    3D TOUCH need resistor?
    • sarvanundefined
      sarvan
      Hi guys,
      I am using a duet2wifi board 1.04version. recently bought a 3D TOUH sensor. but I am not sure whether the sensor output needs to be connected 240ohm resistor between the z probe in andundefined GND pin?
      here my 3D TOUCH it mentioned smart 3.1VersionundefinedWeChat Image_20210710225600.jpg
        The resistor hasn't been relevant for the past couple years now.
        Since it's a clone, it's hard to say what exactly it needs. Did they provide one? If it's a good clone of the Smart Bltouch probes, then it should be fine without.
        Also since you have a recent Duet board v1.04 it is already 5v tolerant, so shouldn't matter.
        sarvanundefined 1 Reply Last reply Reply Quote 0
        • sarvanundefined
          sarvan @Phaedrux
          @phaedrux is there any way to measure the output voltage of the probe?
            oscilloscope?
            • fcwiltundefined
              fcwilt @sarvan
              @sarvan said in 3D TOUCH need resistor?:
              If you have a meter capable of measuring DV volts in the range of 0 to 24 VDC put the black lead on GEN and the red lead on Z MIN.
              That assumes that SIG is used to control the probe.
