    Accelerometer Usage
    Beta Firmware
    25
    191
    20.0k
      dc42 administrators @StaticRed
      @staticred could it be that the INT wire isn't connected?
        @staticred did you get the accelerometer working?
        StaticRedundefined 1 Reply Last reply Reply Quote 0
        • StaticRedundefined
          StaticRed @dc42
          @dc42 said in Accelerometer Usage:
          so i redo the howl wiring, and its pretty secure now on the board. At first it was pretty bad, but now its solid. I now used P100 instead of P0, but still getting accelerometer not found. All cables are connected as meant above.
            StaticRed @StaticRed
            @staticred Sorry meant i used P0 for the accelerometer and gcode.
              @staticred can you confirm that you do not have a PanelDue connected? The PanelDue port is shared with IO0.
              StaticRedundefined 2 Replies Last reply Reply Quote 0
                StaticRed @dc42
                @dc42 Sure nothing else is connected to the board. Just the normal stuff like fans motors heaters
                  StaticRed @dc42
                  @dc42 okay so i rechecked every wire, seems to be all fine. I think its just something about wrong gcode, nothing more.
                  Maybe my config.g can help? https://just-paste.it/SqW7DwJd1j
                  GCode im using just to try the accelerometer
                  M956 P0 S1000 A0
                  DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                  • DIY-O-Sphereundefined
                    DIY-O-Sphere @StaticRed
                    @staticred
                    If you paste
                    M955 P0  C"io0.out+io0.in"
                    to the DWC gcode input box, what is the replied message?
                      StaticRed @DIY-O-Sphere
                      @diy-o-sphere Error: M955: Accelerometer not found on specified port
                        @staticred https://imgur.com/a/p3jq7Oh this is how i hooked it up
                        DIY-O-Sphereundefined 3 Replies Last reply Reply Quote 0
                          @staticred
                          I remember that I also had strange readings in the beginning, but the sensor still worked and was found with the M955 command. I have also plugged it to Io0. But I have connected all wires to the paneldue port.
                            @staticred
                            That is my wiring
                              This post is deleted!
                                @diy-o-sphere Thanks a lot man, i will try it out. I have another version of the Lis3DH sensor, stemm qt. It just has 2 ports on the side, not sure if it will effect anything, but i dont think so.
                                  @staticred
                                  Sorry, had to delete my previous post. Now I noticed that you have connected the wires to the temp dautherboard. That looks right to me.
                                    @diy-o-sphere Ok it now it works,
                                    Accelerometer 0:0 with orientation 20 samples at 1344Hz with 10-bit resolution
                                    It worked until i tried to run a test. Then DWC timed out, and now im getting no connection anymore. Same wiring. Really weird.
                                      @staticred said in Accelerometer Usage:
                                      That suggests that something is wrong with the interrupt input. Check the connection between INT0 on the LIS3DH and io0.in, and perhaps try using a different IO port.
                                        StaticRed @dc42
                                        @dc42 Nope no chance. I wired it to io1. Same thing. I tested all connections with a multimeter and they work. But sadly my board cant build up a connection to the accelerometer. Is there something like a debug mode, which may teaches me more about what exactly the problem is?
                                        StaticRedundefined 1 Reply Last reply Reply Quote -1
                                          @staticred seems like it still did record some data at some point.
                                          But it does not make sense that that is the z axis. Because the board is mounted flat on the toolhead. Really strange
                                            @staticred I will re-test accelerometer with Duet 3 Mini later today or tomorrow.
                                            What did the raw data look like, before you clicked Analyse?
