    Add extruder and heater
    • Pyperundefined
      Pyper
      Do you have to manually update config.g to add another extruder and hot end heater?
      I followed the directions here but nothing changed:
      https://betrue3d.dk/duet-wifi-adding-a-second-extruder/
        droftarts administrators
        @pyper in that tutorial he doesn’t add new heater or temp sensor to the tool, as he’s using the existing hotend for both tools. So yes, you need to add them. Probably easiest to use the RRF configuration tool to produce an example config with two hotends, then copy the bits you need.
        Pyperundefined 1 Reply Last reply Reply Quote 0
        • Pyperundefined
          Pyper @droftarts
          @droftarts
          That makes sense, thank you!
