heater 1 is missing after update
Have the GCODE file running without heating. The axes X and Y are only moving in one direction. Manuel run all axes correctly -
@joe92 said in heater 1 is missing after update:
The print does not work. The GCODE file starts in the middle of the bed and moves quickly to the corner (X350 / Y350). The display shows that the Prinhead is still in the middle.
Here is my reconstituted gcode progression
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.1 on Fri Jan 15 2021 23:22:23 GMT+0100 (Mitteleuropäische Normalzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Set firmware compatibility to look like Marlin M550 P"Voron V2" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; G29 Mesh M557 X55:295 Y30:270 S30 ; S30 for high density, S40 for testing ; Drives M569 P0 S1 ; X Motor goes backwards M569 P1 S1 ; Y Motor goes backwards M569 P3 S1 ; Extruder Motor 0 goes forwards (BMG) M569 P5 S1 ; Z1 goes backwards M569 P6 S0 ; Z2 goes forwards M569 P7 S1 ; Z3 goes forwards M569 P8 S0 ; Z4 goes backwards ; Z-Axis Stepper Leveling Configuration M584 X0 Y1 Z5:6:7:8 ; 4 motors; duex 5, 6, 7, 8 M671 X420:420:-60:-60 Y410:-10:-10:410 S20 ; belts in all 4 corners M92 X80 Y80 Z400 ; Steps per mm M92 E424.30 ; Steps per mm (BMG) (1.8deg) M350 E16 I1 ; Configure microstepping with interpolation M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation M203 X18000 Y18000 E9000 Z4000 ; Set maximum speeds (mm/min) for 2.1 only (300mm/s max) M201 X3000 Y3000 E6000 Z500 ; Set accelerations (mm/s^2) M566 X900 Y900 E1200 Z150 ; Set maximum instantaneous speed changes (mm/min) M98 P"/macros/print_scripts/xy_current_high.g" ; Set XY Motor Currents M98 P"/macros/print_scripts/e_current_high.g" ; Set Extruder Motor Currents M98 P"/macros/print_scripts/z_current_high.g" ; Set Z Motor Currents (must come after extruder, because on the extruder headers) M84 S0 ; Set idle timeout, never time out ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X350 Y350 Z300 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop ; Inductive Leveling Sensor M98 P"/macros/probe_scripts/activate_z_probe.g" ; activate the Z probe M98 P"/macros/probe_scripts/activate_z_switch.g" ; activate the Z switch ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M98 P"/macros/PID/ABS_PID.g" ; Set model parameters for heater 0 and use PID mode? M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; define E0 temperature sensor M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"duex.fan3" Q500 ; create fan 0 on pin duex.fan3 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue ; Enable config-override.g ;M501 ; Allow Movement of Axis that have not been homed M564 H0 ;Generated with Cura_SteamEngine 4.9.1 T0 M109 S0 M82 ;absolute extrusion mode M104 s0 G21 G90 T0 G29 s2 G92 E0.0 M220 S100 M290 R0 S0 G32 ; bed.g ; called to perform automatic bed compensation via G32 ; setup for quad belt gantry M561 ; Clear any existing bed transform G28 ; home ; homeall.g ; called to home all axes G91 ; Relative G1 H2 Z5 F2000 S2 ; Lower bed 15mm G1 H1 X-300 Y-300 F2000 S1 ; Coarse home X and Y G1 H1 X-300 S1 ; Coarse X in case Y homed first G1 H1 Y-300 S1 ; Coarse Y in case X homed first G1 H1 X5 Y5 F2000 ; Move away from the endstops G1 H1 X-300 F360 S1 ; Fine home X G1 H1 Y-300 F360 S1 ; Fine home Y M98 P"/macros/print_scripts/xy_current_high.g" ; Restore motor currents G90 ; Absolute positioning ; Go to z switch and home z axis M98 P"/macros/probe_scripts/activate_z_switch.g" ; Activate Z Switch m558 P5 zstop G31 X0 Y0 Z0.9 M98 P"/macros/probe_scripts/goto_z_switch.g" ; Go To Z Switch goto_z_switch.g/ G1 X116.00 Y0 F12000 G30 Z-99999 ; Probe Z Switch G0 Z20 M98 P"/macros/probe_scripts/activate_z_probe.g" ; Activate Z Probe M558 P5 zprobein g31 x0 y0 z1.46 M98 P"/macros/probe_scripts/activate_z_probe.g" ;activate inductive z-probe M558 P5 zprobein g31 x0 y0 z1.46 ; Probe bed at these 4 points: G30 P0 X335 Y350 H0 Z-99999 G30 P1 X335 Y35 H0 Z-99999 G30 P2 X15 Y35 H0 Z-99999 G30 P3 X15 Y350 H0 Z-99999 S4 G28 Z ; Home Z Axis ; homez.g ; called to home the Z axis ; ; Lift Z relatively to current position G91 G1 H2 Z5 F2000 S2 ; Back to absolute positioning G90 ; Go to z switch and home z axis M98 P"/macros/probe_scripts/activate_z_switch.g" ; Activate Z Switch m558 P5 zstop G31 X0 Y0 Z0.9 M98 P"/macros/probe_scripts/goto_z_switch.g" ; Go To Z Switch goto_z_switch.g/ G1 X116.00 Y0 F12000 G30 Z-99999 ; Probe Z Switch G0 Z20 M98 P"/macros/probe_scripts/activate_z_probe.g" ; Activate Z Probe M558 P5 zprobein g31 x0 y0 z1.46 M98 P"/macros/probe_scripts/activate_z_probe.g" ;activate inductive z-probe M558 P5 zprobein g31 x0 y0 z1.46 M561 M375 P"bareplate.csv" G1 X20 Y20 M83 ;relative extrusion mode G1 F1500 E-1 ;LAYER_COUNT:200 ;LAYER:0 M107 M204 T5000 M566 X300 Y300 G0 F9000 X149.55 Y149.316 Z0.2 M204 P3000 M566 X1080 Y1080 print starts
Does that seem correct to you?
@phaedrux said in heater 1 is missing after update:
This may be a problem. Your back off move in homeall has an H1 on it to seek an endstop. It should not.
@phaedrux At the Config, I changed the command M584. I have inserted E0 and noted that the mistake has to come there. Have changed it in E1 and the Prinhead continues to drive only in one direction but the axis has changed
Have changed in H2
Actually it should have no H at all, or technically H0 as it is a normal move.
Eitherway, does it make a difference?
Eitherway, does it make a difference?No, even H0 not
Can you also remove the S1 on those lines. S1 is no longer used for homing moves in RRF3. Replaced by H1, so they don't really belong. Not sure if that would be enough to cause an issue, but...
If you do just a homeall with G28, are you able to jog around the bed normally? Is it only when starting a print that it's a problem?
How do you have the slicer bed size and 0,0 point configured?
@phaedrux Have the commands M584 rewritten in "M584 E2 X0 Y1 Z5: 6: 7: 8; 4 Motors; DuEx 5, 6, 7, 8"
It works with E2. I have not understood as I set the parameters in M584 exactly but I let it first so as long as it works -
Sorry I'm not sure what you mean by you comment on M584.
Can you copy and paste your command exactly as it is in config.g?
Can you also send M584 in the console to verify that it matches what you expect?
@phaedrux ; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.1 on Fri Jan 15 2021 23:22:23 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M669 K1 ; select CoreXY mode; Network
M586 P2 S0 ; disable Telnet; G29 Mesh
M557 X55:295 Y30:270 S30 ; S30 for high density, S40 for testing; Drives
M569 P8 S0 ; Z4 goes backwards; Z-Axis Stepper Leveling Configuration
M584 E2 X0 Y1 Z5:6:7:8 ; 4 motors; duex 5, 6, 7, 8M92 X80 Y80 Z400 ; Steps per mm
M84 S0 ; Set idle timeout, never time out; Axis Limits
M208 X0:350 Y0:350 Z0:300 ; set axis minima and maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Inductive Leveling Sensor
M98 P"/macros/probe_scripts/activate_z_switch.g" ; activate the Z switchM671 X420:420:-60:-60 Y410:-10:-10:410 S20 ; belts in all 4 corners
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M575 P1 S1 B57600 ; enable support for PanelDue; Enable config-override.g
;M501; Allow Movement of Axis that have not been homed
M564 H0 -
M584 E2 X0 Y1 Z5:6:7:8 ; 4 motors; duex 5, 6, 7, 8 -
It works with E2
What was it before?
Are you saying it's starting the print correctly now?
Was on E0, with E2 make the axes the right movement but is extruded nothing
It really sounds like you have a motor not connected to the right driver.
Verify which motor is connected to which driver.
E2 will only work if the extruder is actually plugged into driver2.
@phaedrux have not understood the reference to numbering but have now correct, thanks
