    4 pin 5V fan on 3 Mini
    • richardmckennaundefined
      richardmckenna
      Hi, I have a 4 pin 5V fan I would like to use as a hot end fan on the on 3 Mini. Just want to check how to wire it.
      I'm supplying EXT 5V anyway to power LEDs.
      If I use OUT 3 to control the fan, can I connect as follows
      Fan Black to OUT3 - GND
      Fan Yellow to OUT3 - out3.tach
      Fan Blue to OUT3 - out3-
      Can I just connect Fan Red to 5V PWM - 5V_EXT ?
      Thanks
        dc42 administrators @richardmckenna
        @richardmckenna yes that should work.
        richardmckennaundefined 2 Replies Last reply Reply Quote 0
          richardmckenna @dc42
          @dc42 Perfect thanks 🙂
            @dc42 ok not quite working. If I config like:
            M950 F1 C"out3" Q25000
            M106 P1 C"Fan" S0 H-1
            Also tried inverting the pin with, which I think you are supposed to do with 4 wire PWM fans
            M950 F1 C"!out3" Q25000
            Calling M106 P1 S1 and M106 P1 S0 doesn't do anything.
            If I disconnect the Blue PWN wire the fan operates at 100% as it should (according to it's datasheet) so it's getting power.
              richardmckenna
              ok I have got somewhere, connecting as above I could not get it to work.
              So I'm now connected:
              Fan Red (+) - VFD-5V_EXT
              Fan Black (-) - VFD-GND
              Fan Blue (PWM) - VFD-out6_buff
              Fan Yellow (FOO) - OUT3-out3.tach
              and in the config I have:
              M950 F1 C"vfd+out3" Q25000
