Solved LCD PanelDue 7i not working
I have a problem with the LCD PanelDue 7i, once plugged it shows a blank screen (photo), i tried with both connection option furnished and still not working. To be sure that it wasn't cable or duet's pin fault i tried with a same LCD panel from another printer and that one works.
Is there any solution for that?
@pietroe3d have you tried reflashing the firmware on the paneldue? https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update#Section_Firmware_update_via_USB
@jay_s_uk it worked, thanks
