    Start / Stop S3D SCRIPT / G-CODE
    2.5k
    • fcwiltundefined
      fcwilt @noblebran
      @noblebran said in Start / Stop S3D SCRIPT / G-CODE:
      homing XYZ
      bed leveling
      setting bed/hotend temps,
      waiting for temps to reach the set points
      priming the extruder
      pausing to allow user to clean hotend/bed
      setting the Z=0 datum
      loading the height map
      If there is anything you can share with me as far as code to get me started I’d appreciate it.
      Glad to help in anyway I can.
      I've listed the primary things that need to get done before a print and thus my print_begin.g file has the commands needed to do those things.
      My file also has some code that is just checking to be sure conditions needed for printing are met.
      Perhaps if you look back at my print_begin.g file that I posted it will make more sense.
      If not ask about any part of it - I can create a simpler version.
      noblebranundefined 1 Reply Last reply Reply Quote 0
      • noblebranundefined
        noblebran @fcwilt
        @fcwilt
        @fcwilt said in Start / Stop S3D SCRIPT / G-CODE:
        I apologize I didn't see where it was, you mean the parts that are listed underneath it or the actual code itself?
        I own a Tevo Little Monster but there isn't much left of that except for the frame. Duet 2 Wifi + PanelDue 7i.
        • fcwiltundefined
          fcwilt @noblebran
          @fcwilt
          My first post to you included my complete print_begin.g and print_end.g files.
          In my next to last post I simply listed the basics things that needed to be done before a print.
          I thought perhaps my files might make sense now that we have conversed.
            noblebran @fcwilt
            I am sorry, yes I see it. I can make it work. I don't know if you want me to post here but can I put my files that I create and have you do a sanity check? I appreciate it.
            Now I have to deal with my fans not working now (always on fans).
            Thank you again sir.
            fcwiltundefined noblebranundefined 2 Replies Last reply Reply Quote 1
            • fcwiltundefined
              fcwilt @noblebran
              @noblebran
              Certainly post your files here.
              We all are glad to check them over and make suggestions.
              noblebranundefined 4 Replies Last reply Reply Quote 0
                noblebran @noblebran
                @noblebran Thank you sir! Be well!
                  noblebran @fcwilt
                  @noblebran
                  Here is my load filament file (not sure if its the most efficient but it works)
                  M104 P1 S225
                  M83
                  M104 S230 T0
                  M109 S230 T0
                  G1 E300 F500       ; LOAD FILAMENT
                  M104 P1 S0
                    noblebran @fcwilt
                    @noblebran
                    UNLOAD
                    M104 P1 S225
                    M83
                    M104 S230 T0
                    M109 S230 T0
                    G1 E15 F250          ;LOAD FILAMENT
                    G1 E-600 F3500       ;UNLOAD FILAMENT
                    M104 P1 S0
                      noblebran @fcwilt
                      @noblebran
                      My start in my slicer:
                      G28; HOME
                      ;G32 (REMOVE SEMI IF YOU WANT TO REMAP)
                      G29 S1; USE STORED MESH
                      G92 E1; SET EXTRUDER TO 1
                        noblebran @fcwilt
                        @noblebran
                        I kept most of your ending script:
                        M291 R"Finishing Print" P"Please wait..." T0
                        M83                                                  ; extruder relative
                        G1 E-1 F3600                                  ; retract filament
                        M106 P0 S0                                     ; turn part fan off
                        G10 P0 S-999 R-999 ; turn extruder heater off (also sets temps to zero)
                        T-1          	             ; deselect all tools
                        M140 S0                ; set bed heater active temp to 0
                        M140 S-999           ; turn bed heater off
                        G91                       ; relative moves
                        G1 Z100 F1200      ; move the nozzle out of the way - step 1
                        G90                         ; absolute moves
                        G1 X0 Y150 F3000   ; move the nozzle out of the way - step 2
                        G28
                        M118 L0 P4 S"FT5|Print Finished"
                        M291 R"Print Finished" P"OK" T0
                        • fcwiltundefined
                          fcwilt @noblebran
                          @noblebran
                          G28; HOME
                          Does your homing script set the Z=0 datum?
                          And why are you not waiting for temps to reach their set points?
                            noblebran @fcwilt
                            @noblebran
                            G28; HOME
                            When it comes z=515. 0 would right at the print surface. I have found on the deltas this is the correct way?
                            In the config.g it calls out for the temps to reach their set points.
                            • fcwiltundefined
                              fcwilt @noblebran
                              Don't know what you mean.
                              Config.g? You mean the main config.g?
                                noblebran @fcwilt
                                0 is the print surface, so when I home z=515 and when it prints it’s .xxxx
                                Yes sir.
                                • fcwiltundefined
                                  fcwilt @noblebran
                                  Yes sir.
                                  How can you be waiting for hotends/bed to reach temps when you cannot, as a practical matter, set them in config.g?
                                  noblebranundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                    noblebran @fcwilt
                                    Yes sir.
                                    It must be done in the slicer? I choose the bed and temp setting, after I slice it in S3D, it has the code in the file (part GCODE file).
                                    • fcwiltundefined
                                      fcwilt @noblebran
                                      No, it does not have to be done in the slicer.
                                      I do it using the filament handling feature in the DWC.
                                      I have entered in a number of different filaments that I use into the DWC.
                                      For each filament entered there is a special config.g file created.
                                      My start code is in a file named print_begin.g and is invoked from the slicer with M98 P"print_begin.g"
                                      In that file I have (among other things) this:
                                      T0							; select tool 0 so extruder commands below will work
                                      M703							; configure selected filament (sets bed/extruder temps, extrusion multiplier)
                                      ; some other unrelated commands
                                      M116							; wait for temps to reach set points
                                      That M703 command invokes the special config.g file for the currently selected filament and in that file I have any commands I want unique to that filament and in that file I set, at a minimum, the bed temp, the hotend temp and the extrusion multiplier.
                                      I have found this to be an effective way to set my temps and I can use different slicers easily as the start code is on the Duet, not in the slicer.
                                      But this is just my way. You should do it in whatever way suits you the best.
                                        noblebran @fcwilt
                                        Thank you sir, I find I like to 'master' one slicer and I guess I almost put all my eggs in one basket so to speak. I will certainly take advantage of the way you are doing it but I want to get successful at printing the way I am now. I can say my load and unload macros work, ha ha... baby steps 🙂
                                        Again thank you for helping!
                                          Phaedrux Moderator @fcwilt
                                          Well, you can set the nozzle and have it take effect with a G10 and T0 to select the tool you can get it to heat right at boot. Whether or not you SHOULD is another matter entirely.
                                          • fcwiltundefined
                                            fcwilt @Phaedrux
                                            @phaedrux said in Start / Stop S3D SCRIPT / G-CODE:
                                            Which is why I said practical. Editing config.g just to specify different temperatures is not what I would call practical.
                                            But that's just me.
