    [3.3-rc2/3] "Change filament" Does not work correctly
    Beta Firmware
    904
      Phaedrux Moderator @Diamondback
      @diamondback Thanks. Far as we know as of RC3 it should be working. @chrishamm will have to take a look at your files.
      Diamondbackundefined 2 Replies Last reply Reply Quote 0
      • Diamondbackundefined
        Diamondback @Phaedrux
        @phaedrux Thank you, I will update to RC3 and see if things persist. 👍
          @phaedrux Just had time to try again on RC3, same behavior as on RC2.
            Would you be able to share all of your macros that are called in the filament change load and unload macros? What's actually happening is buried in there.
            Diamondbackundefined 1 Reply Last reply Reply Quote 0
              @phaedrux here you go (I replaced macro calls by the actual gcode to makes things easier to read)
              unload
              M42 P1 S255; lights on
              M109 S270
              M300 S300 P300
              G4 P300
              M300 S400 P300
              G4 P300
              M300 S500 P300
              M291 P"Pull out filament" R"Filament" S2
              M104 S0
              M300 S300 P300
              G4 P300
              M300 S400 P300
              G4 P300
              M300 S500 P300
              config
              M207 S0.3 F3000 Z0.0 	;firmware retraction settings for PETG
              M302 S250 R190      	;Cold extrusion settings
              load (this is using the "PebbleWiper" concept with a variable amount of pebbles being extruded depending on if it's a filament load or a toolchange, so don't be surprised by the servo calls etc)
              M291 P"Heating for purge" R"Filament" S0 T115
              if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed
                M98 P"homeall.g"
              M109 S270
              M302 S250 R190
              M300 S300 P300
              G4 P300
              M300 S400 P300
              G4 P300
              M300 S500 P300
              M291 P"Insert new Nylon filament" R"Filament" S2
              M280 P0 S40
              if state.currentTool < 0
              	echo "Can't Prime & Brush, no tool selected!"
              	M99
              if heat.heaters[tools[state.currentTool].heaters[0]].current > heat.coldExtrudeTemperature
              	M564 S0
              	G90
              	G53 G1 X-148.7 Y70 F25000		; Move in front of brush at safe Y
              	G53 G1 Y149 F25000				; Quickly move in
              	;G53 G1 Y150 F3000				; Slowly approach final Y position
              	var primeRepeats = 1
              	if exists(var.R)
              		set var.primeRepeats = var.R
              	while iterations < var.primeRepeats
              		G4 P1000
              		M280 P0 S40
              		G4 P100
              		M83
              		;M280 P0 S85
              		G1 E20 F200
              		M106 S255
              		G4 P7000
              		G1 E-0.8 F2500
              		G4 P300
              		M280 P0 S180
              		M106 S0
              		G4 P200
              	G91
              	G1 Y-40 F20000 ; start of brush
              	G1 Y35 F20000 ; start of brush
              	G1 Y-45 F20000
              	M280 P0 S40
              	G1 Y-40 F25000
              	G1 X10 F25000
              	G90
              	M564 S1
              else
              	echo "Skipping Prime & Brush due to unheated tool"
              M104 S0
              M300 S300 P300
              G4 P300
              M300 S400 P300
              G4 P300
              M300 S500 P300
                Note that M109/M104 may cause tool changes so it would be better to use G10 S/R + M116 instead, just to be safe
                the only reason why M701 could complain about a loaded filament is if M702 somehow deselected the tool
                  @phaedrux Thanks for the hint, will change that to be sure.
                  Just in case it got overlooked, this specific code worked fine on previous versions, as far as I know, RC2 was the first version to break.
                    Diamondback
                    Might have found the cause. As you can see, one of the last things my unload does is to display a blocking message that waits before the tool is allowed to cool down again.
                    The error appears in the console while the blocking message is still being displayed, ie before I confirmed it.
                    It reminds me of this issue: https://forum.duet3d.com/topic/23579/3-3rc3-tool-change-don-t-wait-on-m116-p/25
                    @dc42 is this possibly related?
                      Diamondback
                      Update, tested the RC3+7 from the linked thread, this does not solve the issue. Still sounds like a ver similar thing.
                        @diamondback Now that 3.3 final is available can you test with that?
                          @phaedrux Same thing as before, here's a screenshot showing the behavior I mentioned (error from load in the console while the dialog from unload is still being displayed)
                          Will remove the dialog and re-test to confirm.
                            @phaedrux Ok, yea when I remove the M291 S2 from the unload script, it "works", as in it successfully executes unload and then load.
                            So looks like the blocking M291 is indeed the issue here due to M701 being executed while M702 is still "active" due to the blocking dialog.
                              Thanks. Will investigate.
                                Diamondback
                                @phaedrux Any news? This is still bugging my daily 😁
                                  dc42 administrators @Diamondback
                                  @diamondback are you running in standalone or SBC mode?
                                    Diamondback @dc42
                                    @dc42 Standalone. (Duet 2 Wifi + Duex 5)
                                      Diamondback
                                      Any news about this @dc42 ?
                                        Diamondback
                                        Any news on this? Would love to get the "change" functionality back... @chrishamm @dc42
                                          Diamondback
                                          I don't know when exactly this got solved, but starting with one of thhe 3.4 beta builds, this is no longer an issue and works fine again. 🙂
                                          • Diamondbackundefined Diamondback has marked this topic as solved
