Solved Can't seem to get the z-axis motors working.
I've working on a scratch built corexy printer for a while now and am in the process of working out all the kinks with using a duet2 wifi board. I've finally managed to get my x and y axes to home properly using limit switches. I was going to use a bl touch for the z-probe but that won't do anything right now so I disconnected it and installed a limit switch for the z-axis as well. When I select home z nothing happens. Not sure what I'm doing wrong on this one and could use a bit of help on how to approach this. Thanks
@rsbkh please post your config.g and homing files. Also test Z movement by sending these commands:
G91
G1 H2 Z10
G1 H2 Z-10The first G1 should raise the print head or lower the bed by 10mm. The second should do the opposite.
The Z axis won't allow you to manually move it until it's been homed. You can force it to be homed to a position with G92 Z100, then you can use the commands DC42 gave to see if the Z motors are moving at all.
Could you also provide the results of M122 and M98 P"config.g" please?
Seems there was a bad wire connection. LED's are now on for the z-axis motors and I can get it to move up and down now. Looks like a bad connection on the extruder as well but I'll take care of that tomorrow.
Any advice on getting a BL touch to work properly? -
@rsbkh said in Can't seem to get the z-axis motors working.:
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
