    BL touch settings on Reprap configurator.
    • Hiroakiundefined
      Hiroaki
      Hello.
      Please help.
      I am just now trying to change my 3D printer from Duet2wifi to Duet3.
      And having a question to set BL touch on the board 121 in Reprap configurator.
      Could someone tell me the setting for these three vales?
        droftarts administrators @Hiroaki
        @hiroaki set just the input pin and pwm pin, as you have. Don’t set the modulation pin; not used on BLTouch.
        • pldusikundefined
          pldusik
          Do i have to add g32 s2 to my gcode start script in slicer?
            That depends on what you want to do with G32. All G32 does is call the macro bed.g. You can setup whatever you want to happen in bed.g.
            https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G32_Run_bed_g_macro
            https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
            https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
