    Height map makes my bed look warped…Why???
    4.3k
    • Aflac01undefined
      Aflac01
      so yes, 9 made the calibration look good, but it did not make it print good. back to 6 i guess
      • number40fanundefined
        number40fan
        What is wrong with the print?
        • Aflac01undefined
          Aflac01
          Things where great near the center, but out near the edges it went right off the bed. I guess it
          changing the arm length by 14mm was not the best
            number40fan
            How big is your bed?
            • Dougal1957undefined
              Dougal1957
              try 8 factor cal
              • Aflac01undefined
                Aflac01
                Is there a list somewhere of what the different factors are? i saw one once but it only went up to 7.
                • Aflac01undefined
                  Aflac01
                  https://duet3d.com/wiki/Calibrating_a_delta_printer
                  found it, going to give 8 a try
                  • Aflac01undefined
                    Aflac01
                    I think that is better, you can even see on the heightmap where i have binder clips holding the heatspreader plate down.
                    Calibrated 8 factors using 17 points, deviation before 0.087 after 0.056
                      number40fan
                      Earlier you said it went off the bed. Are you saying it tried printing off the edge of the bed? Is your build plate 270mm+?
                      • Aflac01undefined
                        Aflac01
                        it actually went off during a calibration not a print, the first time through the calibration it looked good, later it went off the edge, yes the bed itself is 310,
                          number40fan
                          Is this a Rostock, by chance?
                          • Aflac01undefined
                            Aflac01
                            in concept yes…but i think the heat bed is the only actual real rostock part,
