    DUET3MINI5+
    Firmware installation
    529
    • ansonyangundefined
      ansonyang
      Please share a BOOTLOADER of DUET3MINI5+? Thank you
      • tecnoundefined
        tecno
        @ansonyang
        https://duet3d.dozuki.com/Wiki/Getting_Started_with_Duet_3_Mini_5plus
        ansonyangundefined 1 Reply Last reply Reply Quote 0
          ansonyang @tecno
          @tecno BOOTLOADER
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @ansonyang
            @ansonyang
            https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Firmware#Section_Programming_the_bootloader
              ansonyang @tecno
              @tecno Sorry, maybe I didn’t describe clearly
              I want to upload BOOTLOADER to blank ATSAME54
                dc42 administrators @ansonyang
                @ansonyang https://github.com/Duet3D/uf2-samdx1/releases
                  ansonyang @dc42
                  @dc42 After the BOOTLOADER is uploaded to the blank ATSAME54, the LED flashes slowly and the DUETBOOT disk is added, but there is no COM display on the motherboard. When the firmware UF2 file is copied to DUETBOOT, the LED flashes quickly, and then the LED turns off, and the motherboard does not respond.
                  Thank you
                  juancarundefined 1 Reply Last reply Reply Quote 0
                  • juancarundefined
                    juancar @ansonyang
                    @ansonyang hi could you install the bootloader in the duet3 mini 5+? What file did you use it? Thanks
                      Phaedrux Moderator @juancar
                      @juancar said in DUET3MINI5+:
                      @dc42 said in DUET3MINI5+:
