Solved First home Problem
Hi , i changed the bltouch for Pinda sonda v2 and now when i turn on the printer and click home all , X axis dont move and Y axis move to home . After this homing when i repeat Home ALL ith work fine , X run to home and Y run to home .
Someone help ??
Thanks
Files :
config.g
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jun 28 2021 17:13:06 GMT+0200 (Central European Summer Time); General preferences
M550 P"Prusa i3" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards X
M569 P1 S1 ; physical drive 1 goes forwards Y
M569 P2 S0 ; physical drive 2 goes forwards Z
M569 P3 S1 ; physical drive 3 goes forwards E0
M92 X100.40 Y99.16 Z400.24 E394.00 ; set steps per mm
M201 X2000.00 Y2000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M906 X650 Y650 Z650 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-7.5 Y-2 Z0 S1 ; set axis minima
M208 X250 Y210 Z240 S0 ; set axis maxima; Endstops
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P5 C"^zprobe.in" I1 H0.7 F400 T8000 A20 S0.003 ; pinda v2
M308 S2 P"e1_temp" A"Pinda V2" Y"thermistor" T10000 B3950 ; pinda v2
G31 P500 X45 Y20 Z0.05 ; set Z probe trigger value, offset and trigger height
M557 X7.5:215 Y10:195 S20 ; define mesh grid; Heaters
M915 X Y S8 R1 ; zmena sensityvity na motoroch X a Y
T0 ; Nastavenie na Hrot 0homeall.g
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Jun 27 2021 18:14:24 GMT+0200 (Central European Summer Time)
M400 ; wait for current moves to finish
M913 X70 Y70 ; drop motor current to 70%
M400 G91 ; relative positioning
G1 H2 Z5 F8000 ; lift Z relative to current position
G1 H1 X-250 Y-210 F8000 ; move quickly to X axis endstop and stop there
G90 ; absolute positioning
G1 X80 Y85 F9000 ; move to middle of bed plus probe offsets
G30 ; home z0homez.g
; homez.g
; called to home the Z axis
T0 ; select first hot end
G91 ; Relative coordinates
G1 Z5 F200 ; Lower bed.
G4 P800 ; Dwell for 500ms - to ensure bed is down
G90 ; Absolute positioning
G1 X35 Y15 F3000 ; Go to first bed probe point and home the Z axis
G30 ; Calibrate Z-axis
G1 Z1 F200 ; Raise bed to 1mm. -
Your homeall.g doesn't home Z the same as homez.g does.
Is that intentional?
@fcwilt i dont know , its copied from internet , i total new in DUET .
Have you tuned your sensorless homing stall detection yet?
https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?
@phaedrux
M122 :
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F2MS4-7J1D8-3S06K-KZSWD
Used output buffers: 3 of 24 (11 max)
Static ram: 23876
Dynamic ram: 75292 of which 0 recycled
Never used RAM 15248, free system stack 184 words
Tasks: NETWORK(ready,12.2%,227) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,340) MAIN(running,84.4%,461) IDLE(ready,3.3%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:00:29 ago, cause: power up
Last software reset at 2021-07-15 20:08, reason: User, GCodes spinning, available RAM 15248, slot 1
Error status: 0x00
Step timer max interval 0
MCU temperature: min 16.7, current 20.4, max 20.6
Supply voltage: min 12.5, current 12.6, max 12.7, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-07-20 18:06:25
Cache data hit count 1094592074
Slowest loop: 5.48ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.8ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.56ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address 60:01:94:2e:9b:35
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24240
WiFi IP address 192.168.0.220
WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled - WiFi -
Thanks. Nothing looks out of place. Now the question remains:
@phaedrux im using only this : M915 X Y S8 R1 ;
@savethepetko Then I suggest you go through that link and tune the settings to suit your printer.
@phaedrux said in First home Problem:
Thank i changed sensitivity and its working fine now .
