    No wifi as the U3 blew
    692
      jay_s_uk
      @stout you can use a USB cable to supply the 5v. If its not working with the USB cable then you have more issues with the board
      Stoutundefined 1 Reply Last reply Reply Quote 0
      • Stoutundefined
        Stout @jay_s_uk
        @jay_s_uk said in No wifi as the U3 blew:
        Yes, I'm using a USB cable now and it's working but what I wanted to do was to hook up power to the backside of the USB- ort internally from the board, and my thought was If it was possible to use a wire from the "always on" fan directly to the USB VBUS pad on the PCB?
          jay_s_uk @Stout
          @stout there is no 5v power available on the board because the U3 has blown.
          Where are you expecting to find 5v?
          • Stoutundefined
            Stout @jay_s_uk
            I don't know but the fan sockets are supplying 5V, right?
              jay_s_uk @Stout
              @stout the fans are supplied from U3 or external 5v power, i.e. USB or an external 5v supply.
              So again, where are you expecting to find 5v on the board if the 5v buck converter is blown?
              Stoutundefined 1 Reply Last reply Reply Quote 1
              • Stoutundefined
                Stout @jay_s_uk
                Is it possible to connect an external 24-5V buck convertor from the PSU to the USB?
                The hole idea is to get rid of the external USB cable or an extra external power source.
                  jay_s_uk @Stout
                  @stout yes, you can connect a buck converter to the 5v external connector.
                  • Stoutundefined
                    Stout @jay_s_uk
                    Then the problem would be solved and I have a working wifi as nothing has happened. I have a couple of buck converters laying around so I'll give it a try.
                    Thanks for you support jay!
                    • Stoutundefined
                      Stout
                      Just to clear things out from my head. The external 5V socket give power to the board as the USB port does?
                        jay_s_uk @Stout
                        @stout yea
                        • Stoutundefined
                          Stout
                          Just a follow up...
                          I applied a buck converter to the external 5V power and the wifi is working again as nothing has happened.
                          So I'm pleased that I asked for help as I probably would not think of getting the power from the external 5V. It was easier than I thought to fix it.
