    Start / Stop S3D SCRIPT / G-CODE
    2.5k
    • noblebranundefined
      noblebran
      @fcwilt said in Start / Stop S3D SCRIPT / G-CODE:
      Great.
      Now I don't have any delta printers so I had to check.
      For a delta printer the RRF configuration tool doesn't create those four homing files, just homedelta.g
      The homeall.g you posted looks like what the homedelta.g file should be.
      So get rid of homex.g homey.g and homez.g and then rename homeall.g to homedelta.g.
      Okay, this is done. Let me go to the next part.
      I own a Tevo Little Monster but there isn't much left of that except for the frame. Duet 2 Wifi + PanelDue 7i.
        noblebran @fcwilt
        Now with that out of the way let's turn to config.g.
        You have an M587 there which not be used in config.g. You use that command when setting up the WiFi connection but you don't keep it in config.g.
        At first glance everything else looks reasonable.
        Does the PanelDue work?
        Does homing work?
        Can you move the nozzle to all places in the printable area?
        Can you move over the range of the Z axis?
        If you move to Z=10 and do a G30 does the Z probe work?
        If you activate the heaters do they heat as expected to whatever temperature you specified?
        Do the fans work?
        My PanelDue 7i works, I haven't been able to print an enclosure for it so I haven't really been using it, but it connects and shows readings, etc.
        Homing does work.
        Yes, I can move the nozzle to all places in the printable area.
        I can move the nozzle over the range of the z axis using code, I can using the dashboard buttons. Homed it is x0, y0, z515 so when I put in a g1 z- command it goes down.
        The z-probe worked, re-calibrated just now (put the bed at z5, now its z6.35), I thought I put that correction in the config, but I guess not (as you know its the distance between the nozzle tip and tip of the probe).
        The heaters work, but I have another thread going as I always get faults that my block heater goes way above the set point. I have all e3d parts, I don't have an e3d cartridge thermistor but I didn't get one when I received the parts years ago and it worked when I had the old smoothieware system (MKS Base). The bed works great though.
        The fans work (I think). I say I think because my heatsink fan is on 24/7 now, which I know is because of the connection I plugged it in. My part cooling fans are set to turn on when the temp goes above 50 I think but I didn't know how else to control them as I would normally in the slicer.
        I did do an autocalibration and it worked
        Besides the extruder heater/thermistor and the fans (but they work) I think to answer everything I would say yes besides my comments above. Sorry for the abundance of detail.
        • DonStaufferundefined
          DonStauffer @fcwilt
          @fcwilt Interesting . Why do it as a call to files on the Duet? You do lose the Simpify3D script variable capability that way.
          • fcwiltundefined
            fcwilt @DonStauffer
            @donstauffer said in Start / Stop S3D SCRIPT / G-CODE:
            Yes you do but I haven't found that to be a problem.
            For example, I handle required changes based on the current filament type by using the filament handling feature in the DWC.
            When you select the current filament type to print it runs a config.g file unique to that filament type. In that file I put bed/hotend temperature settings, adjust the print speed and extrusion rate, etc.
            I prefer keeping as much in the Duet as I can which makes using different slicers easier.
            DonStaufferundefined noblebranundefined 2 Replies Last reply Reply Quote 0
              DonStauffer @fcwilt
              @fcwilt I was thinking along those lines but I couldn't quite solidify those thoughts. Makes sense.
                noblebran @fcwilt
                @fcwilt
                So I don't end up putting the code in the S3D software anymore, it is built into the duet? How do I make sure it comes down, the probe touches and prints from that 'mesh/surface'?
                There is also a configoveride now that doesn't have all the information that the config.g file does. I guess I need to make sure it uses that first when making a print. Maybe I need a new slicer?
                • fcwiltundefined
                  fcwilt @noblebran
                  @noblebran said in Start / Stop S3D SCRIPT / G-CODE:
                  That is entirely up to you. Many folks do, I don't. I found I prefer to have all of my print start and print end code in the Duet.
                  Everything that needs to happen at the start of the print is in the code I place in my print_begin.g file which includes:
                  • homing XYZ
                  • bed leveling
                  • setting bed/hotend temps,
                  • waiting for temps to reach the set points
                  • priming the extruder
                  • pausing to allow user to clean hotend/bed
                  • setting the Z=0 datum
                  • loading the height map
                  And anything else that I might want to have happen at the start of a print.
                  The file config-override.g is processed at boot time when config.g is processed.
                  There is nothing you need to do with config-override.g at print time.
                  You can use any slicer you want as I sometimes do.
                  My approach doesn't care as I simply setup each slicer to call my code at the start and end of a print. My code does not change if I change which slicer I use.
                  noblebranundefined 1 Reply Last reply Reply Quote 0
                    noblebran @fcwilt
                    Okay this is the same as Smoothieware on the MKS Base. Thank you!
                    homing XYZ
                    bed leveling
                    And anything else that I might want to have happen at the start of a pring.
                    Thank you my friend. I’m trying to figure all this out, so I appreciate your patience. If there is anything you can share with me as far as code to get me started I’d appreciate it. I know you don’t have a delta so things will be different but I have some things I promised to print (my director) and then my printer burnt out and I’m in a rush.
                    I have a new surface and hot end and don’t want to be smashing into it. Maybe I put a piece of cardboard over it or something. But anything is greatly appreciated and I appreciate your patience.
                    • fcwiltundefined
                      fcwilt @noblebran
                      homing XYZ
                      bed leveling
                      Glad to help in anyway I can.
                      I've listed the primary things that need to get done before a print and thus my print_begin.g file has the commands needed to do those things.
                      My file also has some code that is just checking to be sure conditions needed for printing are met.
                      Perhaps if you look back at my print_begin.g file that I posted it will make more sense.
                      If not ask about any part of it - I can create a simpler version.
                        noblebran @fcwilt
                        @fcwilt
                        I apologize I didn't see where it was, you mean the parts that are listed underneath it or the actual code itself?
                        • fcwiltundefined
                          fcwilt @noblebran
                          @fcwilt
                          My first post to you included my complete print_begin.g and print_end.g files.
                          In my next to last post I simply listed the basics things that needed to be done before a print.
                          I thought perhaps my files might make sense now that we have conversed.
                            noblebran @fcwilt
                            I am sorry, yes I see it. I can make it work. I don't know if you want me to post here but can I put my files that I create and have you do a sanity check? I appreciate it.
                            Now I have to deal with my fans not working now (always on fans).
                            Thank you again sir.
                            fcwiltundefined noblebranundefined 2 Replies Last reply Reply Quote 1
                            • fcwiltundefined
                              fcwilt @noblebran
                              @noblebran
                              Certainly post your files here.
                              We all are glad to check them over and make suggestions.
                              noblebranundefined 4 Replies Last reply Reply Quote 0
                                noblebran @noblebran
                                @noblebran Thank you sir! Be well!
                                  noblebran @fcwilt
                                  @noblebran
                                  Here is my load filament file (not sure if its the most efficient but it works)
                                  M104 P1 S225
                                  M83
                                  M104 S230 T0
                                  M109 S230 T0
                                  G1 E300 F500       ; LOAD FILAMENT
                                  M104 P1 S0
                                    noblebran @fcwilt
                                    @noblebran
                                    UNLOAD
                                    M104 P1 S225
                                    M83
                                    M104 S230 T0
                                    M109 S230 T0
                                    G1 E15 F250          ;LOAD FILAMENT
                                    G1 E-600 F3500       ;UNLOAD FILAMENT
                                    M104 P1 S0
                                      noblebran @fcwilt
                                      @noblebran
                                      My start in my slicer:
                                      G28; HOME
                                      ;G32 (REMOVE SEMI IF YOU WANT TO REMAP)
                                      G29 S1; USE STORED MESH
                                      G92 E1; SET EXTRUDER TO 1
                                        noblebran @fcwilt
                                        @noblebran
                                        I kept most of your ending script:
                                        M291 R"Finishing Print" P"Please wait..." T0
                                        M83                                                  ; extruder relative
                                        G1 E-1 F3600                                  ; retract filament
                                        M106 P0 S0                                     ; turn part fan off
                                        G10 P0 S-999 R-999 ; turn extruder heater off (also sets temps to zero)
                                        T-1          	             ; deselect all tools
                                        M140 S0                ; set bed heater active temp to 0
                                        M140 S-999           ; turn bed heater off
                                        G91                       ; relative moves
                                        G1 Z100 F1200      ; move the nozzle out of the way - step 1
                                        G90                         ; absolute moves
                                        G1 X0 Y150 F3000   ; move the nozzle out of the way - step 2
                                        G28
                                        M118 L0 P4 S"FT5|Print Finished"
                                        M291 R"Print Finished" P"OK" T0
                                        • fcwiltundefined
                                          fcwilt @noblebran
                                          @noblebran
                                          G28; HOME
                                          Does your homing script set the Z=0 datum?
                                          And why are you not waiting for temps to reach their set points?
                                            noblebran @fcwilt
                                            @noblebran
                                            G28; HOME
                                            When it comes z=515. 0 would right at the print surface. I have found on the deltas this is the correct way?
                                            In the config.g it calls out for the temps to reach their set points.
