    PanelDue Firmware 3.3.0-rc5 released
    PanelDue
    • mfs12undefined
      mfs12
      Release Notes 3.3.0-rc5
      This release requires RepRapFirmware 3.3 or later.
      Version 2 (after August 2016) and Version 3 PanelDue are supported.
      Features:
      • added Russian translation
      • added support for emerging backlight mp3302 chip
      • renamed 'Print' tab into 'Status'
      • added slicer time
      • added simulated time
      • removed layer time
      • faster and consistent display of printer status
      • display IP address of printer in Setup tab
      • adaption to changes of object model
      • allow assignment of fans, extruders and heaters to multipls beds, chambers or tools
      • added debugging interface to write debugging information as gcode comments to the reprap uart
      • increase request timeouts to constant 2s
      • added support for new printer state cancelling
      • deactivate screensaver when a new M291 message arrives; S0 and S1 leave the screensaver active, S2 and S3 leave screensaver deactivated until user action
      Bug fixes:
      • gracefully handle parsing errors in M409 K"<key>" requests
      • show warning instead of error when JSON parsing errors occur
      • fix displaying of percent sign
      • fix displaying of M291 dialogs
      • fix sending filename in M37
      • fix unresponsive screen when showing m291 message while screensaver is active
      • fix updating of simulated time left during print
      • fix displaying of standby temperature row
      • fix state reporting in JSON parser warning
      Downloads and flashing instructions:
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.3.0-rc5
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Visit me on github at https://github.com/mfs12/
      • royal32undefined
        royal32
        I've been on RC3 with no issues, I just updated to RC5 and my temperature values are updating very slowly, every 2-4 seconds or so. Just checked RC4 and it does the same thing, is this because of the increased request timeouts to constant 2s?
        4x Railcore 300ZL in various states of completion
        mfs12undefined 1 Reply Last reply Reply Quote 0
        • mfs12undefined
          mfs12 @royal32
          @royal32 i am not sure. the timeout wait just longer for a done request to timeout and handling the next. if the response come immediately then the next request should fired. Do you have any errors in the console tab?
          royal32undefined 1 Reply Last reply Reply Quote 0
          • royal32undefined
            royal32 @mfs12
            @mfs12 Hmm. No errors in the console.
            • mfs12undefined
              mfs12
              Hey @royal32, thanks for reporting. You are absolutly right. I had a look into it and found a fix. Please be patient for the fix.
              Created an github issue for that. Any fixes are going to be reflected there.
              https://github.com/Duet3D/PanelDueFirmware/issues/172
              mfs12 created this issue in Duet3D/PanelDueFirmware
              closed Polling intervals are too slow #172
              royal32undefined 1 Reply Last reply Reply Quote 2
              • royal32undefined
                royal32 @mfs12
                @mfs12 Glad you found the problem, great work!
