on my Pulse. I know that this has been posted to death. I have exhaustively searched more than a week before posting for help. I would really appreciate any help pushing me further in the right direction.
      Errors:
      If I send G29 starts probe downward, stops about 30mm down and deploys probe.
      Error: Z probe already triggered before probing move started
      G28 Error: Z probe already triggered before probing move started
      Config.g
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 23 2021 16:36:21 GMT-0700 (Pacific Daylight Time)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Pulse E-423S"                               ; set printer name
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0.0 S0                                       ; physical drive 0.0 goes backwards
      M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
      M569 P0.2 S0                                       ; physical drive 0.2 goes backwards
      M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E409.00                  ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X1080000.00 Y1080000.00 Z90000.00 E15000.00   ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E1000.00               ; set accelerations (mm/s^2)
      M906 X1000 Y1200 Z1200 E1200 I40                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M208 X0 Y0 Z0 S1                                   ; set axis minima
      M208 X250 Y220 Z210 S0                             ; set axis maxima
      M574 X1 S1 P"io5.in"                               ; configure active-high endstop for low end on X via pin io5.in
      M574 Y1 S1 P"io6.in"                               ; configure active-high endstop for low end on Y via pin io6.in
      M574 Z1 S1 P"io2.in"                               ; configure active-high endstop for low end on Z via pin io2.in
      M307 H3 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
      M950 S0 C"io3.out"                                 ; create servo pin 0 for BLTouch
      M558 P9 C"io3.in" H10 F120 T600                    ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X23 Y10 Z15                               ; set Z probe trigger value, offset and trigger height
      M557 X20:230 Y20:200 S20                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4066       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 A421.6 C860.4 D14.2 S1.00 V24.0 B0         ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                            ; map heated bed to heater 0
      M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4066       ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 R2.648 C163.1:161.1 D6.32 S1.00            ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S315                                       ; set temperature limit for heater 1 to 315C
      ; M950 F0 C"out3" Q500                               ; create fan 0 on pin out3 and set its frequency
      ; M106 P0 C"PartCool" S0 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out4" Q500                               ; create fan 1 on pin out4 and set its frequency
      M106 P1 C"HotEnd" S1 H1:0 T35                      ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"out5" Q500                               ; create fan 2 on pin out5 and set its frequency
      M106 P2 C"CaseFan" S1 H1:0 T35                     ; set fan 2 name and value. Thermostatic control is turned on
      M563 P0 S"Hotend" D0 H1 F0                         ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings
      M280 P0 S160					                   ; Clear any alarms
      M402							                   ; Retract pin just in case
      T0                                                 ; select first tool
      ; homeall.g
      ; called to home all axes
      G1 H2 Z0 F1800          ; lift Z relative to current position
      G1 H1 Z-215 F1800       ; move Z down stopping at the endstop
      G1 H1 X-255 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F1800       ; go back a few mm
      G1 H1 X-255 Y-225 F360  ; move slowly to X and Y axis endstops once more (second pass)
      ; G1 H1 Z-215 F360      ; move Z down stopping at the endstop
      G90                     ; absolute positioning
      G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
      G30                     ; home Z by probing the bed
      ; Custom settings
      ; G91                    ; relative positioning
      ; G1 Z10 F100            ; lift Z relative to current position
      ; G90                    ; absolute positioning
      ; homez.g
      ; called to home the Z axis
      G1 H2 Z0 F6000   ; lift Z relative to current position
      G1 H1 Z-215 F1800 ; move Z down until the endstop is triggered
      RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus Ethernet (standalone mode)
      Board ID: AMDTD-5396U-D65J0-40KM2-2N03Z-7RVW6
      Used output buffers: 1 of 40 (12 max)
      Static ram: 98732
      Dynamic ram: 102564 of which 60 recycled
      Never used RAM 43860, free system stack 150 words
      Tasks: NETWORK(ready,172) ETHERNET(blocked,566) HEAT(blocked,311) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,353) TMC(blocked,97) MAIN(running,440) IDLE(ready,20) AIN(blocked,260)
      Owned mutexes:
      Last reset 00:05:52 ago, cause: software
      Last software reset at 2021-05-27 18:45, reason: User, GCodes spinning, available RAM 43860, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      Supply voltage: min 0.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 1360, standstill, SG min/max 0/38, read errors 0, write errors 1, ifcnt 27, reads 50327, writes 12, timeouts 31, DMA errors 0, failedOp 0x6a
      Driver 1: position 800, standstill, SG min/max 0/32, read errors 0, write errors 1, ifcnt 27, reads 50336, writes 12, timeouts 22, DMA errors 0, failedOp 0x41
      Driver 2: position 10000, standstill, SG min/max 0/16, read errors 0, write errors 1, ifcnt 27, reads 50357, writes 12, timeouts 1, DMA errors 0, failedOp 0x71
      Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 50360, writes 9, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 50361, writes 9, timeouts 0, DMA errors 0
      Driver 5: position 0, assumed not present
      Driver 6: position 0, assumed not present
      Date/time: 2021-05-27 18:50:54
      Cache data hit count 644379875
      Slowest loop: 7.96ms; fastest: 0.11ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 1.9ms, write time 2.0ms, max retries 0
      DMs created 83, maxWait 5641ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 5, completed moves 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 32.19ms; fastest: 0.03ms
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages queued 3177, send timeouts 3174, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
      My Z endstop is temporary, I removed inductive probe.
      I can post anything else needed.
      Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
      www.MatterHackers.com - https://discord.gg/Ked7GREqux
        You've got a Z endstop defined as well as the probe. Are you intending to use both? Having a Z max endstop can be handy on i3 style printers.
        There's a few issues with your files.
        @tinken said in Help needed setting up BL touch:
        Not needed in RRF3. Remove it.
        15mm seems highly unlikely for a BLTouch trigger height. It should be closer to 2mm, and should be measured. The 10mm dive height is also a bit much. Try M558 H5 instead. Part of the problem may be that the trigger height is larger than the dive height.
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
        In your homing files you have a endstop homing move in addition to the G30 probe command. Best to just remove the endstop part entirely.
        Remove that in homeall/homez and replace it with
        G1 X150 Y150 F6000 ; move probe to center of bed
        G30
        I can't really tell from your photos how it;s wired up but it should look like this:
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87#s336
        Michael Hathawayundefined 1 Reply Last reply Reply Quote 1
          Michael Hathaway @Phaedrux
          @phaedrux Thank you very much for helping me.
          I do plan on keeping my Z-axis end stop, but I have reengineered the stop for a microswitch.
          I have changed everything you have recommended. My wiring is exactly like the image you have posted. Except, I did have a bad crimp on io3.in. This has been resolved.
          Now, send G29. The hotend moves down about 30mm and deploys the probe as if to probe the bed. However its short by about 190mm of reaching the bed. It is 211.05mm to the bed.
          Also instead of slowly moving down to probe the bed, it raises as if either it is inverted or my z-axis is inverted.
            Can you post your updated files with the changes you've made?
            Michael Hathawayundefined 2 Replies Last reply Reply Quote 0
              @phaedrux
              ; Config.g
              M558 P9 C"io3.in" H5 F120 T600                    ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X23 Y10 Z0                               ; set Z probe trigger value, offset and trigger height
              ; Custom settings
              ; homeall.g
              ; Custom settings
              ; homez.g
                @phaedrux
                https://www.youtube.com/watch?v=phEKZq5usAs
                  Two things.
                  What's with the insane max speeds?
                  And check what I posted above for the homing files.
                  You've got a g92 z0 in there to force the position as homed and wherever the z axis currently is. You need to remove that and replace it with a g30 command to use the probe. Also helps to position the probe at the center of the bed first with a g1 XY move.
                  Then you can measure the probe trigger height.
                  Michael Hathawayundefined 1 Reply Last reply Reply Quote 0
                    @phaedrux
                    Removed G92 Z0. Insane speeds from Matterhackers config file. Reduced speeds to F360.
                      Michael Hathaway @Michael Hathaway
                      Also had to change the M569 in Config.g from S0 to S1 in order to invert the drive motor. Homeall and Homez will have to be inverted back to correct the direction.
                        I made a few more changes, so far everything is working properly. Thank you Phaedrux for all your help. 😳
                        ; Config.g
                        M569 P0.2 S1                                       ; physical drive 0.2 goes backwards
                        ; Custom settings
                        ; homeall.g
                        G1 H1 X-255 Y-225 F1000  ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 H2 X5 Y5 F360        ; go back a few mm
                        G1 X95 Y100 F1000      ; move probe to center of bed
                        G30
                        ; G1 H1 Z215 F800        ; lift Z relative start position
                        ; homex.g
                        ;G1 H2 Z0 F1000    ; Do not lift Z relative to current position
                        ; G1 H2 Z-10 F1000   ; lift Z relative to current position
                        G1 H1 X-255 F1000 ; move quickly to X axis endstop and stop there (first pass)
                        ; G30
                        G1 H2 X5 F1000    ; go back a few mm
                        G1 H1 X-255 F360  ; move slowly to X axis endstop once more (second pass)
                        ;G1 H2 Z0 F1000    ; Do not lower Z again
                        ; homey.g
                        ; called to home the Y axis
                        G1 H2 Z0 F1000   ; lift Z relative to current position
                        G1 H1 Y-225 F1000 ; move quickly to Y axis endstop and stop there (first pass)
                        G1 H2 Y5 F1000    ; go back a few mm
                        G1 H1 Y-225 F360  ; move slowly to Y axis endstop once more (second pass)
                        ;G1 H2 Z0 F6000  ; lower Z again
                        ; homez.g
                        G30
                        • Nightreaverundefined
                          Nightreaver
                          Something I can also recommend to you, is splitting the home[all|x|y|z].g files into seperate ones.
                          I had trouble with homeall not working while x or y separately worked well.
                          homeall.g
                          ; homeall.g
                          M98 P"/sys/homex.g"       ;start homing x
                          M98 P"/sys/homey.g"       ;start homing y
                          M98 P"/sys/homez.g"       ;start homing z
                          G1 H1 X0             ; return 0 X axis
                          G1 H1 Y0             ; return 0 Y axis
                          and then put for code for x y z homing in separate files.
                          This also helps to find bugs when it comes to "why homez doesn't work standalone, but works when homeall is used" kind of things.
