Cant Connect Maestro
Hello!
For some reason, I cant connect my new Maestro board, I followed the guide with no luck.
I know the board is ok, becase I have 2 Maestros and I have the same result with both...
With the M115 command I have this:
FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.01beta1(RTOS) ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2018-06-23b1
With M552:
Network is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
ok T0:2000.0 /0.0 T1:2000.0 /0.0 B:2000.0 /0.0
The ethernet cable is working because I tested with my computer.
I also have a Duet 2 ethernet wotking in the same network, but I think the Mac address is different.
Mestro: MAC: be:76:48:38:53:34
Ethernet: MAC: be:ef:de:ad:fe:eeI could not find anywhere in the forum the same issue.
Thanks in advance!!
@erickindi if you're setting up as a new board, update the firmware to 3.3
The quickest was to do this would be with bossa.
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_2 -
@jay_s_uk Thanks for the reply! But I can connet with YAT or Pronterface, I just cant connect to the network...
@erickindi still worth upgrading.
If you can use YAT, use fallback procedure 1 to upgrade, taking note that you should go to 2.05.1, then 3.0 and then 3.3 -
@jay_s_uk
It is reporting that the "iap4s.bin" is not found, I tried renaming the "DuetMaestroIAP.bin" file to "iap4s.bin" but it still reports the same old firmware with the M115 commmand.. Is this the correct procedure? Thanks -
@erickindi no. which firmware are you trying to upgrade from/to?
still at 2.01beta1? -
@jay_s_uk From 2.01beta1(RTOS) to 3.0
@erickindi i believe its this one https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetMaestroIAP.bin
@jay_s_uk do I have to rename to "iap4s.bin" in the sys folder? I tried both ways, and it does not update..
Why it is important to update to 3.0 now?
Thanks again -
@erickindi sorry, i gave you the wrong one
go for this one https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/iap4s.bin
there have been lots of updates to improve the ethernet so its worth making sure you are running up to date firmware first -
@jay_s_uk Thankyou so much! Now it is updated to the 3.3 firmware! (3.0 and then to 3.3).
But I get the same error connecting to the web control..The command line I use:
SENDING:M552 S1 P192.168.1.158
Network running, IP address = 192.168.1.158
M552
SENDING:M552
Network is enabled, configured IP address: 192.168.1.158, actual IP address: 192.168.1.158But there is nothing in the 192.168.1.158 Ip
If I change to 0.0.0.0 it is the same thing... -
@erickindi what OS are you on?
Can you try and load the page using an incognito tab?
Can you also try adding the subnet mask and gateway? -
@jay_s_uk Im on Windows using chrome. But I am using my Duet Ethernet in my other printer with no problems.
@jay_s_uk Thank you so much for your help!!!
For some reason, when I conected to another router, it worked!!
