    Thermistor at 2000c
    Firmware installation
    1.5k
    • Bewarenundefined
      Bewaren
      The wiring it a little messy at the moment, please excuse it xD
        Well we need to verify what sensor you are actually using. Is it a thermistor or PT100. If it's a PT100 you will need the daughter board before you can use it.
        Bewarenundefined 1 Reply Last reply Reply Quote 0
        • Bewarenundefined
          Bewaren @Phaedrux
          This is the thermistors or PT100 I am using, not sure if it helps identify it
            I believe the E3D PT100s use red wires and the thermistors are blue. But I'm not sure if that's a hard rule, but I think that's generally the case.
            https://e3d-online.com/collections/printer-parts-electrical/products/thermistor-cartridge
            https://e3d-online.com/collections/printer-parts-electrical/products/pt100-temperature-sensor
            You should try to verify with your invoice or email confirmation from your purchase to be sure.
            You'll need a daughter board to be able to read the PT100.
            https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
            https://e3d-online.com/products/pt100-daughterboard-for-duet-wifi?_pos=4&_sid=8859bba4b&_ss=r
            • Bewarenundefined
              Bewaren
              Alright I can confirm it's a PT100, found the invoice. I will get one ordered asap.
                Glad we got that sorted out. Once you have the daughterboard installed and connected you'll need to make a change to your temp sensor config to point to the PT100.
                M308 S1 P"spi.cs1" Y"rtd-max31865"             ; configure sensor 1 as thermocouple via CS pin spi.cs1
                M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                sg2020undefined 1 Reply Last reply Reply Quote 0
                  A Former User @Phaedrux
                  suppose its still possible they could have shipped the wrong one, to be sure use a multimeter and measure the resistance at room temperature; PT100 should be about 100 ohm, and PT1000 should be about 1000 ohm.
                  (Techincally PT100 is 100 ohm at 0°C and closer to 110 at room temperature, and 1100 ohm for PT1000)
                  • Bewarenundefined
                    Bewaren @A Former User
                    @bearer comes back at 109 ohm
                    • sg2020undefined
                      sg2020 @Phaedrux
                      @phaedrux I was also trying to get my E3D PT100 sensor to work and your code helped. Could you explain why this works? Why does it need p"spi.cs1"? why is it configuring the sensor 1 as a thermocouple?
                        Phaedrux Moderator @sg2020
                        @sg2020 said in Thermistor at 2000c:
                        Ignore the comment on that line. It's not actually a thermocouple, that's just the comment that the config tool has added. It seems to be the same regardless of what type of daughterboard you've chosen.
                        The important thing is that you're telling it what pin you're using (spi.cs1) and what type of daughterboard chip you're using (rtd-max31865).
                        tony449777undefined 1 Reply Last reply Reply Quote 0
                        • tony449777undefined
                          tony449777 @Phaedrux
                          @phaedrux So if the channel 1 on the card is “spi.cs1”
                          And you have one daughter board with the two ports, then is the second port for the same card “spi.cs2”?
                          Is there any pages that you can recommend that would help me understand what this means?
                            Phaedrux Moderator @tony449777
                            @tony449777 said in Thermistor at 2000c:
                            https://duet3d.dozuki.com/Wiki/Temperature_sensors
                            https://duet3d.dozuki.com/Wiki/PT100_temperature_sensor_daughter_board
