Unofficial 3.4 Maestro Beta: Extruder Drive Issue
Beta Firmware
397
    CCS86
    Hey @dc42 I just flashed the unofficial beta build to give IS a shot on my Maestro, but didn't get to test it yet.
    With IS and PA disabled, it was evident that the extruder drive wasn't functioning correctly. Even my prime line misbehaved with a pulsing extruder action, and high pitch whine from that stepper. Once the print started (a simple spiral vase square box), it continued to make high pitch "chirpy" sounds from the extruder stepper, and didn't push much plastic at all.
    Stepper analyzer shows some definite weirdness:
    Video of stepper: https://photos.app.goo.gl/w7nxsWg2BnRwjP9b6
    M122 below. Let me know if I can gather anything else useful for you.
    RepRapFirmware for Duet 2 Maestro version 3.4.0beta2+ (2021-08-13 08:58:33) running on Duet Maestro 1.0
    Board ID: 08DJM-956DU-LLMS4-7J9F6-3SN6Q-KBM2Q
    Used output buffers: 1 of 24 (24 max)
    Static ram: 23572
    Dynamic ram: 69288 of which 0 recycled
    Never used RAM 18004, free system stack 158 words
    Tasks: NETWORK(ready,30.5%,262) ACCEL(notifyWait,0.0%,347) HEAT(notifyWait,0.1%,341) Move(notifyWait,0.1%,315) TMC(notifyWait,1.4%,117) MAIN(running,67.9%,459) IDLE(ready,0.0%,30), total 100.0%
    Owned mutexes:
    Last reset 00:16:33 ago, cause: software
    Last software reset at 2021-08-11 20:47, reason: User, GCodes spinning, available RAM 19744, slot 2
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
    Error status: 0x04
    Step timer max interval 1866
    MCU temperature: min 41.2, current 42.7, max 49.0
    Supply voltage: min 24.0, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/24/24, gc cycles 0
    Driver 0: position 0, standstill, read errors 0, write errors 1, ifcnt 178, reads 34263, writes 9, timeouts 0, DMA errors 0
    Driver 1: position 0, standstill, read errors 0, write errors 1, ifcnt 246, reads 34263, writes 9, timeouts 0, DMA errors 0
    Driver 2: position 5880, standstill, read errors 0, write errors 1, ifcnt 188, reads 34263, writes 9, timeouts 0, DMA errors 0
    Driver 3: position 0, standstill, read errors 0, write errors 1, ifcnt 155, reads 34263, writes 9, timeouts 0, DMA errors 0
    Driver 4: position 0, standstill, read errors 0, write errors 1, ifcnt 62, reads 34266, writes 6, timeouts 0, DMA errors 0
    Driver 5: position 0, assumed not present
    Driver 6: position 0, assumed not present
    Date/time: 2021-08-13 14:24:01
    Slowest loop: 546.35ms; fastest: 0.10ms
    === Storage ===
    Free file entries: 10
    SD card 0 detected, interface speed: 10.0MBytes/sec
    SD card longest read time 1.3ms, write time 152.1ms, max retries 0
    DMs created 83, segments created 32, maxWait 737474ms, bed compensation in use: mesh, comp offset 0.000
    === MainDDARing ===
    Scheduled moves 464, completed moves 464, hiccups 108748, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
    === AuxDDARing ===
    Bed heaters = 0 -1, chamberHeaters = -1 -1
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty
    === Network ===
    Slowest loop: 478.23ms; fastest: 0.02ms
    HTTP sessions: 1 of 8
    Interface state active, link 100Mbps full duplex
    undefined undefined 2 Replies Last reply 13 Aug 2021, 20:13 Reply Quote 0
      dc42 administrators @CCS86
      @ccs86 what pressure advance setting are you using?
      undefined 1 Reply Last reply 13 Aug 2021, 20:19 Reply Quote 0
        CCS86 @dc42
        @dc42 said in Unofficial 3.4 Maestro Beta: Extruder Drive Issue:
        Zero at the moment.
        Here's my full config:
        config.g.txt
          MikeS @CCS86
          @ccs86 I think i hit the same bug but on a duet2 wifi running the latest beta. It seems that high pitch is starting when printing lines considered "bridges" from prusa slicer at the first layer that was at 0.13mm (variable layer height print). Also i notices some more clicking on other test print i was doing as per previous beta build. I get nothing when issue M122 on that firmware.
          Video of the issue (starts at around 0:50):
          Youtube link
          Gcode:
          Spool.g
          Config.g:
          ; generated by RepRapFirmware Configuration Tool v3.1.9 on Sat Nov 28 2020 11:28:36 GMT+0100 (Ora standard dell’Europa centrale)
          G21
          M550 P"Voron 2.4" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          ; PanelDue
          M575 P1 S1 B57600
          ; --- drive map ---
          ; _______
          ; | 6 | 7 |
          ; | 5 | 8 |
          ; front
          M569 P0 S1 ; A
          M569 P1 S1 ; B
          M569 P3 S1 ; Extruder
          M569 P5 S1 ; Z1
          M569 P6 S0 ; Z2
          M569 P7 S1 ; Z3
          M569 P8 S0 ; Z4
          M584 X0 Y1 Z5:6:7:8 E3 ; set drive mapping
          M92 X80.00 Y80.00 Z400.00 E419.50 ; set steps per mm
          M906 X800 Y800 Z1000 E800 I75 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          ;M566 X1500 Y1500 Z60 E16000 ; Set maximum instantaneous speed changes (mm/min)
          ;M203 X18000 Y18000 Z3000 E20000 ; Set maximum speeds (mm/min)
          ;M201 X3000 Y3000 Z250 E4000 ; Set maximum accelerations (mm/s^2)
          M566 X600 Y600 Z600 E8000 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000 Y18000 Z6000 E15000 ; Set maximum speeds (mm/min)
          M201 X20000 Y20000 Z1500 E1800 ; Set maximum accelerations (mm/s^2)
          M204 P1500 T2000 ; Set printing acceleration and travel accelerations
          M208 X3:350 ; set axis minima/maxima
          M208 Y0:350
          M208 Z0:330
          M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
          M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
          M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
          ;M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
          ;G31 P500 X0 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
          M308 S0 P"bedtemp" Y"thermistor" A"Piatto" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 R0.703 C465.2 D4.17 S0.65 V23.9 B0 ;PWM max @65%
          ;M307 H0 R0.636 C552.9 D5.58 S1.00 V23.9 B0 PWM max @ 100%
          M308 S1 P"spi.cs1" Y"rtd-max31865" R430 ;PT100
          ;M308 S1 P"e0temp" Y"thermistor" A"Estrusore" T100000 B4725 C7.06e-8 ;B4138 originale E3D
          ;M308 S1 P"e0temp" Y"thermistor" A"Estrusore" T100000 B3950 ;NTC CINESE
          M307 H1 B0 ; disable bang-bang mode for heater and set PWM limit
          M950 F0 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency
          M106 P0 S0 H-1 C"Layer" ; set fan 1 value. Thermostatic control is turned on
          M950 F1 C"fan0" Q32000 ; create fan 0 on pin fan0 and set its frequency
          M106 P1 S255 H1 T45 C"Hotend" ; set fan 0 value. Thermostatic control is turned off
          M950 F2 C"fan2" Q100 ; create fan 0 on pin fan0 and set its frequency
          M106 P2 S0 H0 T50 C"Elettronica" ; set fan 0 value. Thermostatic control is turned off
          M950 F3 C"e1heat" ; create fan 0 on pin fan0 and set its frequency
          M106 P3 S0 H-1 C"Luci" B0 L0 ; set fan 0 value. Thermostatic control is turned off
          M950 F4 C"duex.fan3" Q32000 ; create fan 1 on pin fan1 and set its frequency
          M106 P4 S0 H-1 C"LayerBIG" ; set fan 1 value. Thermostatic control is turned on
          ; NPN Z-Probe
          M400
          M558 P8 C"zprobe.in" F1200 H5 A5 S0.01 B0 R0.2 T25000
          G31 T8 P500 X0 Y25 Z0.665 ; inductive probe offset, not critical, only used for coarse homing
          ; Z tower positions
          M671 X-65:-65:365:365 Y-20:380:380:-20 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
          M557 X10:340 Y0:300 P10
          ;Taper height
          M376 H10
          ;Accelerometer
          M955 P0 C"spi.cs5+spi.cs6" I50
          ; Input Shaping
          M593 P"zvdd" F58.4
          ;M593 F50
          ;Firmware retraction
          M207 S1.5 F3600 Z0.2
          ;Full Lights on at startup
          M106 P3 S1.0
          T0
          filament.g:
          ;M592 D0 A0.001692599 B-0.000105515
          M572 D0 S0.045
            CCS86
            Any other data that I can gather to help with this?
            undefined 1 Reply Last reply 16 Aug 2021, 20:15 Reply Quote 0
              @ccs86 said in Unofficial 3.4 Maestro Beta: Extruder Drive Issue:
              Yes, you've already provided your config.g file but please also provide a print file that demonstrates the problem.
              undefined 1 Reply Last reply 16 Aug 2021, 21:56 Reply Quote 0
                CCS86 @dc42
                The issue was evident even in my prime line:
                G1 X10 Y0 Z.3 F2000
                G1 E0 F2000
                G1 X50 E5 F1200
                G1 X135 E11 F1200
                G1 X145 F800
                  @ccs86 please try the updated build at https://www.dropbox.com/sh/cq7q3g8coymo9s3/AABtPYEzV1_unETpKEMPInSia?dl=0.
                  undefined 1 Reply Last reply 18 Aug 2021, 13:39 Reply Quote 0
                    CCS86 @dc42
                    Awesome, working beautifully so far!
                    Very simple first test: 30x30x30 square, 3 perimeters, 80 mm/s, 10k accel, 12 jerk
                    All shapers seem highly effective at cancelling the ringing. But all visibly slow the effective acceleration a lot and cause significant corner bulge. I would love to be able to just tune that out with PA, but have found the current implementation very ineffective on my bowden printer.
                    5 out of 9
