Using Accelerometer for Input Shaping
999
    StaticRed
    Hey, so i got finally my accelerometer running on my 3D Printer. I can run tests and collect the data and look at them. But what now? How can i use this data to use Input Shaper on my Printer. In the documentation nothing about this is listet at the moment.
      Configure the input shaper and do some test prints.
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M593_Configure_Input_Shaping
      A ringing test print works well and you can change the shaper being used every several layers on the fly by sending a new M593.
      https://www.klipper3d.org/prints/ringing_tower.stl
      undefined 1 Reply Last reply 17 Jul 2021, 18:12 Reply Quote 0
        StaticRed @Phaedrux
        @phaedrux thank you for the quick answer, i will test it out
          I've updated the Input Shaping page with my previous post since it doesn't really get mentioned anywhere else as far as I found.
          https://duet3d.dozuki.com/Wiki/Input_shaping
          https://duet3d.dozuki.com/Wiki/Accelerometers
          The documentation is a little light at the moment and will improve as the feature is further developed. Please feel free to share any suggestions or questions to help us improve it.
          undefined 1 Reply Last reply 18 Jul 2021, 11:03 Reply Quote 1
            StaticRed @Phaedrux
            @phaedrux it would be good to know on how to correctly analyze the data i now gotten. Date for X Axis looks something like this
            6f52344c-9bde-426a-8dff-08b74c52d406-image.png but which frequency should i now try to cancel out, like the 7hz one or more like the 43hZ one?
            undefined 1 Reply Last reply 18 Jul 2021, 12:58 Reply Quote 0
              martin7404 @StaticRed
              @staticred 42-43 your machine shakes a lot here is mine for both X Y, it is a big machine with all metal parts and hemera. The carriage is about 1.5 kg
              Muldex IDEX Duet2+Duex5
              Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
              Sapphire Pro with Duet2, with closed-loop motors
              custom high temp E3D tool changer with Duet2+Duex
              undefined 1 Reply Last reply 18 Jul 2021, 13:27 Reply Quote 0
                StaticRed @martin7404
                @martin7404 what speeds did you use for the testings? I used 30000mm/min to test it. My normal printing speed at around 10000mm/min has kind of the same readings as yours. But my machine is also at the moment super small and the carriage ways about 300g.
                undefined 1 Reply Last reply 18 Jul 2021, 13:46 Reply Quote 0
                  @staticred 24000
                  8 out of 8
