    Accelerometer Usage
    Beta Firmware
    25
    191
    20.3k
    • StaticRedundefined
      StaticRed @dc42
      @dc42 if i use P0 instead of P100 my DWC will time out and it wont post anything to the console sadly.
      dc42undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @StaticRed
        @staticred could it be that the INT wire isn't connected?
          @staticred did you get the accelerometer working?
          StaticRedundefined 1 Reply Last reply Reply Quote 0
            StaticRed @dc42
            @dc42 said in Accelerometer Usage:
            so i redo the howl wiring, and its pretty secure now on the board. At first it was pretty bad, but now its solid. I now used P100 instead of P0, but still getting accelerometer not found. All cables are connected as meant above.
              StaticRed @StaticRed
              @staticred Sorry meant i used P0 for the accelerometer and gcode.
                @staticred can you confirm that you do not have a PanelDue connected? The PanelDue port is shared with IO0.
                StaticRedundefined 2 Replies Last reply Reply Quote 0
                  StaticRed @dc42
                  @dc42 Sure nothing else is connected to the board. Just the normal stuff like fans motors heaters
                    StaticRed @dc42
                    @dc42 okay so i rechecked every wire, seems to be all fine. I think its just something about wrong gcode, nothing more.
                    Maybe my config.g can help? https://just-paste.it/SqW7DwJd1j
                    GCode im using just to try the accelerometer
                    M956 P0 S1000 A0
                    DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                    • DIY-O-Sphereundefined
                      DIY-O-Sphere @StaticRed
                      @staticred
                      If you paste
                      M955 P0  C"io0.out+io0.in"
                      to the DWC gcode input box, what is the replied message?
                        StaticRed @DIY-O-Sphere
                        @diy-o-sphere Error: M955: Accelerometer not found on specified port
                          @staticred https://imgur.com/a/p3jq7Oh this is how i hooked it up
                          DIY-O-Sphereundefined 3 Replies Last reply Reply Quote 0
                            @staticred
                            I remember that I also had strange readings in the beginning, but the sensor still worked and was found with the M955 command. I have also plugged it to Io0. But I have connected all wires to the paneldue port.
                              @staticred
                              That is my wiring
                                This post is deleted!
                                  @diy-o-sphere Thanks a lot man, i will try it out. I have another version of the Lis3DH sensor, stemm qt. It just has 2 ports on the side, not sure if it will effect anything, but i dont think so.
                                    @staticred
                                    Sorry, had to delete my previous post. Now I noticed that you have connected the wires to the temp dautherboard. That looks right to me.
                                      @diy-o-sphere Ok it now it works,
                                      Accelerometer 0:0 with orientation 20 samples at 1344Hz with 10-bit resolution
                                      It worked until i tried to run a test. Then DWC timed out, and now im getting no connection anymore. Same wiring. Really weird.
                                        @staticred said in Accelerometer Usage:
                                        That suggests that something is wrong with the interrupt input. Check the connection between INT0 on the LIS3DH and io0.in, and perhaps try using a different IO port.
                                          StaticRed @dc42
                                          @dc42 Nope no chance. I wired it to io1. Same thing. I tested all connections with a multimeter and they work. But sadly my board cant build up a connection to the accelerometer. Is there something like a debug mode, which may teaches me more about what exactly the problem is?
                                          StaticRedundefined 1 Reply Last reply Reply Quote -1
                                            @staticred seems like it still did record some data at some point.
                                            But it does not make sense that that is the z axis. Because the board is mounted flat on the toolhead. Really strange
