Problem with connecting fan to Duet 3
I'm having trouble with connecting my two wire 12 volt non pwm extruder fan to duet 3. I want it to be turned on after reaching the temperature of 45 degrees Celsius. I have tried to connect it in many ways, mainly between OUT4-OUT7 connectors, but with no results - it wasn't spinning at all, or in case when i connected it to OUT7, it was working only below required temperature. I was hoping that when i wire it between PWM pin and GND pin and set PWM to 100% it would work. My question is, how can i connect it in the way that it works? Im also putting below part of my config.g file.M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 A500 C170 D4.3 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F1 C"out5" Q500 ; create fan 1 on pin out7 and set its frequency M106 P1 S1.0 H1 T45 C"Hemera" ; set fan 1 value. Thermostatic control is turned on -
@grzegorz said in Problem with connecting fan to Duet 3:
M106 P1 S1.0 H1 T45 C"Hemera" ; set fan 1 value. Thermostatic control is turned onRemove the .0 after S1
Also are you sure you have the appropriate jumpers fitted to se the output voltage used on the fan connectors? -
@jay_s_uk Thanks for reply. My jumpers are fitted between middle pin and 12V.
@grzegorz Can you also confirm how you have them wired?
@jay_s_uk The brown one is connected to PWM and the pink one is connected to GND.
@jay_s_uk said in Problem with connecting fan to Duet 3:
Unfortunately still nothing happens.
@grzegorz nothing will happen as you've connected it to ground and the out4. The MOSFETs switch to ground.
You need to connect between the outlc and out -
@jay_s_uk Thanks a lot, it works fine now.
