[3.3.0] My tool disappeared after 3.3.0 install (?)
Firmware installation
454
    paralepsis
    I've got a recently upgraded Makerbot R2X that has a Duet Wifi brain now. Was printing well on 3.2.2. Upon installation of 3.3, the "HotEnd" tool is no longer visible in the web UI nor in PanelDue 5i.
    Configuration and M122 below.
    Help :)! Thanks,
    Rob
    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 29 2021 06:56:32 GMT-0500 (Central Daylight Time)
    M550 P"Peanut" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes backwards (lazy wiring!)
    M92 X88.89 Y88.89 Z400.00 E96.27520187 ; set steps per mm
    M566 X900.00 Y900.00 Z600.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z1170.00 E1600.00 ; set maximum speeds (mm/min)
    M201 X1000.00 Y1000.00 Z150.00 E2000.00 ; set accelerations (mm/s^2)
    M906 X550 Y600 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    ; M906 X800 Y800 Z400 E800 I30
    M84 S30 ; Set idle timeout
    M208 X275 Y150 Z150 S0 ; set axis maxima. Note X>250 is not on build plate...
    M574 X2 S1 P"!xstop" ; configure active-low endstop for high end on X via pin (!)xstop
    M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin (!)ystop
    M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin (!)zstop
    ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
    ;M557 X15:215 Y15:150 S20 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4066 A"Bed[C]" ; configure sensor 0 as thermistor on pin bedtemp
    ;M307 H0 R0.897 C158.7 D1.38 S1.00 V23.9 B0 ; from M303 H0 S115
    M307 H0 R0.6 C158.7 D1.38 S1.00 V23.9 B0 ; from M303 H0 S115 (modified)
    M308 S1 P"spi.cs2" Y"thermocouple-max31856" A"HotEnd[C]"
    M307 H1 R2.244 C198.3 D5.75 S1.00 V24.0 ; from M303 H1 S250
    ; MCU Temp and TMC drivers -- need this before we set up the fan
    M308 S10 Y"mcu-temp" A"MCUTemp[C]"
    M308 S11 Y"drivers" A"TMC[Warning]"
    M308 S12 P"e1temp" Y"thermistor" T100000 B4092 A"PwrSupply[C]"
    M106 P0 S1.0 H1 T45 C"HotEnd" ; set fan 0 value. Thermostatic control is turned on
    M950 F2 C"fan2" Q100
    M106 P2 S1.0 B0.5 L0.4 T35:40 H10:11 C"Duet" ; turn on the fan if we get a warning from TMC or the MCU gets hot
    ;M106 P2 S0.2 C"Duet" ; turn on the fan all the time
    M563 P0 S"HotEnd" D0 H1 F-1 ; define tool 0, no part cooling fan
    ; DHT22 (pin 1 +V, pin 2 GND, pin 4 (E2 Stop) Data)
    M308 S2 P"exp.e2_stop" Y"dht22" A"AmbTemp[C]"
    M308 S3 P"S2.1" Y"dhthumidity" A"AmbHumid[%]"
    ; LEDs: assign e1heat, treat as a fan so we get a slider, turn them on, name them
    M950 F3 C"e1heat" Q500
    M106 P3 S255 C"Lights"
    T0 ; select first tool
    6/17/2021, 7:40:37 PM m122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
    Board ID: 08DDM-9FAM2-LW4SD-6JKD2-3S86R-KLW7X
    Used output buffers: 3 of 24 (19 max)
    Static ram: 23876
    Dynamic ram: 75916 of which 332 recycled
    Never used RAM 11436, free system stack 122 words
    Tasks: NETWORK(ready,14.1%,244) SENSORS(delaying,0.0%,80) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,313) MAIN(running,85.6%,407) IDLE(ready,0.1%,29), total 100.0%
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:15:10 ago, cause: software
    Last software reset at 2021-06-11 05:59, reason: User, GCodes spinning, available RAM 14012, slot 1
    Error status: 0x00
    Aux0 errors 0,0,0
    Step timer max interval 0
    MCU temperature: min 32.6, current 34.5, max 36.0
    Supply voltage: min 24.0, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/12/12, gc cycles 0
    Driver 0: position 24000, standstill, SG min/max 0/206
    Driver 1: position 12889, standstill, SG min/max 0/154
    Driver 2: position 2000, standstill, SG min/max 0/493
    Driver 3: position 0, standstill, SG min/max not available
    Driver 4: position 0, standstill, SG min/max not available
    Driver 5: position 0
    Driver 6: position 0
    Driver 7: position 0
    Driver 8: position 0
    Driver 9: position 0
    Driver 10: position 0
    Driver 11: position 0
    Date/time: 2021-06-17 19:40:36
    Slowest loop: 8.26ms; fastest: 0.14ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 1.2ms, write time 0.0ms, max retries 0
    DMs created 83, maxWait 63073ms, bed compensation in use: none, comp offset 0.000
    === MainDDARing ===
    Scheduled moves 17, completed moves 17, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 15.83ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is active
    WiFi firmware version 1.26
    WiFi MAC address 2c:3a:e8:0b:36:69
    WiFi Vcc 3.46, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 25120
    WiFi IP address 192.168.1.220
    WiFi signal strength -65dBm, mode 802.11n, reconnections 0, sleep mode modem
    Clock register 00002002
    Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
      paralepsis
      @paralepsis said in [3.3.0] My tool disappeared after 3.3.0 install (?):
      To solve my own problem, it's that "F-1" in the M563 line.
      How do I correctly define there to be no part fan?
      Thanks!
      Rob
      undefined undefined 2 Replies Last reply 18 Jun 2021, 02:25 Reply Quote 0
        Nuramori @paralepsis
        @paralepsis I believe you simply don’t define a fan by removing the “F-1”
          I'd be curious to see what errors if any get reported by sending M98 P"config.g" with the F-1 in place.
          undefined 1 Reply Last reply 18 Jun 2021, 16:27 Reply Quote 0
            dc42 administrators @paralepsis
            What are you trying to achieve? If you want M106 commands in the GCode file being printed to be ignored for that tool, then you would have to define a dummy fan number and use that in the M563 command. If you don't specify a fan number at all in M563, then M106 without a P parameter will default to controlling fan 0 when that tool is active.
            undefined 1 Reply Last reply 18 Jun 2021, 16:24 Reply Quote 0
              paralepsis @dc42
              @dc42 I'm trying to avoid having my fan spuriously controlled during prints. I think the right thing is for me to just not use fan 0 but rather to define that fan to another "position" so that it doesn't matter.
                paralepsis @Phaedrux
                @phaedrux said in [3.3.0] My tool disappeared after 3.3.0 install (?):
                This is something I can answer :):
                Error: in file macro line 70 column 28: M563: expected number after 'F'
                Of course I wasn't seeing that on the console when I booted.
                  @paralepsis I think you can achieve that by not creating fan number 0, i.e. do not use a M950 H0 command; or if you want o be explicit, use M950 F0 C"nil".
                  4 out of 8
