    height map not displaying in Firefox
    Duet Web Control
    965
    • jrsphotoundefined
      jrsphoto
      Also just updated the Duet Wifi Server from 1.22 to 1.23. No effect on my inability to view the height map.
      • jrsphotoundefined
        jrsphoto
        So I decided to try another browser. I had been using Firefox, but just now tried Chrome. This works. So am I dealing with corrupt cache? I'll flush cache on Firefox and try that
        • jrsphotoundefined
          jrsphoto
          I've cleared all the cache from Firefox and it still won't load the height map. I'm stumped at this point.
            I've modified the title and moved to the DWC forum.
              dc42 administrators @Phaedrux
              If you open the debugging console (usually control-shift-J AFAIR), are any JavaScript exceptions shown?
              • jrsphotoundefined
                jrsphoto
                These are the errors I'm seeing now from the developer tools, console tab. For the heck of it, I booted to linux mint and tried things with firefox there. Thinks kind of worked but when I went to extrude 20mm of filament, it would do the extrusion but the buttons for extrude/retract, would change to a spinning icon and never come back.
                  dc42 administrators @jrsphoto
                  @jrsphoto said in height map not displaying in Firefox:
                  That's a known issue between DWC2 and RRF 2.05RC1. It will be fixed in 2.05RC2.
                  With luck, @chrishamm will be along to reply to the height map display issue.
                  jrsphotoundefined TonyGRundefined 2 Replies Last reply Reply Quote 0
                  • jrsphotoundefined
                    jrsphoto @dc42
                    @dc42 Thank you. I'll wait for his reply.
                    • chrishammundefined
                      chrishamm administrators
                      It looks to me as if WebGL is disabled somewhere in your Firefox settings. I just created a new heightmap file and tried to display it and that worked without problems for me.
                      I suggest you open about:config and search for "webgl.disabled". Make sure it is set to "false". If that's the case, I suggest you reset your Firefox profile and try again.
                      Duet software engineer
                      • TonyGRundefined
                        TonyGR @dc42
                        @dc42 I got this morning same problem. Chrome, DWC 3.2.2 on firmware 3.3 wnd DWS 1.26.
                        I enable Webgl as found lower in this post, checke my config which was same as always, but the problem for some reason is here.
                        On Crtl/Shift/J it gives me:
                        Error: Invalid Height Map
                        at new ExtendableBuiltin (app.56671d18.js:42)
                        at InvalidHeightmapError._createSuperInternal (createSuper.js:12)
                        at new HeightmapError (errors.js:99)
                        at new InvalidHeightmapError (errors.js:102)
                        at generateMeshGeometry (3d.js:229)
                        at VueComponent.showHeightMap (HeightMap.vue:332)
                        at VueComponent.showCSV (HeightMap.vue:283)
                        at _callee2$ (HeightMap.vue:476)
                        at tryCatch (runtime.js:63)
                        Any ideas why? I found the csv and i even run a new G29 and it updated the info, but it does not show
                          dc42 administrators @TonyGR
                          @tonygr update DWC to 3.3 to match the firmware version.
                          TonyGRundefined 1 Reply Last reply Reply Quote 0
                          • TonyGRundefined
                            TonyGR @dc42
                            @dc42 i thought there was not a 3.3 since i used the complete Zip to update. I did standalone the dwc to 3.3 and worked great. Thank you
