HELP! Duet 2 WiFi Configuration and DWC Upload???
So, When I try to save my Z height under G31 and then home it, it doesn't go to the height I had just set it at. What am I doing wrong? Do I need to change something in homez.g and homeall.g?
Thanks,
-Carson
So, literally for the past 7 hours I have been trying to get the height map I had when I first started. After almost pulling my hair out and a lot of temper tantrums, I finally got close, probably as close as I'll ever get. It may not look flat but I like the low deviation number
Check it out -
@pcnoobneedsmajorhelp said in HELP! Duet 2 WiFi Configuration and DWC Upload???:
Thanks,
-Carson
G31 Z sets the distance between the nozzle and the bed when the probe triggers. So I'm not sure I understand the question. What are you expecting to happen and when?
That's about as good of a heightmap as I could ever hope to get.
I ended up figuring it out. I was going in the wrong direction.
The problem I'm having now despite having a perfect first layer, and then perfect layers throughout, is that the print is peeling up more and more throughout the print until a print is about half way done (about 122 layers) and it completely separates from the bed causing me to have to stop the print.
For the next print (same object), I put a raft down first instead of just a brim and the same thing happened but this time at 13 layers, all while having flawless layersThe bed is flat, adhesion seems to be fine, and the bed is only at 55c°
Just so the print I have going now doesn't fail again, I've taped the raft to the bed using high heat transfer tape.
I feel like after the PLA cools down all the way, it somehow loses it's adhesion
What are your thoughts?
Thanks,
-Carson
Clean your bed really well with isopropyl alcohol.
And crank up your bed temp. If the heater is set to 55c the surface of the bed could be 10c cooler. Try 65c. -
I usually have it set at 60, but when researching what causes peeling it said bed temp was likely too high. After this print though I'll definitely clean the bed with the rubbing alcohol and do a small test print at 65°c. It'll be like 11pm (PT) by the time this print finishes, so if 65°c doesn't work, what would you suggest I try?
Thanks,
-Carson
70c?
Higher first layer temp on the hot end. Slower first layer.
What type of print surface is it?
Depending on how much you've been touching it you could clean it with warm water with a drop of dish soap in it. Rinse well. Then alcohol again.
Garolite. I run the print temp at 218°c, and no matter what, I always do 10 mm/s for the initial layer. It adds quite a bit of time on larger prints, but it's well worth it.
Yeah I was actually thinking about taking some fine grit sand paper to rough up the surface and then clean it with the alcohol. I don't know yet, but I actually am now kinda interested in playing around with it to see what works and learn some stuff along the way. This is my first time having issues with adhesion, so I'm somewhat curious.
I've not used garolite before, but with the PEI sheet I have I give it a light wet sanding with 2000 grit sponge pad and then clean with water and alcohol and it definitely improves the stick.
Yeah I'm no doubt definitely going to do that then. You can never have enough stick in my opinion.
I might have found the culprit to the last 2 prints not sticking though. I had my ceiling fan on.
"facepalm" -
I wish thermal cameras were cheaper. Being able to SEE temperature would be sooo so useful sometimes.
Just found these. I actually might get one. For both android and ios.
So I'm getting a 404 Error when I try and access the DWC address page.
Sometimes the address works and sometimes it doesn't. It's like hit or miss. Every time I do an update on my PC it seems to happen more, but all of my settings are set to allow the address to load. I've turned off my VPN just in case and still nothing. Solutions?
When you get the 404 are you able to ping the duet IP address?
If you connect via USB terminal (or paneldue) does it respond to commands?
Is the LED on the wifi module lit up?Need to figure out if it's a networking issue, or an SD card issue, or something else.
When I inserted the micro SD into my PC it said something was wrong with it but I just ignored it because PC's are stupid that way, and there usually aren't any problems. The SD card functioned properly though (I was able to access all the files)
Just to be sure I copied all of my files to a new Micro SD and I'm getting the same result/issue.
404 Not Found
Through the PanelDue I sent the M122 and I got this message
Unfortunately the PAnelDue doesn't have enough text space to show the full report and the wifi info is near the end, so you'd need to check from USB terminal.
Though if you send M552 it should be able to tell you if you have an IP address or not.
With the SD card in the socket you can also send M22 to unmount, M21 to mount to the card. And then send
M122 P104 S10
to test if the SD card is working ok with a test write. -
Ok so i did that and got this
so if i connect via USB what program should I open? YAT, Arduino, Visual Studio Code?
YAT would be the correct way to interface over USB terminal.
