Height map makes my bed look warped…Why???
4.3k
    Aflac01
    i thought it only went to 7
      number40fan
      Nope, all the way to 9.
        Forgvn77
        I ran into more issues when I calibrated over 6 factors. Six ended up working great for me. More wasn't better in this case when I set up my delta. The trigger height corrections are what you'll need to establish and plug in. Once you get those nailed, you'll be off and running.
        Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
        Make A Difference!
          Aflac01
          9 factors is looking better for me
          im using a piezo in the print head so i have no variation in trigger height
          Calibrated 9 factors using 17 points, deviation before 0.159 after 0.034
            number40fan
            That's a lot better. What are your M665 and M666 changes?
              Aflac01
              config has
              M665 R135.59 L330.77 B135.59 H235.444
              M666 X0 Y0 Z0
              after calibration i got
              M665 Diagonal 344.383, delta radius 138.954, homed height 235.472, bed radius 135.6, X -0.050°, Y -0.359°, Z 0.000°
              M666 Endstop adjustments X-0.20 Y0.13 Z0.07, tilt X-0.23% Y0.22%
                number40fan
                M500 will save that to override.g and if you have M501 at the end of your config.g, it'll use those settings.
                  Aflac01
                  so yes, 9 made the calibration look good, but it did not make it print good. back to 6 i guess
                    number40fan
                    What is wrong with the print?
                      Aflac01
                      Things where great near the center, but out near the edges it went right off the bed. I guess it
                      changing the arm length by 14mm was not the best
                        number40fan
                        How big is your bed?
                          Dougal1957
                          try 8 factor cal
                            Aflac01
                            Is there a list somewhere of what the different factors are? i saw one once but it only went up to 7.
                              Aflac01
                              https://duet3d.com/wiki/Calibrating_a_delta_printer
                              found it, going to give 8 a try
                                Aflac01
                                I think that is better, you can even see on the heightmap where i have binder clips holding the heatspreader plate down.
                                Calibrated 8 factors using 17 points, deviation before 0.087 after 0.056
                                  number40fan
                                  Earlier you said it went off the bed. Are you saying it tried printing off the edge of the bed? Is your build plate 270mm+?
                                    Aflac01
                                    it actually went off during a calibration not a print, the first time through the calibration it looked good, later it went off the edge, yes the bed itself is 310,
                                      number40fan
                                      Is this a Rostock, by chance?
                                        Aflac01
                                        in concept yes…but i think the heat bed is the only actual real rostock part,
                                        19 out of 28
