    Heatbed and PID
    1.4k
    • StaticRedundefined
      StaticRed @Phaedrux
      @phaedrux Hey, so im running a 150x150mm Heater with 300w of power. This is controlles by an SSR and with 220v. It then heats up an 6mm thick aluminium plate, the termistor is underneath the silicon heater attached.
      To start PID im doing a simple M303 H0 S60, H0 being my bed heater.
      Running latest Duet RepRap Stable Release.
      Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.2.2 (2021-02-11)
        What values does it produce once the tuning is complete?
        This?
        M308 S0 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp1
        M950 H0 C"out0" T0 Q10                                    ; create bed heater output on out0 and map it to sensor 0
        M307 H0 B0 S1.00                                      ; enable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                               ; map heated bed to heater 0
        M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
        M308 S1 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp0
        M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
        M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
        M307 H0 R1.168 C313.3 D6.25 S1.00					  ; bed pid
        M307 H1 R2.798 C162.9:144.9 D7.50 S1.00 V23.7	      ; hotend pid
        StaticRedundefined 1 Reply Last reply Reply Quote 0
          StaticRed @Phaedrux
          @phaedrux M307 H0 R1.160 C255.8 D6.62 S1.00 ; bed pid
          tgese are the current values i use, set bangbang to false and frequency Q to 10
            Just to confirm, you've got temp1 thermistor on the heater0 (bed) and temp0 thermistor on heater1 (hotend)?
            And you've got a semitek thermistor on both bed and hot end?
            Have you ever let the PID tune run to completion or have you always canceled it after a few hours?
            Was tuning started from room temp?
              StaticRed @Phaedrux
              @phaedrux Yes for basically all the questions. I once let it run 3 hours, but then stoped it because i had to go away. The PID for the hotend works perfectly tho. I get really like 0 degree variation. But on the bed i just cant get it working.
                Can you post a photo of the bed assembly?
                150x150x6mm and 300W of AC power should heat up fairly quickly, but maybe takes a lot longer to cool down. That's usually what the tuning cycle is waiting for the longest.
                  StaticRed @Phaedrux
                  @phaedrux alt text so this is what my bed assembly is looking like. Yes it needs kind of long to cool down.
                    Is that a Voron0? Closed sides but open top?
                      StaticRed @Phaedrux
                      @phaedrux its a selfmade printer. Yes sides are closed by now, but top will get enclosed some time soon aswell.
                        I believe there is plans to make the tuning cycle time limitable in such cases. Not sure when that's coming though.
                        As it is, you can probably get a good tune from it by letting it play out, though with a lot of heat retention that could take awhile.
                        StaticRedundefined 3 Replies Last reply Reply Quote 0
                          StaticRed @Phaedrux
                          @phaedrux okay i will let it run trough now, im home all day so i hope it does not take like 10 hours xD
                            StaticRed @Phaedrux
                            @phaedrux so after a bit i got this message this time
                            Warning: heater behaviour was not consistent during tuning
                            Auto tuning heater 0 completed after 6 idle and 25 tuning cycles in 2735 seconds. This heater needs the following M307 command:
                            M307 H0 R1.189 C136.8 D6.60 S1.00 V23.8
                            Edit the M307 H0 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.
                              StaticRed @Phaedrux
                              @phaedrux okay so i was able to fix it. I let it run trough for like 4h, then i had it oscilating, so i rised the d value a bit and now im getting a stable temp.
                                Glad you got it. A little manual nudging to get it stable is pretty common. The tuning algorithm is still being improved upon to better deal with the edge cases like very large beds or very high powered heaters or chamber heaters etc.
