    [3.3-rc2/3] "Change filament" Does not work correctly
    Beta Firmware
    904
    • Diamondbackundefined
      Diamondback @Phaedrux
      @phaedrux Just had time to try again on RC3, same behavior as on RC2.
        Would you be able to share all of your macros that are called in the filament change load and unload macros? What's actually happening is buried in there.
        Diamondbackundefined 1 Reply Last reply Reply Quote 0
          @phaedrux here you go (I replaced macro calls by the actual gcode to makes things easier to read)
          unload
          M42 P1 S255; lights on
          M109 S270
          M300 S300 P300
          G4 P300
          M300 S400 P300
          G4 P300
          M300 S500 P300
          M291 P"Pull out filament" R"Filament" S2
          M104 S0
          M300 S300 P300
          G4 P300
          M300 S400 P300
          G4 P300
          M300 S500 P300
          config
          M207 S0.3 F3000 Z0.0 	;firmware retraction settings for PETG
          M302 S250 R190      	;Cold extrusion settings
          load (this is using the "PebbleWiper" concept with a variable amount of pebbles being extruded depending on if it's a filament load or a toolchange, so don't be surprised by the servo calls etc)
          M291 P"Heating for purge" R"Filament" S0 T115
          if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed
            M98 P"homeall.g"
          M109 S270
          M302 S250 R190
          M300 S300 P300
          G4 P300
          M300 S400 P300
          G4 P300
          M300 S500 P300
          M291 P"Insert new Nylon filament" R"Filament" S2
          M280 P0 S40
          if state.currentTool < 0
          	echo "Can't Prime & Brush, no tool selected!"
          	M99
          if heat.heaters[tools[state.currentTool].heaters[0]].current > heat.coldExtrudeTemperature
          	M564 S0
          	G90
          	G53 G1 X-148.7 Y70 F25000		; Move in front of brush at safe Y
          	G53 G1 Y149 F25000				; Quickly move in
          	;G53 G1 Y150 F3000				; Slowly approach final Y position
          	var primeRepeats = 1
          	if exists(var.R)
          		set var.primeRepeats = var.R
          	while iterations < var.primeRepeats
          		G4 P1000
          		M280 P0 S40
          		G4 P100
          		M83
          		;M280 P0 S85
          		G1 E20 F200
          		M106 S255
          		G4 P7000
          		G1 E-0.8 F2500
          		G4 P300
          		M280 P0 S180
          		M106 S0
          		G4 P200
          	G91
          	G1 Y-40 F20000 ; start of brush
          	G1 Y35 F20000 ; start of brush
          	G1 Y-45 F20000
          	M280 P0 S40
          	G1 Y-40 F25000
          	G1 X10 F25000
          	G90
          	M564 S1
          else
          	echo "Skipping Prime & Brush due to unheated tool"
          M104 S0
          M300 S300 P300
          G4 P300
          M300 S400 P300
          G4 P300
          M300 S500 P300
            Note that M109/M104 may cause tool changes so it would be better to use G10 S/R + M116 instead, just to be safe
            the only reason why M701 could complain about a loaded filament is if M702 somehow deselected the tool
              @phaedrux Thanks for the hint, will change that to be sure.
              Just in case it got overlooked, this specific code worked fine on previous versions, as far as I know, RC2 was the first version to break.
                Diamondback
                Might have found the cause. As you can see, one of the last things my unload does is to display a blocking message that waits before the tool is allowed to cool down again.
                The error appears in the console while the blocking message is still being displayed, ie before I confirmed it.
                It reminds me of this issue: https://forum.duet3d.com/topic/23579/3-3rc3-tool-change-don-t-wait-on-m116-p/25
                @dc42 is this possibly related?
                  Diamondback
                  Update, tested the RC3+7 from the linked thread, this does not solve the issue. Still sounds like a ver similar thing.
                    Phaedrux Moderator @Diamondback
                    @diamondback Now that 3.3 final is available can you test with that?
                    Diamondbackundefined 2 Replies Last reply Reply Quote 0
                      @phaedrux Same thing as before, here's a screenshot showing the behavior I mentioned (error from load in the console while the dialog from unload is still being displayed)
                      Will remove the dialog and re-test to confirm.
                        @phaedrux Ok, yea when I remove the M291 S2 from the unload script, it "works", as in it successfully executes unload and then load.
                        So looks like the blocking M291 is indeed the issue here due to M701 being executed while M702 is still "active" due to the blocking dialog.
                          Thanks. Will investigate.
                            Diamondback
                            @phaedrux Any news? This is still bugging my daily 😁
                              dc42 administrators @Diamondback
                              @diamondback are you running in standalone or SBC mode?
                                Diamondback @dc42
                                @dc42 Standalone. (Duet 2 Wifi + Duex 5)
                                  Diamondback
                                  Any news about this @dc42 ?
                                    Diamondback
                                    Any news on this? Would love to get the "change" functionality back... @chrishamm @dc42
                                      Diamondback
                                      I don't know when exactly this got solved, but starting with one of thhe 3.4 beta builds, this is no longer an issue and works fine again. 🙂
                                      • Diamondbackundefined Diamondback has marked this topic as solved
