Cannot Connect to Duet 3 Web Control
@phaedrux Could you point me back to where you listed the folders I need? I don't see it, I must be blind. I download the 3.3 firmware and then just put it in the www folder?
@phaedrux said in Cannot Connect to Duet 3 Web Control:
@frank-0 said in Cannot Connect to Duet 3 Web Control:
@kb58 After using Bossa to reset my firmware, I cannot find the config.g file. The sys folder changed to this
I have never seen anything like that before.
I suggest you get a clean new SD card, format it as FAT32, and then start fresh from there.
Create the following folders
sys
macros
www
gcodes
menu
filamentsCreate a fresh config file set from here: https://configtool.reprapfirmware.org/Start
Fill out the info to the best of your knowledge. We just want a starting point.
What firmware bin file version did you use to flash with Bossa? 3.3?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWebControl-SD.zip
Download that zip file and extract it into the /www/ folder.
That should get your SD card back to a working state.
Here it is.
@phaedrux What should be in the macros/gcodes/menu/filaments folder? I can make the folders, but Im not sure what to put in them.
@frank-0 Nothing. They will be empty.
The gcodes folder is where your uploaded print files will go. menu is a folder for menu files when using a rotary encoder display. And filaments is used to store filament profiles if you set them up. They just need to exist otherwise you'll get a little warning that they are mising.
Oh, and the firmware folder is where firmware files will go in future
@phaedrux I got this set up and have this currently:
and I extracted 3.3 firmware into www folder. YAT still doesn't really work. M552 S1 P192.168.2.2 just responds with ok, not network running.
@frank-0 There is also no lights lit up at bottom of the ethernet port
Don't do that.
If you send M552 what does it say?
Don't forget to add a folder called firmware.
@phaedrux www folder :
YAT literally just says "ok", like in the images above from a while ago.
Should I just make an empty folder called "firmware"?
Are you able to ping 192.168.2.2?
What IP is your computer using?
Have you tried a different cable?
Do the lights on the ethernet port light up if you connect to your router instead? even briefly?
@phaedrux Timed out, is unreachable. Can't ping it
@phaedrux Computer is using an assigned IP address I changed in the control panel. It is 192.168.2.1. I tried different cable and no the lights don't light up at all.
Not with the router either?
@phaedrux Yeah doesn't light up with either computer or router
Alright, I think we've solved the firmware problem since it's able to speak with YAT now and it is taking and executing commands.
I think we have the SD card issue solved.
Can you post your current config.g from the /sys/ folder please?
Copy and paste the text please.
@phaedrux ; Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Jul 15 2021 14:31:46 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M552 P192.168.2.2 S1 ; enable network and set IP address
M553 P255.255.255.0 ; set netmask
M554 P192.168.1.254 ; set gateway
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
; WARNING: No endstops configured; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp0
M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M950 F1 C"!out6" Q500 ; create fan 1 on pin !out6 and set its frequency
Does this match the gateway you have set on your PC?
On your PC open a command prompt and send ipconfig and see what it says.
@phaedrux I currently use one ethernet running to the router so my computer has wifi. Then I use another ethernet connected to the board and the desktop (via USB adapter). Only one of the ethernet cords shows information about IP/gateway. And this one does not match
