    RRF 3.4 input shaping preview available
    Beta Firmware
    25
    205
    25.9k
    • JenPetundefined
      JenPet @dc42
      @dc42 the two contour lines get thinner and thinner at the end so that there is a gap between them.
      Now I try to lower PA value again.
        dc42 administrators @JenPet
        @jenpet said in RRF 3.4 input shaping preview available:
        If you mean the two perimeter lines, they are joined in the perimeter at the top, joined for part of the length of the perimeter on the right, and not joined at all in the perimeter at the bottom. The difference between top and bottom suggests to me that you have chosen an unfortunate wall thickness and the slicer has failed to ensure consistent infill by altering the extrusion widths - so that whether the perimeters are joined or not is very sensitive to small changes. I am assuming that the thickness of all three walls is supposed to be the same.
        JenPetundefined Egon.Netundefined 2 Replies Last reply Reply Quote 0
        • CadetCundefined
          CadetC @dc42
          @dc42 said in RRF 3.4 input shaping preview available:
          @skrotz @jenpet I've put new binaries at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0.
          I just tested lates bin. - no clunking and nothing suspicious when printing
          Test print done :speed 200mm/s, accel6000mm/s2 . PA 0.022
          print sequence from bottom to top:
          M593 P"none"
          M593 P"ei2" F62.7
          M593 P"ei3" F62.7
          M593 P"zvdd" F62.7
          M593 P"zvd" F62.7
          I think best result with ei3 , second zvd.
          First print where i could use zvd without any problems
          There still problem with DSF compatibility(???)
          Print status is 100% right away in DWC and PanelDue
          • JenPetundefined
            JenPet @dc42
            @dc42 I have lowered the PA value to 0.04 from 0.08 and now it looks better. I tried the same thing a few days ago but there was no inprovement. I think is was my mistake, sorry. Thank you for support.
              @jenpet thanks. Your previous report was very useful because of the reported step errors, and led me to fix a bug.
                dc42 administrators @CadetC
                @cadetc thanks. We are looking to release 3.4beta2 tomorrow, including the updated DSF.
                • skrotzundefined
                  skrotz @dc42
                  @dc42 I did a quick print with this latest firmware (PA 0.12, ei2 input shaping enabled as per usual) and can't say I see a significant difference between this firmware and the previous one on my print, although I'd swear that the previous one still had a tiny bit of "clunkiness" and this one seemed completely normal with no hint of a clunk whatsoever. No hiccups or errors in the M122 report. Like the just previous firmware, I don't see extrusion blobs or zits like were happening before -- I'll need to do some comparison prints with RRF 3.3 and this firmware to see if the minor extrusion issues I feel are present are different from RRF 3.3 or not. All in all, great progress though, and certainly seems ready for more people to start doing prints and comparisons with RRF 3.3 and testing input shaping. Very exciting.
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta2-inputshaping (2021-08-02 19:33:23) running on Duet WiFi 1.02 or later + DueX5
                  UPDATE: I did a baseline print with RRF 3.3 to compare with (DAA enabled at 41hz, PA 0.12), and the minor extrusion issues I was seeing in the latest 3.4 print are there as well in the 3.3 print.. it seems like something that could be improved on but it's not introduced by 3.4. So this latest 3.4 seems quite good to go.
                  • MikeSundefined
                    MikeS
                    @dc42 thanks for the new release. It seems that is running good, you should call the next beta "clunk free".
                    However i noticed i can't stop during mid-print because the firmware goes to status "generic.status.cancelling" when cancel button is pressed. From there i can't press the cancel anymore and the printer won't start a new job
                    M122
                    3/8/2021, 19:41:13 	M122
                    Board ID: 0JD0M-9P61A-J8PS8-6JTD2-3SJ6R-9USUU
                    Used output buffers: 3 of 24 (24 max)
                    Static ram: 23932
                    Dynamic ram: 76624 of which 188 recycled
                    Never used RAM 7376, free system stack 106 words
                    Tasks: NETWORK(ready,14.1%,217) HEAT(delaying,0.0%,326) Move(notifyWait,1.2%,277) DUEX(notifyWait,0.0%,24) MAIN(running,84.5%,420) IDLE(ready,0.1%,29), total 100.0%
                    Owned mutexes: WiFi(NETWORK)
                    Last reset 00:25:32 ago, cause: software
                    Last software reset at 2021-08-03 19:15, reason: User, GCodes spinning, available RAM 7376, slot 0
                    Error status: 0x04
                    Aux0 errors 0,0,0
                    Step timer max interval 0
                    MCU temperature: min 39.5, current 40.2, max 40.7
                    Supply voltage: min 23.6, current 23.8, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                    Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/886/886, gc cycles 0
                    Driver 0: position 28800, standstill, SG min/max 0/1023
                    Driver 1: position -27200, standstill, SG min/max 0/1023
                    Driver 2: position 13510, standstill, SG min/max not available
                    Driver 3: position 0, standstill, SG min/max 0/1023
                    Driver 4: position 0, standstill, SG min/max not available
                    Driver 5: position 0, standstill, SG min/max 0/1023
                    Driver 6: position 0, standstill, SG min/max 0/248
                    Driver 7: position 0, standstill, SG min/max 0/1023
                    Driver 8: position 0, standstill, SG min/max 0/1023
                    Driver 9: position 0, standstill, SG min/max not available
                    Driver 10: position 0
                    Driver 11: position 0
                    Date/time: 2021-08-03 19:41:13
                    Slowest loop: 191.24ms; fastest: 0.14ms
                    === Storage ===
                    Free file entries: 10
                    SD card longest read time 1.8ms, write time 5.4ms, max retries 0
                    DMs created 83, segments created 46, maxWait 15496ms, bed compensation in use: mesh, comp offset 0.000
                    === MainDDARing ===
                    Scheduled moves 10346, completed moves 10346, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                    === AuxDDARing ===
                    Heater 0 is on, I-accum = 0.2
                    Heater 1 is on, I-accum = 0.5
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Code queue is empty
                    === DueX ===
                    Read count 1, 0.04 reads/min
                    === Network ===
                    Slowest loop: 209.69ms; fastest: 0.00ms
                    HTTP sessions: 1 of 8
                    - WiFi -
                    Network state is active
                    WiFi firmware version 1.24
                    WiFi MAC address 48:3f:da:79:65:eb
                    WiFi Vcc 3.34, reset reason Power up
                    WiFi flash size 4194304, free heap 27144
                    WiFi IP address 192.168.1.230
                    WiFi signal strength -23dBm, mode none, reconnections 0, sleep mode modem
                    Clock register 00002002
                      dc42 administrators @MikeS
                      @mikes, that bug was fixed in the 3.4.0 beta 2 release.
                      MikeSundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      • MikeSundefined
                        MikeS @dc42
                        @dc42 i lost one day and the beta is already out! thank you!
                          dc42 administrators @dc42
                          I wish to thank all who have tested the RRF input shaping previews. With your help, I believe I have the new step generation code working well including input shaping and pressure advance. This has given me the confidence to include the new code in RRF 3.4.0 beta 2 which we released today.
                          Please upgrade to that release, and start new threads for any issues you encounter with it.
                          1 Reply Last reply Reply Quote 5
                          • Egon.Netundefined
                            Egon.Net @dc42
                            I also have problems with pressure advance and input shaping with de PA values I already got finetuned without input shaping.
                            Top one: input shapping ei3 @48Hz + PA 0.1 (orbiter extruder direct)
                            Bottom one: just input shapping and no PA
                            Both 100mm/sec, 6000mm/s2 acceleration
                            You can see corners are ok with the PA, and bulges with no PA...
