    Duet 3 does not restart
    42
    2.1k
    • kvi94undefined
      kvi94
      I have implemented a power control using a SSR and pushbutton switch for my duet 3 6HC, additionally I have two enclosure fans rated at 9.2W connected to the 24V always-on.
      When I perform M999 with above setup, the board does not restart. However when both fans are disconnected, the board performs M999 perfectly.
      I am still at configuration stage and I am guessing this issue might affect M916 (power failure) process in the future.
      Any ideas as to how I can solve this issue?
      Having a limited electrical knowledge, I was thinking about using a small 24vdc relay instead of powering the fans from the 24v always-on. But I am not sure whether this will solve the issue.
      Thank you.
      MdeJongundefined Phaedruxundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • markzundefined
        markz
        @kvi94 I'm confused about your setup. Are you saying you have an always-on 24V supply manually enabled into the Duet? The Duet3 produces 12V internally but that's very current limited. I did not think there was any 24V on the board without Vin.
        kvi94undefined 1 Reply Last reply Reply Quote 0
        • kvi94undefined
          kvi94 @markz
          @markz I am talking about Duet 3 6HC not Mini 5+. Duet 3 6HC has both a 12V and 24V always-on connector on board.
          markzundefined 1 Reply Last reply Reply Quote 0
          • markzundefined
            markz @kvi94
            @kvi94 I have two Duet3 6HC's that I run and just don't see what you're describing. Can you explain your configuration a bit better? What do you mean by "power control using a SSR and pushbutton switch"? Which specific pin are you saying is 24V always on?
            • kvi94undefined
              kvi94 @markz
              @markz with reference to 6HC connector layout link below. On the left side of the reset button, is 24V always-on (GND,VFUSED). 12V always-on is located between output row(7-9) and thermistor inputs.
              https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/33DEuEJZXP16vLbF.huge
              Regarding the power control using a SSR and pushbutton, please find below a schematic of my configuration. The input side of the SSR is connected to PSON and GND. Hence, M80 and M81 can be used to control the input power.
              Since my pushbutton is LED illuminated, it is wired to the 24V always-on as well.
              kb58undefined fcwiltundefined dc42undefined 3 Replies Last reply Reply Quote 0
              • kb58undefined
                kb58 @kvi94
                @kvi94 Dumb question for the OP: have you confirmed that your SSR will indeed switch 24VDC? Many/most SSRs are designed to switch AC only, and count on it reversing polarity in order to switch. I'm not sure what it would do if DC is applied to the switching element.
                Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
                • kvi94undefined
                  kvi94 @kb58
                  @kb58 I precisely bought a dc switching SSR for this matter. The output is rated at 150vdc. Please find the link below.
                  https://www.se.com/ww/en/product/SSP1D425BD/harmony%2C-solid-state-relay%2C-25-a%2C-panel-mount%2C-dc-switching%2C-input-3.5...32-v-dc%2C-output-1…150-v-dc/
                  • fcwiltundefined
                    fcwilt @kvi94
                    @kvi94
                    Is there a reason you are trying to switch the DC out from your power supply rather than switch the AC in to the power supply?
                    • kvi94undefined
                      kvi94 @fcwilt
                      @fcwilt I actually wanted a "solution" in order to perform a safe shutdown of my duet board once a print is over. Hence, adding M81/M81 S1 at the end of a print job gcode will automatically shutdown the board.
                      • fcwiltundefined
                        fcwilt @kvi94
                        @kvi94 said in Duet 3 does not restart:
                        That doesn't explain why you are trying to control the DC out from the power supply when you could control the AC in to the power supply.
                        • MdeJongundefined
                          MdeJong @kvi94
                          @kvi94 Hello, This issue is that when you execute the M999 command the board switches of, right?
                          If you press push button, will it power up then?
                          The problem is, that due to the reset, the SSR is switched off (PS_ON is off), and will not be switched on again.
                          I think that the output from the pson is not active after reset.
                          Regards Mark,
                          • kvi94undefined
                            kvi94 @fcwilt
                            @fcwilt I do understand your point, that is totally correct.
                            To be more explicit about my configuration, I have split my system in two enclosures which are 50cm apart. One contains all my 230vac components (PSU and BED SSR) and second enclosure contains 24vdc components (Duet 6HC and 24vdc SSR). To simplify wiring, troubleshooting and keep the machine safe as possible I have decided to control 24vdc rather than 230vac. Additionally, I have no issues if the PSU is running for long hours, considering the price of a brand new PSU vs a brand new Duet.
                            • kvi94undefined
                              kvi94 @MdeJong
                              @mdejong yes correct, upon execution of M999 is switches off and when I press the push button is it on again.
                              But what is actually troubling me is when I disconnect the two fans from the 24vdc always-on connector and perform M999 the board restarts by itself without me pressing the push button (it is like the SSR and push button is absent).
                              So I am guessing that the fans are power hungry and hence there is not enough power reserve for the duet to restart.
                              I am also concerned that it might affect M916, in case of power failure the board might not be able to save required data.
                              Thus, why I turned towards the community and developers to confirm if it is a normal behaviour of the board and if anyone here has some simple ideas of how I can solve this issue.
                              MdeJongundefined markzundefined 2 Replies Last reply Reply Quote 0
                                Phaedrux Moderator @kvi94
                                Do you have the specs on the fans? Those seem pretty beefy.
                                • fcwiltundefined
                                  fcwilt @kvi94
                                  OK I think I understand.
                                  But regards safety do you have a way to turn off the power to the AC devices like the BED SSR?
                                  SSR device tend to fail "shorted" meaning power will always be applied to the BED unless you have a way to turn off the incoming AC power.
                                  All my printers are connected to a network controllable outlet box with which I can kill the AC power to and or all of my printers.
                                  • MdeJongundefined
                                    MdeJong @kvi94
                                    @kvi94 What if you connect the fans directly to the 24 volt and not through the Duet.
                                    or use an mosfet to switch on the fans, the power supply for the fan connect before the SSR and the
                                    always on the control the mosfet.
                                    It could be that the Duet3 power supply is drained to fast due to the fans power consumption,
                                    due to the reset the PS_ON will be switch of, at start-up it is switch on again,
                                    but if the cpu power supply get to low the cpu will stop (switch off)
                                    I hope the description is understandable.
                                    Regards Mark,
                                    • markzundefined
                                      markz @kvi94
                                      @kvi94 I have trouble understanding how PS_ON will work in this environment. The PS_ON control voltage is generated by the CPU, but the board CPU power is coming from the device switched by the PS_On pin which seems circular to me. How does that tie into the pushbutton switch?
                                      Is this a correct summary of your intent?
                                      1. Support M80 and M81 for power on/off using the ps_on pin.
                                      2. Keep the 24V fans on all the time when power is supplied.
                                      3. Use the pushbutton switch to do what?
                                      Looking at the schematic (not too carefully) I don't see how a fan load would substantially affect the ability to reset since afaik the 24v pin you're using is straight from the power supply and a fuse.
                                      Concerning your setup, I applaud the AC/DC isolation but running the PS_ON pin/pair (shielded) from the CPU over to a 230vac SSR won't have any real noise issues. If I were you in this setup I'd put in a cheap (like $2) 24-5V DC converter for use as an always-on CPU supply (external 5V) and then PS_ON is going to work the way you want.
                                      Maybe I'm overthinking this and if so I apologize.
                                      Mark
                                      MdeJongundefined 1 Reply Last reply Reply Quote 1
                                      • MdeJongundefined
                                        MdeJong @markz
                                        This post is deleted!
                                        • MdeJongundefined
                                          MdeJong
                                          My post was marked as spam by aksimet.com therefore with picture
                                          Regards Mark,
                                          markzundefined 1 Reply Last reply Reply Quote 2
                                          • markzundefined
                                            markz @MdeJong
                                            @mdejong Very clear. Thanks.
                                            I'd still vote for a simple 24->5 converter that provides external always-on 5V. The switch could be tied into a script that runs M80.
                                            kvi94undefined 1 Reply Last reply Reply Quote 2
